Question about Sony DECK, MECH WITH AUTO REVERSE Single Dual Cassette Deck
Sony WE605S won't play in back direction any more
I recently replace the capstan and square belts in this dual cassette deck and now it only plays in one direction. What is puzzling to me is that both sides are behaving the same way. Both will rewind and fastforward and play in the right direction but both no longer play in the left direction as they used to.
Any advice?
  • jjbnsb Jan 25, 2009
    It's not just that it doesn't auto-reverse, it won't play at all in the reverse direction. It plays fine when I hit the > button, but won't play at all in the reverse direction (i.e. the other side of the tape) when I hit the < button. When I do hit the < it sounds like it wants to play but can't and so it switches back to the other direction. Interesting it does rewind in the < direction.
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    You need to select LOOP function to play auto-back and its symbol is .. <=> .. like that.
  • 104 Answers
If the square belt kinda serpentines in and around a couple pulleys (or did originally) then it did not get put back on correctly. try to think of another way it could be threaded through the pulleys.
Posted on Feb 11, 2009
The left side of New W-890R cassette deck plays at triple time. Right side plays normal. Tried to adjust with Pitch control but not the answer.
The transistor in the servo capstan motor is probably shorted- this happen now and then and you need a new Capstan motor. The question is most dual cassette decks are not worth the repair.
If the adjustment make no difference then that is likely the problem.
Sep 30, 2013 | Teac Audio Players & Recorders
Belt diagram
The belts are universal in most of the machines and it goes around the motor and the capstans in the twin deck. What is needed is to thread the beld and manually turn the motor to see the direction of movement of the capstan.
Removal of the machanism is to be done with care and refixing of the back plate to the capstan and motor.
Nov 08, 2011 | Sony MHC-NX3AV Shelf System
I replaced capstan belt and now the reverse play doesn't work. I guess I didn't align the belt around the wheels the right way. I have a sony cassette deck tc-we605s. Do you have an image of how...
You do not need any special instructions- look at the flywheels when they are running- they are hooked to the capstan shafts. The capstan shaft have to go in opposite directions for auto reverse so just threat the belt to that this happens- the unit should then work.
You can get a Service manual from Hi Fi Engine maybe
Aug 26, 2011 | Sony Audio Players & Recorders
My Nakamishi Cassette Deck 2 is eating tape. It switches off when it does, but how can I fix this? From the look of it this cassette deck has the same cassette drive as the DR-8. Is that correct?
It could be the take up spindle does not have enough torque causing the tape to bunch up after the capstan. If you open up the unit you will notice ether belts or rollers for the tape drive. If it has belts you can replace the belt after cleaning the pulleys. If it has rollers you may be able to clean them with a rubber cleaner (not alcohol which will dry the rubber and cause glazing). Make sure the capstan and the pinch roller is clean using a rubber revitalizing cleaner on the pinch roller. "Goof off" from a hardware store is great for the capstan if it has a lot of metal oxide on it.
Feb 24, 2011 | Nakamichi DR 8 Single Dual Cassette Deck
NEED THE PART NUMBER FOR SONY TC-WE435 DUEL CASSETTE PLAYER BELTS
Flat belt part number is..
301657001.. BELT (CAPSTAN)
and square belt part number is...
302440501.. BELT (FR2)
Above said info are taken from TC-WE435 cassette player s/m.
Thanks.
Dec 25, 2009 | Sony TC WE435 Stereo Dual Cassette Deck...
Clean machine damages my tapes!
Replace the belts and ensure the clutch is working correctly.
Mar 11, 2017 | Sony TC-KE500S Dual Cassette Deck
Door won't open
It might be a model that has a special IC that allows the door to open and close.
You'll need to take the case off.
try hifiengine.com...that site may have the service manual.
Kirk out
Dec 25, 2007 | Audio Players & Recorders
Motor plays at a very slow speed
capstan belt may be failing. check this by removing lid and touch the capstan flywheel when running. if it is easily stalled/slow to come up to speed and or the belt slipping badly then belt will require replacement.
Oct 14, 2007 | Sony TC WE435 Stereo Dual Cassette Deck...
239 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
