Question about Teledyne Laars Pool & Spa
BLUE PRINT FOR A TELEDYNE LAARS MODEL NO ESC250P
I took all the burners out and got all dust and rust and re aligned the burners and made sher that the ignitor was working. it was. so it wont stay lit. I even ignighted it my self (I know thats a no no). it lit but the flames were not shooting out with power. each nozzle had a little weak flame comming out. so can you help me
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Teledyne Laars Master
  • 1,448 Answers
Check gas pressure if ok check gas pressure on gas valve might have to adjust gas valve if new at this call a professional
Posted on Nov 06, 2014
3 Suggested Answers
  • 990 Answers
SOURCE: teledyne laars natural gas model 125...
Two things, One you may have a low gas presure problem causing a bulid up of soot on your pilot, this will be a small ball of soot on your pilot and can be seen with a light and a mirror. when you hit the heater you cause it to move and the burner will start. If you just reach in with a screwdriver or something and clearit it should start but you should have your pressure checked and have the problem fixed or down the road it will cause other problems. Or if you live in the right (or wrong) aera of the country you could have spider webs in your gas orfaces and these can be cleared with a bent wire inserted into the orfaces. This is a problem that will reoccur as these are hard to control. Try these and see if they help and let me know how you do. good luck.
Posted on Nov 07, 2009
  • 3 Answers
SOURCE: Teledyne Laars LD250 Propane Pool heater cycles on and back off
Do you replace the thermopile or check the milivolts?
Check the Pressure gas
You need replace all of them terminals and check again the milivolts at the gas valve
Posted on May 29, 2010
I have a goodman gmpn 100-4 furnace that gives off a puff of flame when it lights
remove burners and dump out rust and dust then put burners back in and restart gas preassure in burners blocking burner ports with rust and dust
Jan 04, 2013 | Goodman GMS90703BXA Heater
Lighting device will not stop clicking
I am not sure if you are talking about when the burners are on or off so I will address both
If burner is off:
If it is continuing to click and the stove is turned off, this can happen if you recently cleaned it, the switches can get moisture in them and once they dry out it works fine again. If it is dry and clicking when off then you need to have the switches replaced.
If burners are on and still clicking, it is due most of the time to the ignitor probe or burner caps are not aligned. Rust or spills can also cause this. Clean really good around the burner holes where the spark takes place
May 23, 2010 | Stoves Ovens
Pilot stays lite but the burner wont ignite propane unit
the gas is not coming out of the burner, probably due to rust clogging the holes.
Dec 04, 2009 | Water Heaters
H400 WILL NOT LIGHT FAN WORKS
If your ignitor is getting white hot it is hot enough if it just get's red hot it may be low voltage. If this is not the problem than it has to be something keeping the gas from getting to the ignitor. If the ignitor is steaming then you may have a deeper problem with sweat on the exchanger wich may mean a venting problem. But the end result of this would be rusted or burnt burners and you will need to pull them and check to make sure they are letting gas flow correctly. Good luck.
Jun 25, 2009 | Hayward H Series Pool & Spa Heater 400k...
Gas oven wont stay on
If this is electronic ignition, then chances are the burner or ignitor nub has residue on them, preventing the flame detection system from keeping the gas on.
Use warm soapy water and a plastic scrub brush to thoroughly clean the burner cap, burner base, and ignitor nub.
Jan 25, 2009 | Whirlpool GS475LEKS Gas Kitchen Range
GE gas dryer, no heat, new ignitor
Hi!! make sure that you have 120 volts going to the glow ignitor.the gas valve will not turn on the gas if the ignitoe wont glow..if it glows the check yout coil boosters they are round and are located by the gas valve.then if not you have a bad timer.they are usually round and are black..good luck..
Jan 03, 2009 | Dryers
Electric ignition
I want to know more about your business I repair restaurant commercial equiptment please respond maybe I can help
Sep 08, 2008 | DCS RGS-305 Professional Gas Kitchen Range
Problem with getting burner to light.
All my ignitors spark when I turn one of them on. I'v been told it is normal. I had a problem before and the tech that replace the ignitor said the issues is with alignment. Try to rotate the burner a bit left or right and see if it fixes it.
Aug 26, 2008 | Jenn-Air JGS8850BDS Stainless steel Gas...
Maytag gas dryer wont stay hot
Check the exhaust to see if it is clogged. If not, you may need a pair of gas valve coils (not very hard.)
Replace the coils if you see the ignitor glow and shut off, without the gas valve opening up.
Mar 09, 2008 | Kenmore 63942 Dryer
Pool & Spa Logo
74 people viewed this question
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
