Display not lighting
I have a VocoPro Gig Man karaoke machine. Last year the "blue" backlight started flashing on and off and now it is not working at all. I can still read the information in the display if I get up close to it, but there is no backlight to see it from any distance. Any suggestions would be greatly appreciated.
  • 1,512 Answers
Hi last1975
You will find that the display has a lamp behind it that backlights the LCD display. Changing out the lamp is usually simple enough if you are handy with screw drivers and a soldering iron. Most generally are 12 volt, meter it first if you have a multimeter, You can buy lamps to suit from Farnell electronics in most countries of the world. If you have any trouble matching types to order one, I can help you there. Happy to answer any questions you may have about your job. Good luck, and thanks for using FixYa.
regards robotek
Posted on Feb 08, 2009
Vocopro 8900 noise but no music
No power to voco pro 8900 cd player
Aug 09, 2012 | Music
How do I connect a droid to my voco pro gig man?
You need at least one adapter. Buy a 3.5mm male headphone to STEREO RCA adapter. Make sure to buy one with 2 channels (red and white) for stereo.
Plug a digital/analog 3.5mm male headphone jack adapter into the droid. Plug the RCA (red and white) into the mixer. Good luck!
Jun 06, 2011 | Vocopro Kj7000pro 19" 6 Channel Karaoke...
I picked up a vocopro karaoke machine at a yard sale and the echo makes a loud hum also i need a owners manual and remote where can i get help with this. model#890G thank you
Hello. For the manual and remote your best option is to search online. As far as the echo goes, this is just a cheap microphone with a cheap system. It will not go away unless you turn the volume down on the system. If you want to put good money down on a nice SHURE brand microphone it will definitly help with the echo, however it will not make the system any better.
Apr 17, 2011 | Vocopro DVD-Duet Multi-Format Karaoke...
I need a channel slider for a vocopro mixer KJ7000
various types are avail at mouser and digi-key .com. google them -check their catalogue and search under potentiometer.verify value,physical dimension and shaft length.
Mar 03, 2010 | Vocopro Kj7000pro 19" 6 Channel Karaoke...
I need a schematic for the vocopro entertaner model no HKH000011
You might try emailing the service centers listed here and see if you can get lucky:http://www.vocopro.com/servicecenter.php
Jan 23, 2010 | Vocopro DVD-Duet Multi-Format Karaoke...
I have a Memorex Karaoke machine, Press power button, screen comes on but it will not play a disc nor cassette. There is a small light beside the power button but it does not come on either. What could be...
Had same problem opened up back found blown fuse replaced and still blows.
Unhooked power source from were fuse was blown and fuse dose not blow seems to be something in that big board above it.I'm realy not into repairing of electronic boards. There is a lot or stuff going on inside there.
Just thought I would share my experience.
Good luck
Oct 20, 2009 | Memorex Karaoke System MKS5620RFB
My receiver is reading NO DISC it is a vocopro karaoke player/receiver model # DKP-10G
First, the player does not support DVDs or MP3 discs.
Try two things:
#1:
Unplug from outlet and Turn ON player (while unplugged).
Plug back in and try to use the CD.
#2:
Obtain a CD laser lens cleaner from Radio Shack ($13). It is an audio CD with a row of brushes and does not use chemicals
Oct 16, 2009 | Vocopro DKP-10G
Vocopro Gig Man Karoake Not working properly
Hello! Did the live session get disconnected? It is possible that he has also toggled the voltage selector that may have roasted the mainboard however you can try the factory reset to see if it works..
http://www.vocopro.com/PDF%20Manuals/GIG%20MAN%20MANUAL%20eng.pdf
Aug 13, 2008 | Audio Players & Recorders
Vocopro Gig Man won't play
we're having probles.we have avhf-4800 from voco pro,lights come on the box and on mikes no sound on teo mikes
Jan 09, 2008 | Audio Players & Recorders
89 people viewed this question
 Grubhead
Grubhead
