Question about Kodak Office Hero 6.1 Printer
Ned parts for kodakhero6.1
Need hinges for lid
Registration camfrog
I have a ASUS U64E that I purchased 2/2012 and repaired in 8/2013.
At six months, the lid hinges started becoming lose and noisy. I removed the
hinge covers to tighten the hinge-to-case screws but they were not loose. It
was difficult to tell what the problem was without further disassembly. I let
the situation alone until recent failure of the one hinge with the opposite
side also near failure.
With the laptop out of the one year warranty, I searched and
watched various Youtube videos on ASUS screen replacement as the screen needs
to be removed to gain access to the lid hinge mount points. The failure is the with
lid hinge mounts to the lid frame.
My repair involved 1) regluing the lower part of the lid
inner frame to the lid, and 2) reducing the friction of the hinges by loosening
the hinge nut about 1/8th of a turn. On my unit, the hinge friction
was too tight putting a lot of stress on the hinge mount. I used Gorilla glue
for the repair.
The following videos are helpful for removing the screen:
http://www.youtube.com/watch?v=o7vSFvHphxM
http://www.bing.com/videos/search?q=how+to+fix+asus+u64e+screen+repair&FORM=VIRE2#view=detail&mid=857D69BAB15A49A9B0B2857D69BAB15A49A9B0B2
I also removed the keyboard and touchpad assembly to inspect
and clean the cooling fan which was very dirty.
The repair is holding and the lid action feels good with the
reduced friction.
Sep 02, 2013 | Computers & Internet
Glass separating from lid
Replace with steel lid. Parts below but first I have to get my 2 cents in!
I bought the replacement glass lid and it broke within the first week. Terrible design! They are using double sided tape to hold the glass to the hinge. There is too much spring tension to be held with tape. Way to go whirlpool engineers. I'm just a welder with 1 year of school and I figured that out? Hmmmm?
Steel lid retro fit
Whirlpool will tell you it can't be done. However I did and it works and looks perfectly.
here's the parts you need
All from a WTW8200 series washer
Part prices from Sears. I'm sure you can find them cheaper elsewhere if you look. I bought from sears to utilize the return policy while figuring out what parts to get. Thanks Sears! Give them the business if you can!!
1 pc 8572026 Steel lid $40.90
2 pcs 8563964 hinge $6.99 ea (hinge from the glass lid are different and the screw holes won't line up)
4 pcs W10119828 $3.99 ea (could probably get from the hardware store for half the cost.
Solution 2:
buy a replacement glass lid from whirlpool and send them your broken original glass lid and get a refund for the one you just bought. Repeat as needed until they figure out they need to produce a quality product.
Keep your whites...White and your colors bright America!!!
Nov 20, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
ASUS U46E broken hinge
Replacing a hinge, or both of them, isn't very tough. Check out this WEB site.
http://www.insidemylaptop.com/replace-br... Replacing Display hinges for your laptop maybe available from thia WEB site.
http://www.laptopparts101.com/display-screen-hinges/
Aug 27, 2012 | ASUS Computers & Internet
I need a lid hinge the number on the side is 07do4l do you know where i can get this part
The lid hinge on the mfx-1430 which "tends" to be the one that breaks is part #Z906461000 which is the hinge on the L.H.S. as you are looking at the machine from the front. Contact any copier dealer locally who deals with Muratec and they should be able to provide the part.
Feb 10, 2010 | Muratec MFX-1430 Copier
Acer 9402WSMi laptop with a broken lid.
You may not need to replace the lid just the hinge.
Try this WEB site for Acer parts.
Use this link :-
http://www.notebooksolutions.ca/zc/index.php?main_page=product_info&products_id=2839
Jun 30, 2009 | Acer Aspire 9402WSMi Notebook
Tightening HP Pavilion DV9000 17'' LCD Hinges
you may find the hinges parts from eBay which is cheaper price:
http://shop.ebay.ca/?_from=R40&_trksid=m38&_nkw=HP+Pavilion+DV9000+hinges&_sacat=See-All-Categories
how to replace your laptop hinges:
1) take out the screws at back of laptop under the hinges base
2) or take out the screw at side of laptop near the hinges base (if you find any screw there)
3) there are two cables connect between LCD lid and laptop base
you do not need disconnect those canbles. just careful them
4) take out all scews on the front of lid cover( the scews is covered by thin plastic cover), then take away front lid cover.
5) take out the screws at beside hinge base and side of LCD panel(2-4 scews at one side), you need check the back of lid cover can separate to LCD panel a little., be care replace only one at one time .
6) put back all screws step by step.
hope help you fix it, please take a rating let me know how much you are helped, thanks! any question please let me know!
May 18, 2009 | HP Pavilion dv6000z Notebook
Where can I find replacement lid? SCVC604 smart-pot
Try going to MarBeck.com they are a great source for small appliace parts.
http://www.marbeck.com
Dec 15, 2008 | Rival SCVC604-SS 6-Quart Slow Cooker
Brother Fax Machine MFC8840Dn broken hinge
you can actually by the hinge itself for only 27$
the website is here: http://www.precisionroller.com/search.php?q=brother+mfc+8440+hinge&x=0&y=0
Mar 19, 2008 | Brother MFC-8840DN (Bundle) All-In-One...
Brother MFC 8420-- hinge?
i went to Brother site and opened support.
searched for parts and got a listing of technical support shops in my area. called the first one listed and asked if they had the LP2403001 hinge in stock and they came back with an affirmative answer. will pick it up this afternoon locally.
You can see an image of the hinge assembly at ebay if you search for LP2403001.
Regards,
David
Jan 25, 2008 | Brother DCP-8020 Laser Printer
Kodak Office Hero 6.1 Printer Logo
43 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
