Question about Whirlpool ACD052MM Air Conditioner
My air condition keep blowing the reset button out and when i finally get it going i cant switch it to high cool or it defetley blows the reset button or whatever it is on the end of my plug its a 220
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 110 Answers
Looks like you are overloading the circuit breaker or reset button as you call it. YOu need to rerplav\ce it with one of a higher power rating
Posted on Sep 07, 2007
6ya staff
SOURCE:
MY AIR CONDITION IN MY 03' CHEVY IMPALA IS BLOWING HOT AIR THE DAY B4 IT WAS BLOWING COOL AIR COLD THT B MY COMPRESSOR OR DO I NEED ANOTHER CLIMATE CONTROL UNIT PUT IN I CANT AFFORD A DEALERSHIP PRICE
Sounds like the ac might need charging-it certainly would cost a lot less than a compressor. Sometimes it pays to start at the bottom,check out the simple less- costly DIY solutions first,maybe eliminating the those high end dealers prices Good Luck
Sep 05, 2017 | Cars & Trucks
My air condition is blowing hot air the day b4 it was blowing cool air could that be the compressor, or the climate control what could I do to fix it cant afford a lot of mechanical work
I can think of at least a dozen things that could cause that. But when you keep the year, make, model a secret, it's much harder to give any kind of answer
Sep 03, 2017 | Cars & Trucks
Intertherm model# FEH-015HA It is no longer blowing heat
High limit safety device is probably tripped, it should reset automatically, also check other safety's for tripped condition, they look like small round device located in a variety locations through out the unit with two wires to each one, some have small push button resets located in the burner compartment area. If all the safety's are reset and check out OK the main control board may need replaced. One of the most common causes of high limit safety device trip is lack of air flow, Dirty filters, evaporator coils, malfunctioning blowers, closed supply air registers etc.
Note: High limit safety switches also go bad after being tripped to many times.
Nov 28, 2011 | Heating & Cooling
Blowing hot air when on ..volume of air is fine..started weaking and finally no cold air
If the it is still blowing air yet not cooling the air, you may have to check that your air conditioning unit may need re-gasing. Heres a video which demostrates how the (genaric) re-gasing would work.
Jul 28, 2011 | Air Conditioning and Heat for Kia Amanti
I have a 1999 323i BMW. The AC doesnt blow cold (on cool days it blows cool temperature but not common A/C Cold Air, Hot Days it blows Warm/Hot Air). The heater blows warm air but definitely not common...
First things first.....You must have the air conditioning system hooked up to an a/c system machine and then checked for leaks and also read low and high side pressures. If there are leaks then low Freon (R134a) content and low refrigerant oil can cause the a/c system to not engage the a/c compressor which basically means you will not have proper defrost functionality nor regular air conditioning. Most shops, when working with your air conditioning, will install air conditioning dye to assist them in locating leaks and is the first step in diagnosing all a/c systems. Post the findings after thw
Jan 21, 2018 | 1999 BMW 323 Series
My A/C is not blowing hard
That high pressure rest button is most likely it(A breaker from the wind/mess), try resetting it.
Aug 11, 2009 | Ruud UAKA037 Air Conditioner
2000 chevy tahoe air conditioning blowing warm air
probably a leak.
what are your high and low side pressures?
Aug 01, 2009 | 1996 Chevrolet Tahoe
Air conditioning blowing only highest setting but HOT air
Sounds like your freon has leaked out and your heater blower resistor is burned out. Deffinitly take this to the dealer.
May 20, 2009 | 2001 Honda Odyssey
After switching from heating to cooling - air won't come on
It sounds like the fan relay in the stat itself is not closing when you make the switch over. If you have had the stat for less then 5 years it is covered. Honeywell has a full 5 year warranty on their focus pro stats, and would replace it free of charge.
Apr 02, 2009 | Honeywell Focus 6300B 5-2 Days...
Air conditioning only works on high
It sounds like you have a blend door problem.
Jun 24, 2008 | 1998 Mercury Mountaineer
Whirlpool ACD052MM Air Conditioner Logo
212 people viewed this question
Top Whirlpool Heating & Cooling Experts
Bill Long
Norman Al-Anbar
Dennis Boxerman
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
