Question about Vacuums
I took apart my bissell easy vac to clean it because it was clogged and now I cannot remember how a part goes on that is underneith the vacuum. I keep putting it on but its not right. It lifts the vacuum off the floor so it is not sitting in there right.
  • 66 Answers
Make sure the plate is lined up correctly it should side down flush
Posted on Jan 24, 2009
My vacuum lost it's suction power. I've looked to see if it's clogged and the container is clean. What's going on?
That type of vac is notorious for stopping up where the 90 degree turn is. You may need to access it from the vac head by removing the beater bar or take it apart where ever you can access the turns and hoses.
Feb 19, 2011 | Bissell Healthy Home HEPA Bagless Upright...
My Bissell 3130 Easy Vac Bagless vacuum makes a "rev sound when pulling back on the vacuum, never did this before i have taken apart and cleaned vacuum thoroughly, not sure what else i can do
The drive belt may be wornout/stretched and the act of pulling the vacuum backwards could be causing the belt to slip and the motor to rev up as a result.
Do you have a replacement belt you can try?
Jan 05, 2011 | Bissell 3130 Bagless Upright Vacuum
I took my bissell 9400 series apart to clean the heater and the hoses were clogged. now I'm not sure where they go, i get all solution now and no water. i cant find a diagram of hoses nowhere,
I've taken some pictures of the inside of my Bissell Proheat 2x Plus and posted them here:
http://bbay.dreamhost.com/bissel_proheat_2x_plus/
Best of luck!
Nov 18, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Debris getting stuck in vacuum hose
Check that the filters are completely clean. If there are clogged they would have to be washed and then dried to room temp (or a low temp tumble dryer, put the filters into a pillow case with a towel and install into the machine) Tip the bissell backwards to make sure the bottom bin is pushed and locked all the way in. Only when the two seals meet will you know that the bin has locked in properly. Unhook by prising the main hose at the back off to check for clogs as well as the main hose at the bottom and the main dust channel at the sole plate where the roller bar is. You may have to remove the bottom plate to check for any obstructions behind the brush bar.
I have the Easy vac myself. Its not an Easy machine to maintain when it gets clogged!
Mar 22, 2009 | Bissell 3102-0 EasyVac Upright Vacuum
My bissell easy vac won't pick up after first use
Well after reading and re-reading my bissell easy vac manual (I had only used the vac twice), I went through all the troubleshooting recommendations. I cleaned out all filters and even though I had only used my hose attachment once, I was shocked that it was completely clogged! I took the whole thing apart and thoroughly cleaned it out according to the manufacturers instructions. It is working beautifully again now, I just take extra care to check it after every use...it can be a hassle, but I find that's what happens when you buy bargain items; you spend less but end up investing more time in upkeep. I hope this helps!! :)
Dec 20, 2008 | Bissell 3102-0 EasyVac Upright Vacuum
Attachment hose has no suction
Sometimes when you take them apart and
reassemble the vac (the plastic slide doesn't
make full contact with the lever,or it isn;t on
the lever at all) that switches
from the floor to the attachment. IF Tthere
are no clogs in the duct then that the
most likely problem
Nov 18, 2007 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Vacuums Logo
50 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
