Question about Vacuums
Manual for kenmore progresive cannister vacuum #116.28614801
reddevil6
  • 1673 Answers
SOURCE: Kenmore Progressive Motor is not working.
Could be a number of things, cord may be bad as well as a problem with the motor. There also is a fuse that could have blown. If you go to sears.com, click on parts, put in your model number, when the page loads, click on the first link and you will have a parts list, and scroll down there will be a parts break-down picture that you can look at. You can also order parts thru the Sears website.
Posted on Feb 28, 2008
Agent Don
  • 310 Answers
SOURCE: Kenmore Cannister Vacuum Model 26312
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=109396&thid=552260
Kenmore Canister Vacuum Model 26312
Posted by Alecia Rojas on Apr 28, 2008
Kenmore 23612 Progressive PowerMate Canister Vacuum
Vacuum is not sucking. It is just over a year old.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
It sounds like you have a clogged hose or a full bag, or dirty filter. The best way to check your electric hose id to run a marble or steel ball thru the hose and if it goes thru all the way then check the bag and filter, most times it is the vacuum hose. If it id the hose you can try to pull apart the clog from both ends using another central or canister vacuum. If not and the ball stops mid way thru the hose then you can use a broom handle with a round hook on the end so that it does not puncture the hose is any place and the round hook can loosen or break up your clog and then your suction will return, if you poke a hole in the vacuum hose there are repair kits that go on the outside of the hose that will slide over the hose and then you use a heat gun and shrink the hose repair kit down to size therefore plugging the leak. (Hose repair kit). So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.sears.com/shc/s/home_10153_12605
National Customer Relations 1-800-549-4505
Home Services & Repairs 1-800-4-MY-HOME
1-800-469-4663
Parts Orders & Inquires 1-800-366-PART
1-800-366-7278
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Posted on Apr 28, 2008
advacak
  • 125 Answers
SOURCE: Kenmore Progressivecannister vacuum
order from sears
Posted on Dec 30, 2008
odiebugs
  • 949 Answers
SOURCE: how do I open the Sharkplus canister vacuum? I have no manual.
Where the hose plugs into the canister,just above it should be a button that you push in to lift the top back. You did not put what the model # was,so its not easy to find things without the model #.
Below is the manual for model# ep3005t, but once your at the site you can get the right one.
The manual is a pdf file, most all are,so you need adobe reader to view the manual,also I am putting the link for the reader,it is free. Ifyou click on the links I post and it does not take you too the site just
copy the link and put it in your browser.Hope this helped you.
http://www.sharkvac.com/productDetails.aspx?ProdID=0xbTZnOD3Iw%3d
http://get.adobe.com/reader/
Adobe reader should work on xp and vista.
Posted on Mar 24, 2009
  • 9 Answers
SOURCE: Kenmore 34723 Grab-N-Go Upright cannot re-attach dust cannister
make sure the top of the dust cup is properly installed and for kenmore parts go to www.searspartsdirect.com and inter the modle #
Posted on May 22, 2009
Kenmore cannister vacuum model 116.2411290 has begun exhausting a 'burned' smell. Suspect bad blower bearing. How to access?(Can't find manual online.)
Hi,how are you so sure the problem is from the blower bearing and not the belt,well to know if the problem is from the blower bearing or the belt you have to know how to access your vacuum first,so from all angle you need the manual You can download the manual of your kenmore cannister vacuum from this website;www.manualsonline.com.I found it there Thanks and take care
Apr 01, 2010 | Kenmore Vacuums
I need the owners manual for kenmore cannister 24212
If you type in the model number on your searchbar, the website will be listed "after" all the sponored sites. Use the site that has YOUR manufacturers name in the url. Under the "support" section choose manuals and especially the term pdf. Thank you, Dana
Feb 13, 2010 | Kenmore 24212 Whispertone Bagged Canister...
Kenmore cannister style. Cannot remove the
It depends on the model you have. Do you know the model number? If you need a replacement belt you can get one here:
http://www.vacbelts.com/kenmore.htm
Oct 25, 2009 | Kenmore Vacuums
May 22, 2009 | Kenmore 34723 Grab-N-Go Upright Vacuum
Vacuum won't come on
The switch in the hose maybe bad, motor problem, or some of these cannisters have a relay mounted by the motor, it may be bad.
Mar 16, 2008 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore vacuum manuals
I tried what reddevil6 suggested and was not able to get Sears to produce a manual. I would prefer an online manual but at this point I'm desperate enough to try anything.
Dec 10, 2007 | Vacuums
Kenmore Bagless Issue
after cleaning the filter,replace the bag.But this time before you close the lid,make sure you remove the hose.after the lid is closed then put the hose back on.
leaving the hose connected to the lid after closing will create a gap between the bag holder and the bag.so just remove the hose first before changing the bag
Jun 16, 2007 | Kenmore 23313 Whispertone Bagged Canister...
Vacuums Logo
67 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
