Fuji FinePix A800 Digital Camera Logo
Posted on Jan 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
CAN I IMPORT PICTURES TO CAMERA FROM PC?
I WANT TO PUT THE PICTURES ON MY COMPUTER TO MY MEMORY CARD IN MY CAMERA. TO USE IN MY DIGITAL FRAME.
Anonymous
Level 3:
  • Master 903 Answers
  • Posted on Jan 24, 2009
Anonymous
Master
Level 3:
Answers
903
Questions
6
Helped
322749
Points
2524
The best thing to do is get a memory card apadpter for your pc, they are really cheap. Place the memory card into one end and then plug the other end into a usb port on your computer. Then all you will have to do is copy the images from your computer onto the memory card (found as removable storage in 'My Computer') then place the memory card into your digital frame.
How to copy pictures in digital frame internal memory
http://www.digitaltips.org/imaging/digit... ...
The following items about digital frames are from the link above where you may find additional information.
Memory
Another important feature to consider is how many images you can store on the frame. Most have slots for loading pictures directly from a camera's memory card. Make sure it accepts the same type or types of cards that your camera(s) do, as this will make transferring images to the frame significantly simpler. Also, look for a frame with a large internal (built-in) memory if you plan on loading lots of images for slide shows, videos and so forth.
Connectivity
With all the attention your digital frame will get from friends, family and members of your own household, you'll want to keep it updated with your most recent photos. Having multiple connectivity options can make this task a lot simpler. Most frames can connect to your PC using a ubiquitous USB cable, while Blue tooth and WiFi-enabled frames let you sync wirelessly from laptops, camera phones and cameras that are WiFi enabled. Many WiFi-enabled frames can automatically sync images from PCs on your home network or from photo sharing sites on the Internet, making it simple to keep updated.
If your computer has memory card slots, you can copy from the computer to a memory card.
If there are no memory card slots on your computer, purchase a Targus card reader at Walmart for $8.88 or another brand for less at Ritz/Wolf/Kit camera. Also, they do 3½ x 5" digital prints for 6¢ each on Tuesday and Wednesday.
CAUTION To prevent memory card corruption, keep batteries charged and don't delete. Wait for lights to stop flashing then turn camera off before removing memory. For card readers, double click Safely Remove Hardware. Select then click Stop and OK.
Have just been playing with this and found that it works really well, but you should first format the memory card in the camera because it adds files to the card you will need.
Next, take a picture of something with the camera.
Place the memory card in the card reader and go to My Computer.
Open the memory card and you should see a folder on the left (DCIM) that has your picture. Do not open the MISC folder on the right.
Double Click on the DCIM folder and you should see another folder (e.g.,100HPM417) which includes the name of your camera. Double Click on that folder and you should see the picture you just took.
When you copy from the computer to a memory card, that is the folder where your computer pictures must be copied. You may only be able to copy one picture at a time from My Computer.
One last thing, the file names of your pictures must not have any additional letters or those pictures will not be seen by the camera. Also, the file name format must match the file name of the picture you took e.g., HPIM1903. Rename files to the format of your camera photos.
If you have trouble with this, it may be easier to right click on Start and then left click Explore. Find and select the pictures you want to copy and then near the top left, click the X next to Folders to see a place to select Copy files. You can then select the memory card folder e.g.,100HPM417, that you clicked to see the picture you took and click Copy. You can copy pictures easier with this method.
Click this link for other camera tips and complete instructions on cleaning camera and battery electrical contacts. ...
http://www.google.com/base/a/4210404/D13...
Thanks.
Mar 11, 2011 • Cameras
2answers
Do not know how to transsfer pic fromcomputer to the Kodak pic frame
On one side of the frame there should be memory card slots and a usb slot.
two ways to do it, take the memory card from the camera and put it in the frame.
Or down load the camera to tyour computer and then with a usb cable upload the picture fram with the pictures you want
Or from your computer load a memory card and then stick it in the frame
My children gave me a digital photo frame for Christmas. I have a Nikon digital camera. I have downloaded and deleted from my camera several pictures I would like to put into my photo frame. Am I able to...
If the "camera chip" you refer to is a removable SD Memory Card you need to put that into a SD Card Slot on your computer or use an USB Card Reader device. The computer will recognize the SD Card as a Disk Drive and you can use Windows Explorer to transfer the picture files to it.
1helpful
2answers
I need instructions on how to load pics to my Optimus 07A08 digital frame.
On the back of the frame remove the memory card, then You need to use a pc with a Memory card reader, you can get usb card readers that simply plug in your usb, then copy all the pictures you want on the card from pc.
Transfer from computer to memory card
http://wwwuk.kodak.com/global/en/service/downloads/dln_ekn029310.jhtml?pq-path=3906/2308/2316
you haveto install driver from above link..and then try to transfer photos from camera to pc...
after that from pc you can transfer to photo frame...
Copying pictures from PC to the memory card.
When you connect your camera to the pc, via usb cable I presume, don't use the software that came with the camera, instead open the MY COMPUTER icon on the desktop, or in the windows START BUTTON. Your camera should in fact be recognized and appear as a new disk drive with its own drive letter or name.
If that happens, open the new drive window, and you should be able to see the folders that your camera uses to store pictures taken with it. It may depend on the picture frame requirements, but seems to me that you can now just drag and drop, cut, copy and paste any pictures you want right to the memory card drive, and I would not put them in any folder created by the camera, just on the memory card itself.
The other alternative is to purchase a memory card reader/writer for your type of card. They usually accept every card out there, and now you would be able to use that device to copy to and from the memory card without the need for a pc.
Hope that helps.
How do I load my photos on a pandigital picture frame?
I could not load my directly directly from PC. I had to put them on my camera memory card, then insert memory card into frame. worked well but took more time.
Was given digital picture frame . have no cd manual. haS 22 PICTURES ON IT .CAN I PUT MORE? MODEL NO. 7FF1
It depends on how big the existing pictures are. It has a 14MB internal memory, but it says about 12MB for storage. You can buy memory card to insert into the frame but it will not display internal memory once you insert a new memory card. If you bought a 512MB card, you could put hundreds to thousands of pictures in JPG format. You can hook the frame to your computer or directly to a digital camera. From the computer it takes a few seconds to convert the pictures. The frame will show up on your PC as a mass storage device and you will be able to delete photos as well.
I hope this helps
2answers
Memory Card
Format the card in the Camera- read your manual
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
