Question about Motorola Mobility HS820 Consumer Headset
Motorola HS820 The light on my Motorola HS820 is on, permanently. I can't set it off too. It can be paired with my phone. I can't use it. The message on my phone(U6) is unable to connect.
  • 2 more comments
  • Anonymous Mar 19, 2009
    my head set wont go off blue .... i have tried everything i just dont know what to do
    this didnt help me the light never turned off
  • kenziegrl01 Mar 19, 2009
    i have a motorola HS820 headset, my light wont go off... I have tried everything i can i feel like throughing it away can you help me ??????
  • elvinchi May 22, 2009
    I TRIED THAT AND IT DID NOT WORK IT IS STILL ON AND WONT DO ANYTHING. IT DOS NOT APPERED ON ANY PHONE
This worked perfectly, props to sandrew...
Posted on Oct 05, 2007
    President:
  • 2,961 Answers
The always on light mens that it is in pairing mode and wont go out until it has paired with a phone, if you wish to turn it off, press and hold for 3 seconds, it will then flash 3 times and then go off. Try pairing again by pressing and holding the button until the light stays on.
Posted on Jul 11, 2007
SOURCE:
My droid 2 is not recognizing the motorola hs820 bluetooth device; I have no info on how to set the hs820 to pair
I think I can help here:
Make sure your headset and phone are charged before doing anything else. The blue light on your headset will come on when it is charging, and will shut off when fully charged.
To put your headset in pairing mode, make sure it is completely off first (no blinking blue light). Then hold down the Call button for 6-10 seconds until the blue light stays on. (It will likely flash once and shut off, but keep holding until it is all the way on and stays there!)
From there, go into the settings on your Droid 2 and access the bluetooth connections. Do a new scan for your headset if you don't see it listed, pair, and connect!
http://www.motorola.com/mdirect/manuals/QG-HS820_9494A71A.pdf
Feb 23, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
After charging my HS820, the light stays on, no matter what I do, and it is supposed to be in sync mode, but it won't sync with my Samsung, but my other Motorola headsets do!
You need to disconnect it from the charger and keep the button pressed to put it in pairing mode, then associate with the phone with the PIN 0000.
Jan 29, 2010 | Motorola Mobility HS820 Consumer Headset
Can't hear with bluetooth
That means the pairing is not successful.Follow the steps
1.Turn on mobile bluetooth and set the status to shown all 2.Tun on the bluetooth mobile and keep pressing the button on the  bluetooth for few seconds. 3.You will notice that light is continously ON and not blinking 4.Now find the device from mobile via search option 5 When it detect use this code 0000 to pair. 6.When the pairing is successful ,select option button and click connect.. 7.Now you should hear from your bluetooth..
Regards
Dilip Bagdi
Dec 27, 2008 | Motorola Mobility HS820 Consumer Headset
Pairing Motorola HS820 with Blackberry 8310
there is really no fail safe method to pairing a bluetooth device.
The main thing is recognition. i,d suggest trying to press the different buttons on the transmitting bluetooth device, whilst attempting to pair. i.e volume up/down or on/off et,c. to enable the device-blackberry to find and sync. i,d think the device that needs to be configured or setup correctly is the blackberry rather than the bluetooth device.
try changing the phone settings. to accept all incoming signals on bluetooth, or disable encryption.
hope this helps.
Mike @ Compurepair.
Oct 06, 2008 | Motorola Mobility HS820 Consumer Headset
NOT PAIRING ANYMORE
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select HS820 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Mar 15, 2008 | Motorola Mobility HS820 Consumer Headset
Motorola hs820
you have to press and hold the button for a few seconds, it will then flash 3 times and then stay solid blue, this is now in pairing mode, get your phone to find the headset and then pair usually with the numbers 0000, then thelight will flash then it is paired.
Sep 30, 2007 | Motorola Mobility HS820 Consumer Headset
My Phone Does Not Locate My HS820 Headset
Try the following:
1) Make sure the HS820 is fully charged up.
2) Remove the battery and SIM card from your phone for about 1 minute and put them back in.
3) As soon as your phone is booted up, access the "find devices" function for adding your HS820.
4) Hold the HS820 button down until the blue light is solid.
5) Then do whatever your phone requres to "search for devices."
6) Here's the key: as the phone is searching for devices, PHYSICALLY TOUCH touch the HS820 to the phone.
I couldn't get my HS820 to synch with my new Blackberry Curve the normal way and ultimately got it to synch by going through this process.
Sep 11, 2007 | Motorola Mobility HS820 Consumer Headset
Samsung e900 pairing
if you press the power button and hold until the blue light stays on the set is then in find mode, at this point use your phone to search for new devices and when it finds it it will see the HS820 and probably ask for a pin number this is 0000, when they are paired the blue light will flash and then flash intermitently from then on.
May 26, 2007 | Motorola Mobility HS820 Consumer Headset
Headset will not pair up eith razr phone.
Have you pressed and held the button on headset until light is always on, as this is in pairing mode, then search devices with your phone.
Jan 15, 2007 | Motorola Mobility HS820 Consumer Headset
Motorola Mobility HS820 Consumer Headset Logo
339 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis Webber
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
