Question about Refrigerators
I have a kenmore 253.26072100 freezer everything was fine i unplugged it to clean behind the freezer was without power for about two hrs and plugged it back in and went to bed next day got home from work to a puddle on the floor and freezer was not working light was on inside and meat was starting to thaw. the display is not working on the outside and commpressor is not on. I changed the battery also in this process to no avail. Can you help
  • 114 Answers
SOURCE: Bottom mount freezer not getting cold enough
You have a failed component or components in your automatic defrost system. This is why you have excessive frost inside the freezer along the back wall. The timer could be stuck in run mode. The defrost thermostat (bi-metal) could be defective or the defrost heater could be open or shorted.
Posted on Sep 27, 2007
  • 145 Answers
SOURCE: Sears Kenmore ColdSpot Frostfree Frosting up/Not working
You have a defrost problem. You need to determine which one of the parts is faulty. The defrost timer on that model should be behind the kick plate in the center front underneath. If you turn the little knob by hand you will hear a load click when it gets to the defrost point and the unit should shut off. Check in the bottom of the freezer to listen for water sizzleing or for water running down. If it is the timer is not advancing and needs replaced. If not you will have to take the back off the inside of the freezer to see if it is the heater or the defrost thermostat. Unhook power before taking panel off or replacing any parts.
Posted on Apr 24, 2008
  • 5 Answers
SOURCE: ARB2214CB - Condensor is Noisy
If there's an ice maker but you don't have water piped to it therefore and it can't work, try pulling the wire arm up that turns off the ice maker. It's down in the freezer, on the upper left freezer area.
I replaced my capacitor on my compressor before I noticed this. It's easy to drag something by it and bump it down.
Posted on Mar 09, 2009
tborn6
  • 700 Answers
SOURCE: SAMSUNG RS2545SH FREEZER SIDE BLINKS AND THAWS WHEN AT WORK
check to kake sure that you have not blocked the air inlet holes in on the back side of the freezer and that the door lights work on the freezer side.
Posted on Mar 21, 2009
caroldon
  • 17130 Answers
SOURCE: sudenly stops working everything in freezer thaws
The auto timer in your Fridge is faultly and is not defrosting in the eight hour cycle. There could also be any wire detached from corrosion inside/within the freezer compartment that gives wrong signals to the the thermostat. You will have to remove the inside cover to confirm.check the wires to the heater/ failure of the heater. In case you are not able to do the work have this in mind and look into what the technician responds. take an estimate and move on.Helpful? good day
Posted on Jul 02, 2010
GE profile bottom freezer model # PGSS5NFXA SS. Got up this morning and freezer thawing. Pulled back panel cleaned the condenser fins with compressed air andchecked the connections. runs fine but can'
I had this happen with my fridge when the door was open for awhile when I was cleaning the inside. I did what you did, clean everything behind it. Pay particular attention to the circuit boards, there may be reset buttons in that area. Then unplug the freezer for 10 minutes (make sure it's for a FULL 10 minutes) then plug it back in and try it.
Feb 03, 2015 | GE Refrigerators
Sidebyside kenmore works great for 12 hr. then seems to go into defrost mode and won't cool unless i unplug for 6 to 8 hrs plug it back in and it works fine for 24 hrs then repeats
Larry I tried to write the solution here but it would not send. Click Here=> Kenmore Appliance Model Number Locator and examples Your solution is at top and center of that web page. Let me know if helpful or if you have more questions, Thank You, Sea Breeze
Nov 16, 2011 | Refrigerators
I have a Kenmore Elite refrigerator model number 59673503201 and there is a terrible fish smell coming from the bottom portion of the appliance where the freezer is. It is not coming from trash, or food...
Please note when you keep fish in freezer once, the smell will be longer even you remove it. O.K. Now solution for your problem- Please unplug power.Keep fridge door open. Take wet cloth dipped in soap water and clean all compartment including freezer . Keep freezer door also opened.Then clean with dry cloth. Spray room spray in your room not into the fridge. And allow 5 hrs to circulate fresh air to pass thr' your fridge and then close fridge and freezer doors. Plug fridge and run for one hour on empty. After one hour store items in fridge and/or freezer.
Keep all food items in closed style which will avoid odor spreading and also be a hygienic. Thanks.
Jan 30, 2011 | Refrigerators
Kenmore side by side not cooling
First off how far did it get leaned when moved and second it might just need to be cleaned.
If you laid it down when it was moved it should have been left unplugged for 12 hrs before plugging in because the refridgerant used is also a lubricant and it needs time to settle.
As far as cleaning it you will need to take off the back panel and use a vac to clean out the dust.There is also a kickplate on the front that needs to come off and clean the cooling grates that are under there.If you have a dryer brush it works great for cleaning the grates.You can get between them with it.
Unplug it before you do any of this.
Oct 22, 2009 | Refrigerators
My older kenmore refridgerator/freezer isnt cooling well
Likely defrost mode, which on older models runs for a fixed amount of time whether needed or not.
The motor that times the cycle may be stuck or running slowly. It often is located at the bottom front of the frig behind a cover that runs between the front legs. Unscrew it and you will see a small motor running, that, through gears, turns a wheel 1 rotation every 24 hours.
The wheel can also be turned by a screwdriver - turn it until you hear a click that indicates defrost cycle is off. Should solve the problem short-term.
Long term, replace the faulty motor or clean it off to run smoothly. Alternately, unplug the motor so that defrost never kicks in automatically and defrost it manually.
Oct 03, 2017 | Kenmore Refrigerators
When plugged, kenmore freezer shorts the surge protector and outl
if thats the case should be an apparent wire off, somethings shorting directly to ground. the chest freezer has all of its wiring behind the access panel on the side of unit , no other wires in machine id look right there for something obvious
Nov 30, 2008 | Kenmore 14.8 cu. ft. / 419 liter Chest...
GE Fridege TBX18J MS not getting cold
hi is the fan motor going in the freezer. if so how long has it been plugged in if more than 24 hrs and the fan is going. it could be that because it sat for 10 years the lines that go inside could have rusted out. so if this is the case its scrap sorry. the appliance doc.
Oct 16, 2008 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Refrigerator will not cool
also the complete mod number would help
May 21, 2008 | Refrigerators
Kenmore elite MOD.596.76533500
Hi, If the freezer is cold............ I would suspect the defrost timer. Remove everything and place in coolers or another refrigerator. Unplug the refrigerator. With doors open let it sit for aprox 6 hrs. A fan blowing into the freezer section will help. Plug back in and see if it works good again. The fans may be caked in ice and should run again but they may have burned up and need replaced. If it works good for a couple of days and problem returns, Replace the defrost timer. Hope this helps. kstfas
Sep 24, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
