Question about Brother HL 1030 Laser Printer
Printing black smudges across the page at 10 cm intervals
The printer prints smudges, ca 5 cm apart horizontally and 10cm vertically. Varies, when I clean everything, the green roller, gently, and with the wire maybe one page prints clean, then the smudges return. Replaced the toner cartridge today but problems remain the same. Any suggestions much appreciated
  • 43 Answers
Most likely cause by the drum unit. Replace drum or upgrade printer.
Posted on Jan 24, 2009
Smudged horizontal lines
Try cleaning your rollers, it worked for me. I hope this helps.
Feb 13, 2013 | Canon Pixma MX410 All-In-One Printer
I have just collected a second hand HP 1600 printer and there is a 2cm green vertical line down the left side of the page and a 3mm line down the centre and 2 thin lines down the right side, help!
Dots, Lines and smudges on the printouts are due to deteriorating cartridges and cleaning the green drum of the cartridge may help temporarily. Take out the cartridge and gently clean the roller/ green drum with a dry, soft, lint-free cloth wiping off the toner dots marks/ lines. (corresponding to the location where you are having a green line on the paper)
Also, make sure that the visible inside of the printer and the Black belt are clean and there is no spilled toner inside, which sometimes results in dots.
Moreover, streaks (thicker lines) and dots etc indicate faulty PCR Roller which is located behind the green drum inside the cartridge. Replace the Cartridge or get the PCR Roller changed by a professional.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 16, 2011 | HP LaserJet 1600 Printer
I have an Samsung ML-2851ND printer and it is printing grey patches vertically down the pages behind the text. What is causing this and how can it be resolved?
Dots, Lines and smudges on the printouts are due to dirty/ deteriorating cartridge and cleaning the green drum of the cartridge may help temporarily. Open the front cover and take out the cartridge and gently clean the roller/ green drum with a dry, soft, lint-free cloth wiping off the toner dots marks/ lines.
Also, make sure that the visible inside of the printer is clean and ther is no spilled toner inside, which sometimes results in dots.
Try to rotate the drum to clean its whole face. You may have to repeat cleaning more than once.
Let me know if any further clarification/ assistance is required.
Dont forget to appreciate the solution and to convey your feedback
CreativeTECH
Jan 24, 2011 | Samsung ML-2851ND Laser Printer
Hi, my HP2600N colour laser jet leaves two 1cm wide coloured smudge lines length ways on all my A4 prints. The printer is getting to about 2 years old now so i'm fearing that some major part needs...
Also, make sure that the visible inside of the printer is clean and there is no spilled toner inside, which sometimes results in dots.
Rest assure that the printer is fine and needs no major replacement.
Don't forget to convey your feedback
CreativeTECH
Jan 22, 2011 | HP Color LaserJet 2600n Printer
When i print it is having a smudges lines in the letter black only .how 2 solve it?
Lines and smudges on the printouts are due to deteriorating cartridges and cleaning the green drum of the cartridge may help temporarily. Take out the cartridge and gently clean the roller/ green drum with a dry, soft, lint-free cloth wiping off the toner marks/ lines.
Also, make sure that the visible inside of the printer is clean and ther is no spilled toner inside.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 08, 2010 | Office Equipment & Supplies
Printed sheets come out with blackish/greyish lines on the right side
Use follow these cleaning steps for your printer:
1. Open the front cover of the printer and remove the drum/toner unit.
2. Gently wipe the scanner window with a soft dry cloth. The scanner
window is located on the roof of the inside of the printer.
3. On the top of the drum unit, locate the blue tab on the left side.
Slide it back and forth across the drum about 30 times.
4. Remove the toner cartridge (TN430 or TN460) from the drum unit
(DR400). To remove the toner from the drum: hold down the blue lever on the right side of the drum (DR400) and lift the toner (TN430 or TN460) off of the drum unit.
5. Inside the drum unit (DR400) there is a green roller. Wipe the green
drum roller with a dry tissue (i.e. Kleenex). You may turn this roller
by moving the gears on the far left side.
6. If the pages area gray pages or have gray vertical lines, install a
brand new toner cartridge. If pages have dots, spots, smudges or
horizontal lines, install a brand new drum unit.
OR
If you are still experiencing gray pages or gray vertical lines,
please install a brand new toner cartridge (TN430 or TN460).
Brother strongly recommends that customers do not use generic drum unitsand/or toner cartridges, or refill their Brother toner cartridge. Each Brother laser printer is designed to work at pre-set temperatures that are matched exactly to each of our individual toner formulations. Each individual component is designed to work with the other to ensure quality and reliability. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability.
The Brotherlimited warranty does not apply to any problem that is caused by the useof unauthorized third party drum units, toner cartridges or toner.
If I have helped please rate my post...I will always do my best to help
Sep 11, 2009 | Brother HL 1230 Laser Printer
Canon Pixma MP130 printing lines through pictures etc
I'd say it's probably the printer driver. Uninstal and reinstal it or update it. Printer drivers are a comon cause of printing faults.
Aug 16, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Epson stylus photo 890 printer (5 years old)has
Do a cleaning several times. If that doesn't do it, then it is time to get a new printer. They are cheap enough and will be cheaper than bringing it to the repair shop.
Apr 22, 2009 | Epson Stylus CX9400 Photo Printer
VERTICAL PRINT LINES
Check the front paper exit rollers for fit and alignment also the paper deck guides close to the planten area, if the printer is dropping print vertically down one side of the page, this can be caused by debris or anything that lifts the caridge assy the slightest bit, also check the print head seating and ribbin cable for proper alignment
Apr 04, 2008 | Canon PIXMA iP3300 InkJet Photo Printer
Brother HL 1030 Laser Printer Logo
696 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
