Question about KitchenAid KCMS145J Microwave Oven
Diswasher now leaks noisy kichenaid
I tried to take my water inlet off to clean. couldn't. now the dishwasher leaks and sounds like a hair dryer inside
  • joe merigold Jul 22, 2007
    cleaned the water inlet, replaced the fill value, removed the lower spray arm to check the screen and the impellar. now when i run the machine, water fills, then heats, then you hear a clicking, then a low hum like a motor is trying to run. But no spray. The spray arms were working before I started this project
  • 4 Answers
If you could be more specific about the problem which you are encountering then i may be able to help, it sounds like its not to serious.
Posted on Jul 19, 2007
SOURCE:
GE dishwasher GSD6260JSS doesn't clearn as well as when new
water temp should be a minimum 140 degrees at inlet this can be checked with meat thermometer at kitchen faucet,also need proper fill of water entering dishwasher proper water pressure and fill also important for proper cleaning of dishes,if water is slow entering you may have sediment inside fillvalve screen if on well water in this case you will have to disconnect water supply line and take valve apart the screen is in side valve reassemble and test operation...if this does not work you may have to replace inlet vavle
Oct 21, 2012 | Microwave Ovens
We have a bosch dishwasher that doesnt seem to be emptying?
You should pull the unit out of the cavity and check the inlet to the drain pump. Sometimes a label or something will get sucked into the inlet and block it. If you don't find a blockage then either your drain pump is bad or the water level sensor is bad.
Aug 17, 2011 | Microwave Ovens
Kichenaid microwave khms155lss-4 doesn't work
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Aug 15, 2011 | KitchenAid Microwave Ovens
My dishwasher didn't drain the water out on the end of the clicle? What could be the problem?
Hello, Thank You for using FixYa. I will be helping you today.I would start where your drain line connects to the house drain,This is where most blocked drains happen. Disconnect the drain line and put it in a bucket and try to drain the dishwasher. Chances are its blocked somewhere you just have to find it.
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jul 02, 2011 | Microwave Ovens
I have an older model kelvinator dishwasher and there is water in the bottom of the dishwashwer and the diswasher will start and then stop but will go through all of the cycles. It just doesn't do the...
Pull the dishwasher out of the slot. There is a motor underneath that runs the pump to drain it. The usual cause is the it has a bad connection.
May 28, 2011 | Microwave Ovens
I have a LG Dishwasher that keep displaying and "e" error signal can you tell me what is wrong
Have you checked the water inlet? If the water doesn't enter the machine quickly enough and error 1E will show.
Hope that helps.
Mar 06, 2011 | Microwave Ovens
Hello I have an Inglis Soundblock II (Pretty standard) dishwasher. We have been watching it very carefull sincde our dishes stopped getting clean. All parts of the cycle seem to run well Except: There is...
How about the water inlet electrovalves, are they sticking maybe? Is there good pressure to the water inlet electrovalves from the house plumbing?
Apr 20, 2017 | Microwave Ovens
When my dishwasher drains both sides of sink fill with water...then they both eventually drain back into the dishwasher.
Sounds like your sink drain trap or line is clogged. When the dishwasher drains, the sink drain can't keep up, the water backs up, then backs down the dishwasher drain line into the dishwasher. You may not notice the slow line when you run a little water into the sink, but with the amount of water coming from the dishwasher the problem is worse. You can try taking off the trap under the sink and making sure it's clear. If the problem is farther down the drain line, you can try snaking it yourself, or call a plumber. I don't recommend using Liquid Plumr or Drano because if those don't work, they leave the line full of caustic chemicals for the next person who works on it. That can be dangeerous.
Dec 07, 2010 | Microwave Ovens
Electrolux esl 6115 dosent seem to be getting hot, filling with water but not cleaning the dishes, cleaned the filters.
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker
Sep 30, 2010 | Microwave Ovens
On whirlpool dishwasher on litle screen we get notification "F6", what should we do, what does it mean?
This is what it means:
F6. 6 Flashes. Water valve (WV1) is switched on but flow meter (FM) senses no impulses (less than 10 impulses in 10 secs) and the water indicator (WI) is at a low level
Water Valve Closed. Water inlet hose blocked.
Water inlet valve (WV1) defective. Flow meter (FM) defective (leads to FM failure)
The above info is pretty self explanatory but the bottom line is the dishwasher either is not filling fast enough or... is sensing that it is not filling fast enough. Check your inlet water line for flow by first turning off the power and water supply line then remove the line .... open the wall connection valve and check the flow. Also take a flashlight and small mirror if need be to check the hole of the inler to the water valve.
Thanks for choosing FixYa.
Kelly
Sep 02, 2010 | Microwave Ovens
KitchenAid KCMS145J Microwave Oven Logo
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Thomas F. Schneider
Jaime Hernandez
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
