Question about HP CPQ175KB Keyboard
Spacebar - HP CPQ175KB Keyboard
  • 81 Answers
Well if the sapce bar on the key board is not working.... you can try to use the keyboard on another system & see if the same key works if it still dosen't work.. then go ahead & replace the key board of your system..
Posted on Jan 24, 2009
Fix spacebar
On a Desktop, just purchase a new kb for $16 or so. On a laptop, it's an involved process to replace the kb.
To get a space without a spacebar, try these two suggestions:
- Press Alt/32 (that's Alt with 3 2) then release the Alt key.
- Run OSK and click the spacebar.
The actual model number MIGHT get you a repair procedure in a Google or Youtube search for "repair spacebar".
Oct 28, 2013 | Computers & Internet
(Remington Streamliner) the space bar automatically tabs instead of moving one space forward. How do I fix this?
This can mean that the spacebar is not being tapped hard enough, the spacebar is sticky, the escapement is sticky, or the spacebar linkage needs adjusted. If the letters do not cause this, then the escapement being sticky is less of a concern. Sometimes the touch on the spacebar is right on the point where the escapement mechanism just barely escapes and doesn't lock in. First try tapping the spacebar more firmly to see if this helps.
Aug 14, 2013 | Office Equipment & Supplies
Why does the space bar only have a centre touch point
The reason for this happening is that the metal bar under your spacebar is not properly attached. It's time consuming to properly fix it, but it's an easy fix at that.
All you need to do is remove your spacebar and metal bar (shaped somewhat like a tall C, if held sideways). On the bottom of the spacebar will be approximately 2-3 small clips in which the metal bar will snap into. Once snapped into place, you will want to look at the area where the spacebar goes. There should be two small clips at each end. With the metal bar clipped into the spacebar, you want to place the "ends" of the metal bar under the clips on the keyboard and very carefully place the spacebar into the hole on the keyboard and snap it into place. Now test it out and it should work fine. If not, it's likely that the metal bar came out from under the keyboard clips. The annoying part is snapping the spacebar into place without having the metal piece come out from under those clips, so you may need to perform this task a few times.
Here's an example image...
Jul 22, 2013 | Asus Systems Asus X501A Notebook
The far right and left ends of the spacebar do not work. In order to use the spacebar function, the direct middle of the button has to be pushed down.
You need to reposition (clip) the torssion bar under the spacebar key (a steel wire formed in a wide U shape), it is unhooked, call for a professionnal if you'r not sure how to do this as you may brake the plastic hinge if you don't know what you'r dooing...
Aug 09, 2011 | Toshiba 310CDT Keyboard
I broke my spacebar off my laptop gateway computer! How do i fix this?
Of all the keys on the keyboard, replacing the SPACEBAR is probably the most difficult. The SPACEBAR is kept even by a metal wire that is inserted into slots on each leg of the plastic bar key. However, you have to get the wire into the slots without depressing the wire. If you push the wire down, you compress the wire and installation becomes impossible. As a general rule, do not remove the SPACEBAR unless absolutely necessary. If you remove the SPACEBAR, remove several surrounding key caps also. This will let you get some tools under the SPACEBAR wire later on. Once the SPACEBAR is reinserted, you can easily replace any of the other key caps.
Jan 19, 2011 | Gateway 2520915 Keyboard
Dell inspiron 6400 faulty spacebar?
You need to have the keyboard replaced. If you can't get it fixed locally, contact me for shipping information, I fix these kinds of problems a lot.
Jan 05, 2010 | Dell Inspiron 6400 Notebook
SPACEBAR WILL NOT SPACE
Inspect the spacebar paralell guide wire. When depressing the spacebar on the right or left side extreme the spacebar other side should travel down at the same time. If not the spacebar will not actuate the electronic keyswitch under the spacebar. Most likely, the keyswitch is defective and requires replacement.
Oct 12, 2009 | Olympia Mastertype 3 Typewriter
Spacebar not responding on Toshiba laptop Satellite
Since the spacebar is the most used key on the keyboard, it is likely a hardware failure of the spacebar itself. Replacement keyboards can be found on EBay and normally run about $20
Jul 05, 2009 | Toshiba Satellite M45-S331 Notebook
Spacebar/will/not/space
just take it it up the spacebar key with a pen or anything like a pen and clean inside of the keyboard which is the spacebar is placed and fix the spacebar again and type
Apr 23, 2008 | Computers & Internet
HP CPQ175KB Keyboard Logo
129 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
