Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
I have a poulan 2375 chainsaw and the clutch is bad, is there a clutch assy?
I have the same Chainsaw And i have gone through 3 clutches now. I have cut 100 to 150 trees with this saw. It still runs great. It seems alot of TRUE VALUE Hardware stores seem to have the clutches for them. They reverse screw off and are very easy to replace. I believe the clutch cost me under $10.00.
Posted on Feb 18, 2009
  • 2,176 Answers
I woulf check with PSEP.biz and you would need to know the exact model and type number for the saw. I just was there and they have a pretty good site for the breakdowns for these tools. Let me know if you need more help
Posted on Feb 15, 2009
My chain oiler is not working
The 2375's are famous for stripping the plastic gear on the oil pump. If you have ruled out all the other possibilities such as plugged transfers holes, then you will probably find the problem to be the pump. There is also a pickup in the tank but it is not accessible through the oil tank fill, you have to remove the assy. from the clutch side of the saw. Hope this helps.
Feb 20, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Plastic housing broken due to over tightining
I call it a clutch cover, Poulan calls it a "Chain Brake Assembly", pn 545139903 for Type 1 or 2 - 2375 WildThing.
http://www.ordertree.com/modelinfo/PWE/2375LE-Gas-Saw-Type-2/75.2375LE-Gas-Saw-Type-2.1.59.1.html
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 17, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I AM LOOKING FOR PART 2375 LE CHAIN BRAKE PART CAN U HELP ME FIND ONE. I AM LOOKING ONLINE CAN NOT FIND.CAN ANY ONE HELP ME FIND ONE. THIS IS MY EMAIL Kbagdon1@aol.com
PLEASE do not shout. Rules here do not allow us to contact you directly. Without a serial number I can only get you close. My best guess follows:
A Poulan "2375LE Gas Saw Type 2" link below (may not be your saw):
It appears you must purchase the entire clutch cover. See the "Handle, Chassis & Bar Assembly"; item 36; pn 545139903; $18.50.
All Poulan 2375 saws can be found here:
Poulan.com
The dash number of your serial number is the type.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 18, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Gas Oil Mixture
USE 50 TO 1 RATIO BETTER MORE OIL THAN LESS WORST OUT COME A BIT MORE SMOKE RATHER THAN SEIZURE
Nov 15, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wildthing 18" chainsaw 2375 sprocket/drum replacement
mso 9]> Normal 0 false false false MicrosoftInternetExplorer4 mso 9]> mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> mso 10]> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi tchild,
my name is Dennis Gladx and I can assist you with the problem of getting the sprocket off of the crankshaft of your chainsaw.
To remove the centrifugal clutch and sprocket you unscrew it from the crankshaft and it has a left hand thread. Also a little trick to remove anything from a crankshaft that could turn while you want to unscrew the item, Remove the spark plug and insert some rope into the cylinder for the piston to squeeze against and you will jam the piston without damage.
Glad to be of assistance Please rate this solution because I can learn from your rating. Thank you
Nov 08, 2008 | Poulan Garden
Poulan wildthing chainsaw
Go on the internet to:
http://lawnandgarden.manualsonline.com/manuals/mfg/poulan/poulan_gas_chainsaw_product_list_3.html
this is a free site that will give you access to a manual.
Pleased to be of service.
Oct 19, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
162 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
