Question about Canon MP250
The black ink in my mp258 canon printer is blured how can i fix it
The photocopy and print result in black ink is blurred or not good result
  • 826 Answers
Try a few print head deep cleanings if that does not help then you could try soaking the print head in a shallow plate of hot distilled water. Soak the tip of the print head only in no more than 1/8th to 1/4 inch of water.
Posted on Jan 16, 2013
Danieldesmon
  • 56 Answers
SOURCE: Canon MP190 not printing using only black ink, color ink finished
hai there...you try press the reset and colour button in the same time...the printer will back to normallyl
Posted on Mar 01, 2010
  • 619 Answers
SOURCE: blurred printing printer i255
Hi, check the nozzle and test , if the result not in solid color there are spaces within the color means need head cleaning after head cleaning twice test print .
Posted on Jan 23, 2008
  • 739 Answers
SOURCE: Canon MP600 printer. Black Ink cartridge PGBK5 is
You need both. One is pigment and the other is dye. One is used for photographs and the other for non-photographs - but it's the printer that decides which one to use.
All Canon printers (to my knowledge) will stop working if any one ink cartridge is empty. This is to prevent damage to the print nozzles. The ink itself is the cooling medium for the hot nozzles.
Posted on Nov 29, 2009
Testimonial: "Instant answer so I can stop trawling the internet now! Thanks"
  • 1583 Answers
SOURCE: The black ink won't print on my canon iP5200.
Try removing the cartridge and cleaning the cartridge contacts in the printer with a cotton swab dampened with isopropyl alcohol. When the contacts are dry, lightly scrub them with a white pencil eraser (the red ones are too coarse and may cause more problems), then wipe clean with a dry cotton swab.
If that doesn't help, open up the printer and find the other end of the ribbon cable connected to the print head carrier. There is often some sort of locking clamp on that connector. Unlock it, pull out the ribbon cable and clean the contacts on that end, then reassemble. (The lock may be a sliding sleeve around the cable (it only comes out about a millimeter) or a flip-up plate. If there is nothing like that, the cable is a friction fit and pulls out with a small amount of force. Some very cheap printers use a permanently attached connection).
Explanation: It is possible that there is a second drive voltage to the print heads that isn't connecting, but its failure doesn't prevent normal communications to the cartridge using the logic level voltage.
Posted on Dec 09, 2009
SOURCE: my canon pixma mp258, the
I have this problem too...I can see is my ink inside the ink hose is stuck.....can't go in to the ink Cartridge....so that means problem is the ink ...stuck in the middle of the ink hose...if anyone how to run the ink in the ink hose...please help me..=]
Posted on Nov 01, 2010
I have a brother DCP-165C and it is not printing black.
The nozzle may be blocked. So take out the colour cartridge and place its nozzle in a bit of water for about 10 mins. Bring it out and dab the nozzle with folded paper. If the tissue is blotted with the three colour it means you have unblocked the nozzle. Try now to print after returning the colour cartridge. You may need to repeat to get good results.
Thank you!!
Jul 12, 2010 | Brother DCP 165C Compact Color Inkjet...
All colours and black print faded. Black is a
ANSER #1
Assuming that you are using original Canon cartridges or a brand of Compatibles that you have used before.
If print results are blurred, colors are faded or not printed correctly, the pint head nozzles are probably clogged.
Follow the procedure below to print the nozzle check pattern, check the print head nozzle condition, then clean the Print Head. You may have to do this 2 or 3 times.
If printed ruled lines are misaligned or print results are otherwise unsatisfactory, aligning the Print Head may improve print quality.
Caution Do not rinse or wipe the Print Head and ink tanks. This can cause trouble with the Print Head and ink
tanks.
Note Before performing maintenance
Open the Top Cover and make sure that all lamps on the ink tanks are lit red.
If not, see Checking the Ink Status and take an appropriate action.
Increasing the print quality in the printer driver settings may improve the print result.
Sep 30, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
I can't print photo's properly
If you are to go into the printer properties you should be able to adjust the print saturation for your pictures. I am not sure what type of printer you use from your post although if the information I have provided is not sufficient then please respond with the make and mode of your printer and if it came with any software.
Sep 21, 2009 | Office Equipment & Supplies
My C6280 printer says the black is empty but it is
Dear Sir,
Printer doesn't identify the ink accurately all these are controlled by software only.So it is showing your black cartridge is empty but trace amount of ink actually remained,by this you are getting black and white prints correctly.After the consumption of that trace amount of ink it may print black text as a greenish-brown because printing taking place only by means of color cartridges.So if you observed blurred text or greenish-brown text, now you can replace your ink cartridges.
i think it helps
good luck
Aug 11, 2009 | HP Office Equipment & Supplies
I only want to use the black ink, not all 4 colors
Color printer have sofware installed which stops all printing inless their is ink in all containers. No, their is no way around it. Someone would be rich making a kit to do so. since I see this question over and over  at least once a week.
Mar 09, 2009 | Brother MFC 420CN All-In-One InkJet...
Photocopier prints red
You might be running low on black ink and it's not an item when you print from your computer because the settings you are calling for are different. The computer asks you if you want to print normal...to best, etc.
Apr 25, 2008 | Dell 924 All-in-One InkJet Printer
Print result at 1st line ok..2nd line become blur..its alternate till end of printing
Replace the ink cartridge.
The cartridge is so wide that it can print 2 lines at a time, and the upper part of it is probably partially clogged. That's why every 2'nd line is blurred, and the rest is ok.
Jan 17, 2008 | Office Equipment & Supplies
Canon MP250 Logo
376 people viewed this question
old marine
old marine
