Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
TV won't turn on. (Panasonic 1080i HDTV)
We have had the TV for 6 years - no problem. This morning when it was tried to turn on, it wouldn't. The power button is just sitting there with the power button blinking. I have already tried unplugging it and all.
  • 9 more comments
  • bms_12694 Jan 24, 2009
    It blinks 3 times, then pauses, and then blinks another three times, and so on.
    Our TV model is a pt-53wx53g.
    Alright. Thank you so much.
  • mwong2 Jan 26, 2009
    is PT-53WX52F the same kit?
  • rfreiner Mar 16, 2009
    red light blinks five times
  • hhmm1 Mar 28, 2009
    i have the same problem can i use the same kit on PT-47wx53 model
    i have the same problem can i use the same kit on the PT-47WX53 model.
  • nicoyadri Apr 01, 2009
    HI,
    I HAVE A PT-47WXC43G AND WHEN WE PLUG IT IN AND TURN ON THE POWER
    BUTTON IT CLICKS BUT THEN IT IMMEDIATELY TURNS OF AND THE POWER LIGHT BLINKS ON AND OFF THREE TIMES THEN PAUSES AMD SO ON WHEN YOU TRY TO
    TURN IT ON AGAIN IT WONT TURN ON SO WE HAVE TO UNPLUG IT AND DO IT ALL
    OVER AGAIN.
  • randy walters Apr 17, 2009
    exactly the same prob blinks three times and shuts off
  • cdeerhunter1 Apr 21, 2009
    model # pt53wx54j that when i turn it on the on button blinks 3 times pauses then blinks 3 more times...is pt53wx53 the same convergence repair kit if not what would be the repair kit to fix my television.....
  • ricachica May 01, 2009
    I have the same problem. Woke up this morning and pushed the power button and the tv turns on, then off and the power button blinks three times. What do I need to fix this?
  • Panasonic Master
  • 8,617 Answers
The power led blinking is an error code if you can reply to this same post and let me know the number of blinks I can assist you with what it means.
Posted on Jan 24, 2009
  • Sonny Berry
    Sonny Berry Jan 24, 2009
    Thats the error code for the convergence shutdown. Very easy repair. If your model number is the PT53W53 you can get the convergence repair kit whih contains both convegence ICs and all six feed resistors and the kit comes with free step y step instructions with detailed photos so you can do the repair yourself. Heres a link to the repair kit.
    http://servicemanuals.vstore.ca/product_...
  • Sonny Berry
    Yes thats the same kit that you would need the PT53WX53 and the PT53WX53G are the same
  • 25 Answers
It needs to be serviced . I have the same problem . Service guy will be here in 48 hours ,,,within 48 hours , Today is March 9 09
Posted on Mar 09, 2009
  • adam jackson
    adam jackson Mar 09, 2009
    I have a PT53WX54J is it the same kit for my TV. I'm having the same problem , won't turn on and has 3 blinks to the red power light.
    Problem Solver:
Randywal- Thanks for help (slinteriors) ordered convergence kit today will update on sucess. 4-22-09
Posted on Apr 22, 2009
2 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: TV won't turn on. (Panasonic 1080i HDTV)
thats the error for the convergence ICs You will need two STK392-110 Convergence ICs you can get replacements at the following link.
Do my panasonic hdtv 1080i need a converter box in order to work?
None of the newer style TV's need a converter box because all the tv channel tuners use a digital signal. The tv signal in the air is now digital when using a tv antenna.
Sep 13, 2015 | Panasonic Televison & Video
Why is my panasonic hdtv 1080i on off switch blinking red
thats usually an error code. How many times does the light blink?
Apr 02, 2013 | Panasonic PT-53WX53 53" Rear Projection...
Hi, I turned my computer and monitor off as I normally do last night and when I came downstairs this morning to turn my computer and monitor on, my monitor didn't turn on. I pressed the power button on...
You need your monitor repaired or replaced.
Unlike a computer, there is not much troubleshooting beyond making sure it is plugged into a live outlet and turned on which you did already.
Jul 19, 2011 | LG L194WT 19" LCD Monitor
My tv will not turn on i woke up this morning wanting to watch tv and it keeps making this funny noise everytime i try and turn it on I've had this tv for about 6 or 7 years what can i do? And usually when...
May be power supply failure and then maybe cold solder joints...a lot of sanyo's came in the shop that had bad solder joints...we would look for solder joints with a cracked looking ring around them , resolder them, and the set would usually work...you can try to remove the back to gain access to the underside of the board to see if this may be the case...otherwise, it may be a circuit malfunction
Jan 08, 2011 | Sanyo DS24424 24" TV
The power light is just blinking red on my panasonic 1080i hdtv. cant even switch it off using the power button. picture and sound come on for about a second when the tv is switched on after power cord...
The power light keeps flashing and the tv won't turn on. If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old.
Jan 01, 2011 | Panasonic PT-53WX53 53" Rear Projection...
How do i turn on an hdtv 1080i on?
You don't "turn on" 1080i, the TV receives a signal that is in that format and displays it. If the antenna or whatever you have is not giving a High Def input to TV, it can't display HD picture.
Dec 22, 2009 | Panasonic Televison & Video
I have a Panasonic HDTV 1080i 52inch TV that is 6 years old. When I turn it on, the green power light just blinks and there is no picture at all. Any advice?
Check the lamp. Detach the front cover, read the warning, unscrew the cover, look inside, undo the one and only screw you can find, and pull out the lamp module. (Without touching the lamp) have a look at the light. Can you see it smokey in colour, or is the filament broken? This is how the PT-50LC13-K that I found in the garbage behaved, and the lamp filament is toast. Just thought I'd share.
Oct 10, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Blury screen on panasonic 1080i hdtv
seeing double and a lot of green on my panisonic hdtv 1080i what do i need to replace?
Aug 23, 2009 | Panasonic Televison & Video
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
5,456 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
