Question about Reddy Heater RLP100 Portable Forced Air Propane Heater with Variable Heat Ouput
Ready heater forced air 60 kerosene run for 4 min or so and dyes
Runs longer with cover off.has run fine for 5 years this year i run diesel thru it about 2 months and has fine until now
  • 3 Answers
First CARBON MONOXIDE WILL KILL YOU
#2 fuel is too dirty, use #1 or clear K-1.
I have found when running mine in any confined space like a garage, it will consume too much oxygen if not vented. It might run till it draws down the oxygen level. You start at 21% and draw down the oxygen to 14% that is where mine kicks out.
Clean out the filter, flush the tank, put in clean K-1, You might need to replace the igniter. Check your fuel line pressue (mine was 4 psi).
Good Luck
Posted on Jan 25, 2009
Ready Heater 60 wont start. Fan runs for about 5 seconds and then stops.
Check the wires for good connections. If the connections are good, then check the adjustment for the ignitor (sparker or glowplug).
Feb 10, 2011 | Reddy Heater 60,000 BTU Kerosene...
Reddy heater 165,000 runs for approx 15 to 20 min. I unplug wait 5 min. it restarts again and runs for another 15 to 20 min. and so on ....and so on purchased approx 1 year ago
There is a sensor in the tube that is a safety feture. it is a snap disc it maybe faulty, it is reading that the tube is to hot and shutting down, it cools and works again, check snap disc and also they need pleanty of fresh air.
Jan 13, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
I have a Remington 100 Heater. Was running fine until we had to refuel with kero that has a die in it. The heater will run for about 10-15 mins. then just start smoking with a heavy fuel smell. Cleaned the...
Similar heaters that use diesel have to routinely cope with the dye added to untaxed fuel, ditto similar heaters that use both fuels. Unless there was an excess of dye in the fuel you used the problem was probably a coincidence.
Dirt can be a big problem due to corrosion forming in the fuel tank caused by a relatively large percentage of moisture naturally in the fuel and the formation of condensation. Fuel is generally filtered through a fine gauze when the tank is filled but there is little or no filtration preventing dirt already in the tank from being picked up and finding a way into the spray head which generally jams the spinner affecting the quality of the fuel spray.
Cleaning the spinner and nozzle might work for a while but only a major clean out will restore reliability until the next time. It is also wise to check and adjust the pressure of the air pump.
Feb 18, 2018 | All-Pro Kerosene Garage Shop Heaters - All...
Ingition shuts down within 30 seconds. I realize this is the auto shut down, but there is no reason for it to do this. I took the cover off and found it would stay lit and run if I didn't tighten the...
Can be the Photocell {eye} at the back of the burner or the inline fuel filter.Photocells are easy to replace and when you install the new one make sure it's aiming straight to the flame.Inline filter can be cleaned by using forced air,but not recommended.Filters are cheap.If none of that works check the air pressure at the pump,rear of machine,little plastic pipe plug.4 to 5 P.S.I
Dec 23, 2009 | Reddy Heater 60,000 BTU Kerosene...
Look below
make sure air and fuel filter are clean.Set pump pressure to mfg set pressure after two minutes of operation
Feb 26, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
115000 btu ready heater/ about 3 years old from home depot/multi fuel
I would try cleaning the flame sensor, use a Qtip slightly moist with ispropyl alcohol. it's a rubber boot about 2in. long faceing the combustion chamber with two wires.
Jan 15, 2009 | Reddy HEATER R115 115,000-BTU PORTABLE...
Reset button keeps popping and the time between becomes shorter.
check the photo eye. It's the little rubber boot on the bottom right on the back side of the burner. If it's dirty, it may not be shutting off the igniter. If the igniter runs continuously, the safety breaker will trip.
Dec 18, 2008 | All-Pro Kerosene Garage Shop Heaters - All...
All pro multi fuel
This may sound dumb, but is it full? i have a simupar one and if i start it out at 1/4 tank or ness it will not run long before it shuts off.
Dec 12, 2007 | All-Pro Forced Air Kerosene Space Heater...
Heating & Cooling Logo
123 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
