Related Tags:
This problem should be removed because:
Problem with KitchenAid 24 in. KUDI01TJ - Multiple Color Built-in Dishwasher
noisy kitchenaid dishwasher during filling
how do i change water inlet value. also, how do i clean the water inlet opening on side wall
Solutions (1)
Best Solution
Fill valve replacement should be fairly simple. Most dishwashers are constructed in a similar manner, so although these steps are generic, it should lead you in the right direction:
1. Remove the lower kick panel right below the dishwasher door. The fill valve should be located in the front of the dishwasher on the left hand side.
2. Turn off the water supply line.
3. Turn off the circuit breaker to the dishwasher or unplug the unit as necessary to secure power.
4. Carefully remove the two wire connectors going to the fill valve solenoid. These wires are delicate, so be careful with them.
5. Leave the fill valve attached to the mounting plate in order to loosen the supply line. Once you have the supply line loosened you can remove the valve from the mounting plate by removing either one or two screws.
6. With the supply line disconnected, wires removed and the valve removed from the mounting plate, you can now remove the secondary water line that goes into the wash tub. It is usually behind the valve and easier to access if you can pull the valve out far enough the reach it.
7. Make sure you put teflon on all your threads BEFORE you re-install.
8. Installation is in the reverse of what I just explained to you. You should not have to remove the dishwasher from under the counter, but you can if it makes access easier.
It's that easy. Just make sure you check your water lines for leaks BEFORE re-installing the kick plate. And, make sure you reconnect the wires properly. Good luck. I hope this helps you.
dishwasher repair
Dishes weren't gettting clean. Replaced fill value. Cleaned side water inlet. Removed lower spray arm to check screen and impellar. ...
smeg dishwasher intermittenty opens and shuts off...
this causes the pipe line to bang in the walls of the house, most annoying at night, also items are clean when cycle finishes but are never...
18 yr old kenmore electronic
18 yr old kenmore electronic dishwasher has stopped filling at same time as aerators on faucets filled up with sand and gel particles. Is...
Please explain what the No
Please explain what the No E17 refers to. I have taken the side off and can see that the water is draining ok but as it starts to refill it...
Add Your Solution
I have a Kitchenaid Superba KUDs230y and it has...
I have a Kitchenaid Superba KUDs230y and it has intermittently reset itself after a wash cycle. Now the Energy Save Dry...
how can I clean my washer, It has rust and smells
how can I clean my washer, It has rust and smells a bit can I use bleach/
See all KitchenAid 24 in. KUDI01TJ - Multiple Color Problems
Fix-O-Meter
345
345 people viewed this problem
- 0 people are following this problem. Be the first!
Top KitchenAid Dishwasher Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
If you're talking about the inlet on the side of the dishwasher case, you need to remove the hose, first. Then, look inside with a flashlight (if you can) to see if you have any sediment build up. If this inlet gets clogged the dishwasher will leak. I personally had to use a small screwdriver to fish around in the inlet opening to break a chunk of hard water mineral deposits. Something you may try. This inlet is not removable and if damaged, the whole tub generally has to be replaced. A lot of work for one small problem.
You could have a clog in the main wash pump. This is a common symptom. The tub should fill with water to just below the heating element. The main wash pump will then take over and distribute water through the spray arm(s). If the wash pump is restricted in any way, you won't get enough pressure through the spray arm(s), which in turn, will not dissolve detergent, and will not get your dishes clean. If the tub is filling to the proper level, I would suspect you have a clog somewhere. You will need to remove the lower spray arm and the coarse strainer to get to the impeller area of the wash pump. Check for any obstructions. Let me know if this helps.
I thought the strainer had 4 screws, but I could be wrong. The strainer SHOULD just lift out exposing the impeller port to the main wash pump. Sometimes the strainer has to twist off. It's hard for me to tell just by the model number. Once you get to the impeller area, there may be an additional cover that you need to remove to get to the impeller. This usually has one or two screws holding it in as well. Let me know if you are successful.
View More Comments
