Question about Pool & Spa
Intellipro vs 3050 has power to it but will not turn on, LEDs on drive do not light
2 Suggested Answers
  • 64 Answers
SOURCE: pentair pool pump vs 3050
These pumps should not be hooked into an intermatic mechanical timer. It should always have power supplied to it, meaning it should be installed to the line side of the power supply. Scheduling is done either in pump itself or thru an external controller such as a suntouch or easytouch controller, etc. When you have it wired into a timer like intermatic, power is interupted to the pump every day when the timer setting is for off. It is very hard on the drive of this pump, it does not like it, and will shorten the life of the drive. The pump was designed to always have power supplied to it, even when it is not scheduled to run. This may be the problem you are experiencing. HTH
Posted on May 22, 2010
I have 230 v to pump but it doesnt activate the display. is there a reset button
check incomming voltage make sure pump is set up for correct voltage see side of motor if set up for 240 volt and only have 120 volt that could be the problem also make sure grounded
Jul 12, 2014 | Sta Rite StaRite P6E6Y4H209L IntelliPro VS...
Power out Failure alarm
need more info will pump motor spin freely if not turn by hand remove cover on back of motor sometimes they lock up with power off turn by hand a few times then try with power
Mar 30, 2014 | Pentair IntelliFlo VS-3050 & VS+SVRS...
Pentair vs pump has power but will not run and LEDs do not light up
How did you test for power? Is it proper amount of power?
Did you use a multimeter to test for proper supply power/voltage?
Jan 15, 2013 | Pentair Intelliflo 4x160 Pool Vs-3050 Pump...
Pump will work manually when you turn it on but will not come on all the time with a intermatic time clock. no power light on speed light, timer is in on position, reach down press desired speed and start,...
This pump cannot work with a mechanical timer alone.You would need to use a pentair controller to use this in the fashion that you desire. The intellicomm P/N: 520641 is the cheapest way to accomplish this feature. However, if you have the intelliflo vs-3050 WITH SVRS then you simply need to program the timer to come on and off when you want it to. If you have only the VS-3050 with no SVRS , then you need the intellicomm module. Just incase you have the vs-3050 with SVRS, I will post the link for the manual so that you know how to program the timer. Any other questions, im @ adamh@newconceptchem.com
http://www.pentairpool.com/pdfs/IntelliProVS+SVRSOM.pdf
Jan 10, 2011 | Pentair IntelliFlo VS-3050 & VS+SVRS...
We lost our password for our Pentair IntelliFlo VS SVRS pump, part No. 011017. Our serial No. is 03321380901156. Please help us retrieve our password. Thank you.
On the normal vs-3050, you need to reset the whole unit. You do this by holding all 4 speed buttons for 30 seconds. After thi, shut off the power at the breaker. let sit for 2 minutes. Restore power and all setting are reset. I cant find any information about the SVRS model, but it should work the same way.
Sep 04, 2010 | Pentair IntelliFlo VS-3050 & VS+SVRS...
Pentair pool pump vs 3050
Jun 02, 2009 | Pentair IntelliFlo VS+SVRS Pump 230v -...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
