Question about NAD C522 CD Player
Tray does not stay closed - NAD C522 CD Player
How do I get the tray to stay closed on my iLO DVDR04
This is normally caused by a small loading belt that has stretched and the tray can not complete the cycle to close the door properly thus causing it to open.
Apr 19, 2012 | iLO DVDR04
Close milk drawer message stays on at all times
Look inside the machine where the milk tray goes into. You will find plastic lever where the milk tray push in when you close the tray. Check the switch by pushing in with finger and see the message gone off?
**** a small plastic hose and saddle on the milk tray in a place where it touches the switch lever then close the tray which should contact the lever harder.
Jul 25, 2010 | Saeco Primea Cappuccino Touch Plus Coffee...
Xbox 360 disk tray willo not stay closed.
i dont know lol have it send in if your warranty is bad hit me up ill send you cash
Aug 14, 2009 | Microsoft Xbox 360 Console
Disc tray won't stay closed.
I fixed this by jerking the tray gently. Someone jammed my tray and it skipped a few gear teeth. It seemed like the machine couldn't pull it in far enough to reach its preset position. So I let it close and when it was almost closed, I gently jerked it out to skip the gear teeth back into alignment. It is kind of tricky because the motor will just reverse instead of skipping teeth (you'll hear the plastic clicking when it skips). Perhaps unplug it and slowly push it in manually then **** it back out softly. Just be gentle. Good luck.
May 16, 2009 | Pioneer Televison & Video
Dvd tray will not stay closed. opens and shuts randomly
i had exactly the same problem on a LG-RH278H resp. a Medion MD 81733. I solved it by opening the micoswitches, cleaning the contacts and streching the springs inside the switches a little. The Problem was, that one of the microswitches stayed conductive even when it was off/open.9acead3.jpg
May 12, 2009 | Televison & Video
Coin Tray Wont Stay Closed
The plastic spring clip had become stressed and had "moved" out of position resulting in no "retaining presure,hence the coin tray/fuse cover would not stay in the "Closed" position."Simple" $6.75 fix.
Dec 29, 2008 | 2002 Subaru Forester
Cd tray not staying closed
gently push the cd door back in while pushing the door closed button , untill it closes if it still comes out then the cd laser mechanism is not lifting or something else has happened , then it will need to be tested to determine the exact cause
Oct 16, 2008 | Memorex MKS5001 Shelf System
Disk tray won't stay closed
i have same problem with mine, if i close the tray quickly by hand after it re-opens,it usually starts reading the disc
Jun 14, 2008 | Microsoft Xbox 360 Console
DVD Tray won't stay closed
It can only be repaired by the repair shop I think your son broke a lug on the inside it may need a new tray?
Sep 13, 2007 | Zenith DVD5201 Multi-disc DVD Player
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Larry Stiles
Larry Stiles
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
