Question about GE Profile JTP95 Electric Single Oven
Microwave at the same time, the microwave truntable stopped turning and the microwave wasn't heating the food
  • 76 Answers
This would most likely caused by a door switch. It is either not being activated by the door not closing tight enough or the switch itself has failed
Posted on Jul 11, 2007
SOURCE:
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    Microwave is not make food hot
    Hi.
    The wave emitting part inside the microwave oven is called the magnetron. The waves emitted by the magnetron generate heat in food. When the microwave is running, turntable turns and light comes on but there is no heat it means that either the magnetron is faulty or the magnetron is not getting power. When the magnetron is not getting power parts such as the high voltage diode or capacitor must be tested or replaced. Testing and repair must be carried by a technician. Here some general troubleshooting: http://www.fixya.com/support/r2096491-microwave_works_normally_but_not_heat
    Regards.
    Ginko
    Sep 05, 2011 | Whirlpool Ovens
    My microwave 290HS was performing perfectly until one day when it stopped heating. I followed the steps given in the manual. The tray is rotating, the light inside goes off when the door is closed, the...
    May be one of the components in the High Voltage circuit has failed...Usually there is a relay or semiconductor switching device that turns on a tube called a magnetron..this magnetron is what heats the food...any one of the components in these circuits could have failed...I would have a repairman look at it to see if would even be worth it to get it fixed.
    Dec 20, 2010 | Ovens
    I own a microwave oven of make Sharp electronics. I had been using this for past two years. All of a sudden it has stopped heating the food items/water, though the light is glowing and the oven makes the...
    Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
    Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
    Microwave Oven Basic Troubleshooting Tips
    heatman101
    Sep 08, 2010 | Sharp Ovens
    Why does food get hard after cooking or reheating in a microwave
    It's basically a loss of moisture during the cooking process, to avoid this in a standard oven cook on a lower temp for longer and cover with foil....in the microwave, drop the power setting and always reheat or cook with the food cover with a microwave safe cling wrap or microwave specific cookware with lids.
    Hope this helps.
    Sep 08, 2010 | Whirlpool Ovens
    Convection works but Microwave does not heat
    Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
    heatman101
    duid
    May 26, 2009 | GE Monogram® ZMC1095BFBB /...
    try using a voltage stabiliser .it may just solve ur problem..
    May 17, 2009 | GE Monogram® ZMC1095BFBB /...
    Goldstar ma-1012W microwave oven doesn't heat food
    Sounds like a bad magnetron (the device that produces the microwaves) - if the microwave is over 6-8 years old, it's usually not worth fixing.
    Mar 17, 2009 | Ovens
    GE Profile JTP95 Electric Single Oven Logo
    205 people viewed this question
    Top GE Ovens Experts
    William Miller
    William Miller
    Steve Allison
    Steve Allison
    Marvin
    Marvin
    Are you a GE Oven Expert? Answer questions, earn points and help others
