Question about Bissell Vacuums
Bissell PowerForce compact: the brush doesn't spin, locks in place (it's not the belt!)
The belt side of the brush fits into a groove that doesn't allow it to spin. I never noticed because it has worked great until recently. I thought it was the belt but it won't even spin by hand when in place????
  • 97 Answers
SOURCE: brush not moving in Bissell pro-heat
if the belt is more then 6 months old or more, then the belt will have to be replaced reguardless of the way it lookes. belts can stretch over time and when you put the machine on the carpet the friction causes the brush to stop because the belt has stretched. i would try this first. hope this helps
Posted on Aug 02, 2009
BissellCSR
  • 276 Answers
SOURCE: I have a Bissell pet hair eraser model #3920. It's
- Remove the access panel, which is on the bottom of the machine. There are 4 tabs to lift on the access panel to remove. Start with tab 1 then 2-4 tabs.
- Check the brush, and belt for any damage. Clean off any debris on the brush.
-The belt may not be broken but may show signs of wear. If belt is broken or shows signs of wear, replace belt.
Posted on Aug 04, 2010
  • 377 Answers
SOURCE: i have a bissell momentum
Most likely your brush needs to be removed and cleaned. Clean all debris that might be in the bristles of the brush. You will see a holder for the brush on each end that holds it into the frame of the vacuum. The two holders should turn freely. If they do not, spray a bit of WD40 between the brush and the holders and rotate the holders around the brush. Doing this will clear up the most common occurring cause of the problem you are facing.
Good luck and feel free to contact me if you find this does not solve your problem.
Paul
Posted on Sep 18, 2010
SOURCE: We are trying to replace
Remove the beater brush assy & remove the
shaft & brgs that go through it 7 clean out the
hair,fuss ect,so it will turn
You need to take your vacuum apart once a year or more
to clean things so they continue to work
Posted on May 22, 2011
  • 88 Answers
SOURCE: i have a bissell powerforce
Make sure all the pulleys the belt attaches to are spinning properly, if one is stuck or not spinning fast enough that will easily generate enough friction to melt the belt each time you replace it. Might need to replace other parts, or clean out more than just the brushes.
Posted on Jun 15, 2011
Testimonial: "thank you! will give it a shot and see what happens."
Height Adjustment on Hoover Wind Tunnel doesn't seem to do the job.
You changed the belt that drives the brushroll, it is a flat stretch belt. The V belt also should be replaced every year or two max. It will not be stretched out like the flat belt but with normal use the side of the v will of wear off and the belt will be a little thinner which can cause it to slip on the pulley. The V belt drives the transmission. The flat belt goes from the transmission to drive the brushroll. The burning smell could come from the V belt if it's slipping real bad.
Mar 15, 2017 | Vacuums
Brush won't spin when carpet cleaner is running
see this causes and fix it. God bless you
If the vacuum cleaner brush is not spinning, the brushroll bearing might be jammed. Try removing the brushroll assembly and cleaning all hair, string, lint, etc. from the brushroll bearing. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning, the brushroll assembly itself might be jammed. Try removing the brushroll assembly and cleaning all hair, string, lint, etc. from the brushroll bearings. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning, the brushroll itself might be jammed. Try removing the brushroll and cleaning all hair, string, lint, etc. from the brushroll bearings. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning the cogged belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
If the vacuum cleaner brush is not spinning the drive belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
If the vacuum cleaner brush is not spinning the belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
Sep 27, 2012 | Vacuums
The belt on my oreck XL 3600 is slipping. I replaced it with the one that came with the vacuum. It smells bad when we use it and the brush sometime doesn't spin.
Usually the belt that's stored in the groove on the bottom of the body is the correct one for the unit, and doesn't require much stretching to get it into the channel. If yours was in a bag of some sort then all bets are off.
I'll start as though you were installing one you had just bought from a dealer. Remove the bottom plate so that you can get to the motor and brush roll housing. This can usually be achieved by lay the unit out flat either on a table or the floor. With your NEW belt in hand, remove any pieces of the old belt and discard them. Remove the brush roll from it's housing and install the new belt over the drive end of the motor. Pull the opposite end up and over the drive portion of the brush roll. Now you'll have to maneuver the bearing shrouds into their respective support areas, usually by levering the drive end up and over the right end and then the idler end. Once done, rotate the brushroll by hand to make sure the belt is in the correct place. Replace the bottom plate, install the screws and you should be ready to vac.
Jul 14, 2011 | Oreck XL Ultra Bagged Upright Vacuum
Brush/beater bar not turning
The belt maybe broken.Turn the machine over and remove the screws that hold the plastic plate on.the bar will now lift up and out.Make sure to notice how it is in.The belt fits in a groove on the brush and the other end fits on a small wheel or rod ,about six inches back from the groove on the brush.
Jul 08, 2011 | Kenmore Progressive Bagless Upright with...
The beater bar on my Kenmore Progressive stopped turning. I tried to clean the hair out of it, then switched it back on. The bar still wasn't turning and then it started to smoke..... lots of smoke,...
The belt is broken.First while looking at the brushes,find the screws that hold that bottom plate on.Remove the screws and the plate comes off.This will allow you to lift the brush out of the vacuum.It is important to make note of how the brush fits in the vacuum.The new belt will fit on a groove on the brush.The other end fits on a small wheel about six inches back from the brush.
