Question about Konica Minolta Magicolor 4695MF All-In-One Laser Printer
004E error code mc4695mf
Code occurs after warm up.have replaced the fan & prcb board.
Bizhub 951how to remove code c-0104
Dear Noorul,
Your question seems to be related to a copier. It is categorized under tv & video. I hope this is the information you are looking for:
Code
C-0104
Description
Abnormality of the vertical conveyance motor (M8) power in the printer control board (PRCB). An error detection signal (blowout of ICP) of M8 is detected when M8 is turned ON.
Causes
• Vertical conveyance motor (M8) • Printer control board (PRCB)
Konica Minolta bizhub Pro 951 Error Codes
Sounds like you have some replacement of parts that are needed. Let me know if you need a service manual. I will look for that.
Blessings!
Jul 05, 2017 | Televison & Video
Bizhub 554e error code C-4801
C4801
(1) Contents Trouble type Main unit board failure
Trouble code C4801 Rank C
Detection timing MFP detects simultaneous replacement of multiple boards.
Trouble isolation -
Relevant electrical parts • SSD board (SSDB)
(2) Procedure
Step Action Control signal Location of electrical components
1 Reinstall the old PRCB. - -
2 If the above actions do not solve the problem, contact
KM. - -
NOTE
• Do not replace the printer control board and the SSD board at the same time. The backup data is lost and image failure may be
caused.
Dec 29, 2016 | Konica Minolta bizhub Office Equipment &...
MY BIZHUB 283 SHOWING THE ERROR CODE C-0202
Code
C0202
Description
Tray 1 feeder up/down abnormality
The tray 1 upper limit sensor (PS22) is not blocked even after the lapse of a given period of time after the lifting motion has been started.
Remedy
1 Check the connector between M12-PRCB CN25 for proper connection and correct as necessary. 2 Check the connector of M12 for proper drive coupling and correct as necessary. 3 Check the connector between PS25-relay CN30- PRCB CN26 for proper connection and correct as necessary. 4 PS25 I/O check, sensor check PRCB CN26-3 (ON). 5 M12 operation check PRCB CN25-5 (REM). 6 Replace M12. 7 PRCB ICP5 conduction check. 8 Replace PRCB.
Konica Minolta bizhub C224e Error Codes
Nov 08, 2016 | Office Equipment & Supplies
What is Error 0F54
Here is your error code
Code 0F54 Description Toner level sensor /C malfunction
• An error occurs on the toner level sensor board (TLSB). Remedy 1 Check the cable and connector for proper connection and correct as necessary. 2 Change TLSB. 3 Change PRCB.
Aug 14, 2015 | Konica Minolta Magicolor 4690MF...
Error code: 4801
Error code: 4801 "System can't satisfy the requested min upstream rate. Please input again."
Feb 25, 2015 | TP-LINK Computers & Internet
Konica minolta bizhub pro c6501 error c2304
Developing fan/1 (M45)
Developing fan/2 (M46)
Developing fan/3 (M64)
Check the above fans or its the board that controls them $$$$$$$$$$$
Apr 04, 2014 | Konica Minolta bizhub Office Equipment &...
0F54H Fatal Error
Witam,
An error occurs on the toner level sensor for each color:
0F52H Toner level sensor /Y malfunction
0F53H Toner level sensor /M malfunction
0F54H Toner level sensor /C malfunction
0F55H Toner level sensor /K malfunction
Relevant electrical parts:
Toner level sensor/Y (PS13)
Toner level sensor/M (PS14)
Toner level sensor/C (PS15)
Toner level sensor/K (PS16)
Step Action:
1 Check the connector between each sensor- PRCB PJ21 for proper connection and correct as necessary.
2 Replace the toner level sensor of the corresponding color.
3 Change PRCB.
Feb 11, 2014 | Konica Minolta Magicolor 3730 Dn Color...
0500H Fatal Error
Witam,
0500H Heating roller warm-up failure:
The thermistor /1 does not detect the specified temperature and the warm-up cycle is not completed even after the lapse of a given period of time after the cycle has been started.
Fuser unit
DC power supply (DCPU)
Solutions:
1 Check the fuser unit for correct installation (whether it is secured in position).
2 Check the connector between fuser unit - PRCB PJ9 for proper connection and correct as necessary.
3 Check the connector between fuser unit - DCPU CN2 for proper connection and correct as necessary.
4 Change fuser unit.
5 Change PRCB.
6 Change DCPU.
Mar 12, 2013 | Konica Minolta Magicolor 3730 Dn Color...
Can anyone tell me what sc32-10 on bizhub pro 1050 is?
The blowout of a fuse for the
transfer/separation suction fan
(FM4) in the printer control board
(PRCB) is checked.
An abnormal condition occurs
with the FM4 EM signal a specified
period of time after FM4 is turned
ON. This abnormal condition
recurs even a specified period of
time after FM4 is turned OFF and
then turned ON, and an error
detection signal (blowout of a
fuse) is detected with the 24V normal
Your Fan (FM-4)or the Board PRCB (Printer Control Board) is bad. Hope the fan not the board $$$$$$$$$$$$$$
Mar 25, 2012 | Minolta Office Equipment & Supplies
Konica Minolta Magicolor 4695MF All-In-One Laser Printer Logo
67 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
