Question about Keurig B150 Office Brewing System
How do i de-scale if i have a direct plumb kit
Plumbed coffee system has blank screen
Strange. If the onboard computer has stopped working, first thing to try is a reboot -- the trick being, right now you can't shut it off. No matter. If the plug is inaccessible, go to your breaker box and shut it off at the breaker. Wait a minute, turn it back on, and see if it boots up correctly after that.
Feb 22, 2015 | Miele Coffee System
Tip
De-Scale Keurig coffee units
<br /><br />The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.<br /><br />Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.<br />Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.<br />If you taste vinegar..use more clean water, until the taste is ok.<br /><br /><br />
on Dec 22, 2010 | Coffee Makers & Espresso Machines
How to vacuum to waste using a Hayward ec65
Unfortunately, you can't. Unlike other DE filters yours does not have a multiport valve attached. What you can do is plumb in a three way valve between your pump and the filter. One direction would direct water to the filter, the other would direct water to a waste line.
Sep 01, 2013 | Pool & Spa
Pool skimmer has too much suction after changing to PVC pipe.
if you only have a skimmer and no valve to direct suction from the skimmer to he main drain, you will nee to down size your pump, i suggest a hayward 3/4 hp super two pump
Apr 29, 2013 | Pool & Spa
Coffee maker won't work. says it needs to be de-scaled.
De-scaling is normally done through the use of vinegar. I prefer the white vinegar myself. This is simple. Instead of water, place a quart of vinegar in your water tank and no coffee grounds in the basket. Start the cycle. When it is all done, repeat with ordinary clear water, again no grounds in the basket. When this cycle is completed. if yours is a integrated tank, turn the coffee maker up side down to remove all liquid. Refill and enjoy your freshly de-scaled coffee maker.
Presto - de-scaled.
I trust you will find this solution adequate. Thank you for your interest in FixYa.com
Jul 11, 2011 | Vacuums
I recently bought the latest model of keruig and after only a month it barely drips now. the water only dribbles out. I am not sure what to do.
Hello, W/D here.
Take an ordinary paper clip, and bend (unbend) it into an "L" shape. Use the end that is about 1" long to pass up into the K-cup puncture needle, and down into the outlet needle. Grounds can migrate in both directions, and this may be the problem. If this does not correct the problem, go through the de-scaling procedure, and clean the needles again after the de-scaling process has finished.
--W/D--
May 31, 2011 | Keurig B50 Coffee Maker
I can;t find manual and I want to clean my keurig coffee maker
You may be able to find the User Guide for your Keurig machine here:
http://www.keurig.com/customer-service/brewer-registration-and-support/user-guides-and-help
Your brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar. Full de-scaling insturctions can be found here:
http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/FD69E91A51CA41BEBF4CCAA138325BBF.ashx
Mar 26, 2011 | Microwave Ovens
De-scale botton blinks all the time
42n2nn4
Sorry to read about your issue.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Dec 22, 2010 | Keurig Elite B40 Coffee Maker
What does de-scale mean?
To de-scale anything in relation to water means to remove the mineral scale buildup on the walls or where ever. That's the usually white chalky stuff that you might see around nozzles etc. Follow yu manuals instructions to de-scale. Usually involving white vinegar, or possibly a product like CLR for removing minerals and rust stains. I AM NOT SAYING TO USE CLR IN YOUR MACHINE, just indicating an example of a product that manages mineral scale. Read the manual to do it correctly.
Nov 26, 2010 | Keurig B100 Coffee Maker
Keurig B150 Office Brewing System Logo
104 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
