Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Pull-cord will not retract.
Brand new 18" poulan chuckless chainsaw. Used 2 times & pull-cord will not retract. I remove the cover, rewind the cord, re-attach cover & pull to start. Over & over. Finally will start, however, the cord is dangling out in the wind as I attempt to use the saw. Not Safe. Curious as if there is a method of up-grade for this mechanism?
Best Regards.
  • 1 more comment
  • jerry_jarvis Jan 24, 2009
    Cord will NOT Retract...cord does not get stuck.
  • dspear99ca Jan 26, 2009
    I've got the same problem on a Husky chainsaw. I took the whole pull cord mechanism apart, and for the life of me didn't really see how it works in the first place. Okay, yes, I understand the coil spring, but most other models I've worked on had some sort of "tab" thing on the rotating plastic piece that either hooks into the loop at the end of the spring or otherwise interacts with the spring.... on this one there doesn't appear to be anything. So, after managing to coil the spring back into place I put it all back together. Now the weird part. It worked fine after that. In my backyard of course. I started the saw several times, and this is a big saw that requires quite a few pulls to get it started. This weekend i took it out in the bush to get some firewood and... you guessed it... one pull and it wouldn't go back in. I've heard that sometimes these recoil mechanisms look fine but aren't. I'm not sure which parts I need to replace, I'm off to the local dealer today and see if they can enlighten me. Why is it that chainsaws always start in the backyard when you don't need them?
  • Anonymous Apr 28, 2009
    I have the same problem with my 18" Poulan Chain Saw the rewinder will not release after being pulled. Greg
  • 3 Answers
Pull the cord cover off the top of engine,check to see if there are any cracks in the plastic cover ,cord coil,or any trash that may have gotten stuck.Most of the companies are using plastic parts that have a tendency to break or crack, this can cause the cord/rope to get stuck.
Posted on Mar 26, 2015
I had the same problem and solved it with some lubricant. The screw on the pulley over tightens when you pull the cord and does not release the pulley. Add some oil to the center of the pulley and it should prevent the screw from tightening.
Posted on May 15, 2009
    President:
  • 2,692 Answers
If you put a longer cord on it , then it will not retract as far and get stuck.
Posted on Jan 24, 2009
  • Thomas F. Schneider Jan 24, 2009
    It is stuck in the out position right now. It does not retract. Stuck.
Poulan Pro PP5020AV pull cord won't retract
You need to wind the spring back in a coil at a time, it is not easy if you have never done one, order a new spring, this will come pre wound in a cassette and is an easy fit.
Nov 22, 2012 | Poulan Pro Chain Saw 46cc 20"
How do i replace pull string on craftsman 20/14 chainsaw
Remove the cover containing the cord rewind mechanism, untie the cord's knot in the center of the mechanism and remove the old cord by unwinding it from the pulley. Thread the new cord through the hole it goes through on the outside and wind the recoil mechanism so that it has sufficient spring tension to rewind the new cord. Use something appropriate to immobilize the pulley while you thread the cord through the center and tie the knot. Slowly allow the pulley to retract and wind the new cord onto it. Replace the cover. As an aside, sometimes when the cord breaks and the pulley snaps back quickly, the rewind spring can break.
Jun 24, 2011 | Garden
My pull start cord won't retract. How do I fix it
Remove the starter assembly from the engine and pull the cord out--it should have spring resistance to pulling. If nothing, the rewind spring may be broken, or it may have pulled loose from one of the attachment points. Remove the cord from the pull handle and unwind it from the spool if it isn't already pulled out. Remove the spool from the frame to expose the spring--check the ends for breakage and the attachment points for damage (one will be on the under side of the spool). Repair or replace any damaged components and assemble the spring into the attachments. Wind the spool/spring about 2-turns CW, then wedge it to prevent unwinding. Fit the cord back into the spool and wind it CW until the cord has about 8" or so to feed out through the cord port. Fit the cord end back into the handle, tie an overhand knot, and push the knot into the handle bore. Remove the spool wedge and try pulling the cord several times to make sure it goes out and back smoothly. Return the starter to the engine and attempt starting. Hope this helps!
Nov 08, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
The rope does not retract when the cord is pulle... how do I fix it
Has the cord been replaced? If so, when the old one broke, the spring will completely unwind. The trick is to rewind the spring first, attach the new cord and wind it around the spool while holding the spring tension. After the cord is wound, feed the end out through the cord port and test for good return (don't let go!!), then clamp the cord with locking pliers and affix the handle to the cord. Melting the cord ends helps keep the knots from pulling out. Hope this helps!
Jun 07, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Jammed pull cord on Poulan P4018 chainsaw!
There maybe a split pin holding the cover down over the spindle! Not too sure, but possible. Could be pushed down the centre, just a case of having a good look. Only really worked with Hurqvarna's and Makita's. Hope it helps. Good Luck
RICH
Dec 16, 2009 | Poulan Wild Thing 18" 40cc Gas Chainsaw -...
Starter rope will not retract.
inside the rope pull housing is a flat spring,it may have come loose from its anchor, its an easy fix...unscrew the 3 screws on housing, lift off housing, and the rope pull is inside the casing, you will then see if its broken, or just come off anchor, 10 minute job if its just loose......
Jul 21, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Recoil spring on homelite chain saw doesn't retract pull rope
Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
Jul 04, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Having hard time with new poulon 18" chainsaw starting.
Since you have good spark and good gas the only things left to check are the air filter and the carbeurator. If the air filter is dirty, replace it. While you are at the auto parts store also pick up a can of a gasoline additive called seafoam which will keep your carb. clean. Finally get a can of spray carb. cleaner and put a couple short squirts directly into the air intake which is right there when you remove the air filter.
May 20, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Broken recoil spring
A new spring comes wound tight enough to be dropped into place in the starter housing (Easiest).
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so i tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension to retract properly.
If you're lucky you can pull the cord out enough for a pretension then slightly raise and add the withdrawn cord to the spool.
Both methods require about 2 turns of pretension to rewind the cord when pulled.
Lou
Mar 21, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing 18 Inch replace starter spring?
I invert and secure the starter housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension to retract properly.
Lou
Oct 09, 2008 | Poulan 1630 16" Chain Saw
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
1,375 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Dwain Pippen
Roland W VanLue
Roland W VanLue
Are you a Poulan Garden Expert? Answer questions, earn points and help others