Thank you for using Fix Ya.
Jun 03, 2011 | Kenmore 27514 Bagged Canister Vacuum
The beater motor will not turn. Is there a fuse? I've tried the reset, but this still doen't work. My wife smelled a burning smell and quit using.
Sounds like you need a new belt.Turn it upside down and locate the screws on the bottom.Remove those screws,and then the plate they hold on(if there are no screws then the plate will be held by clips just pull it off,carefully.The brush now may be lifted out,but before you do.The belt fits around the brush.Find which side,if the belt is broken and still in the vacuum,it should still be on the side it came from.If the belt is not still in the vacuum,there is a groove in the brush about one inch wide.That is where the belt fits.The other end of the belt fits on a small wheel about 4-5 inches back from the brush.There may be a small plate over the belt and wheel if so just remove it and you will see what I am talking about.
May 17, 2011 | Eureka Capture Upright Vacuum Vacuum
I have a problem with my model 6585-3 bissell upright powerforce bagless turbo with turbo brush vacuum The brush has quit spinning upon removal i noticed that one side of the brush was free to spin the...
Hair and dust build up under the end caps of the brush roll and cause friction. Replace the brush roll and belt. Be sure to clean the brush roll frequently after use.
Jun 24, 2017 | Vacuums
Hoover WindTunnel Self-Propelled V Belt
when you released the end to slide the new belt on it allows the tension roller to slide into the wrong position. Remove the top so that you can see the roller, at the left side of the roller mechanism there is a screw, loosen it enough to allow the roller to return to the correct position.
good luck
Mar 23, 2009 | Hoover U6441-940 WindTunnel Bagged Upright...
How to clean the power brush on the miele vacuum. Is the brush removable? If so how do you remove it?
Greetings from GoVacuum.com,
Miele canisters have 2 different types of power brushes. The first, and most popular is the Miele SEB 217, and 213 Power heads. To remove the brush, follow these instructions.
On the bottom of the power head there are 2 yellow (older models it is black) plastic screws. You can remove these screws with a phillips head, or flat head screw driver. Simply unscrew these two screws. You do NOT have to remove these screws, just unscrew them to where they are loose enough to remove the bottom plate.
Once you have unscrewed the plastic screws, simply pull the bottom plate up and off of the power brush. You will notice the belt on the left hand side of the brush. Simply pull the brush up, and un hook the belt from the brush;
Now that you have unhooked the brush from the belt, you may thoroughly clean the brush, and un wrap any hair or thread that is wrapped around the brush. You will notice on the roller brush itself there are two indentions on both sides of the brush that run the entire length of the brush. You can take a knife or scissors and run them down the brush on both indentions, which will help you remove the stubborn debris wrapped around them.
Also you'll notice on both sides of the brush that there is a yellow bearing cap on both sides of the brush. You may pull these bearing caps off, and remove any debris that is around these caps. You may also lubricate these bearings with grease or WD-40, to ensure the brushes spin fluently.
After you have cleaned the brushes and bearings, insert the brush roller back through the belt, and into the power brush. You'll notice that the bearing cap will have two sides. One side of the bearing cap has 1 groove in it, the other side has 2 grooves.
When you reinsert the brush back into the power brush, you may lower the roller brushes if the machine has been used a lot. If the roller brush is older, you will want to re insert the brush with the side that has 2 grooves facing upwards, and the side with 1 groove in it, facing down. In the first picture above, you will see that the side with 1 groove is facing upwards and is visible to the camera. The side with 2 grooves is facing down. This is because this brush is new. If your brush is older, you will want to reverse that, and have the side with 2 grooves facing upwards. When the brush is back into the power head, simply put the bottom plate back on, (IMPORTANT! Make sure that in the front of the machine the bottom plate is completely hooked onto the front of the power brush, there should NOT be any space in the front) Once you have screwed the plastic screws back into the power brush, in the front of the power head, push the bottom plate upwards to make sure there it is fastened tightly in the front.
I hope this helps you. If you have the larger, less popular SEB236 power brush, just send me an email, I'd be happy to walk you through cleaning the brush on this one also. If you have any questions about this repair, please feel free to email with any questions, I really enjoy sharing my knowledge, and passion fixing vacuum cleaners.
Chris Jones
GoVacuum.com
chris.jones@govacuum.com
Sep 29, 2008 | Miele Vacuums
Roller brush won't spin (bissel 6390/3910 series)
I just fixed mine. It took me all of 10 minutes. Pull the brush out. Stand the brush on end on the edge of your study work bench/table top. while holding the brush vertical( on end) take a small phillips screwdriver and tap using a hammer on the metal pin you see in the middle of the brush. Keep tamping and the whole assembly will come apart. What you will have then is a long metal shaft, 2 bearings(they are acutally skateboard wheel bearings same number same make). Clean the gobbed up hair with a razor blade and then reassemble by tapping back together. The bearing wont be worn out because they are way too tough for a vaccum. We used ride down hills on them! a ten minute fix wow and you wont have to drive to vacuum shop and spend $$ and time
Dec 31, 2007 | Bissell 3594 CleanView PowerTrak Bagless...
Vacuums Logo
425 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
