Question about Gateway Computers & Internet
Have Gateway Mfatxstl nmz 500 special. How can I increase memory?
Is there a chip or board I can install? System says I have 640 Mb (?)
SOURCE: Removing cover from old Gateway PC to add memory
If your Gateway PC is laying horizontally flat. There will be a black button in front of the PC on the left side of the CD-Rom. Push really hard. And WallAA!
Posted on May 03, 2008
leecom72
  • 4806 Answers
SOURCE: RAM upgrade for Gateway model MFATXNIN NMZ 300L?
The system takes PC133 SDRAM, as far as i know without performing a BIOS flash it can take up to 1GB (2x512MB) most of these PC's are restricted to 2x256 so a BIOS flash could be imminent in this case.
Good luck
Posted on Jun 19, 2009
  • 20 Answers
SOURCE: where can I find a E210882 N232 Motherboard Manual
I think that motherboard is actually an Intel D865GLC; there's lots of info available on the intel site. Here's the manual: (http://www.intel.com/support/motherboards/desktop/d865glc/sb/cs-008973.htm).
Look at the manual and see if it matches up. If it is a D865, it looks like it uses DDR memory, up to 3 or 4 GB (4 slots)
Posted on Aug 03, 2009
  • 28 Answers
SOURCE: can I increase the system memory beyond 2 mb?
The maximum allowed memory on this model desktop is 2 GB (2 x 1GB) memory modules.
You might be confused as computers normally do not ship with 2 MB of memory these days. This model was introduced in 2005.
Posted on Aug 07, 2009
CeeJayB
  • 77 Answers
SOURCE: I removed a Seagate 11 Series 5 10gb from a
If the 10gb. is a second drive, remove it from your machine and make sure it is set as a slave. Next, you'll have to get into your system BIOS by pressing F1 or F2 at one second intervals immediately after turning the machine on, and make sure it's recognizing the harddrive correctly.
Posted on Oct 19, 2009
Amount of ram Hp designjet 500 plus 24 inch and amount of ram support for Hp designjet 500 plus 24 inch.
According to the service manuals there is no memory upgrade for the 500 and standard memory is 16mb.. The 800 and 510 only have upgrade capability.
Apr 05, 2015 | HP Office Equipment & Supplies
Gt5082 what is the best sticks for gateway gt5082
Memory Upgrade for Gateway GT5082 Computer, the Gateway GT5082
Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. Memory
Type, and comes installed with 2.0 GB = 512 MB (removable) + 512 MB (removable) + 512 MB (removable) + 512 MB (removable) of Memory. You can upgrade your
Gateway GT5082 Computer to up to a maximum of 4.0 GB Memory, the system has 4 sockets to install Memory, already with 2.0 GB = 512 MB (removable) + 512 MB (removable) + 512 MB (removable) + 512 MB (removable) standard Memory installed.
For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
Choose the following Memory Upgrade for Gateway GT5082 Computer.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
hope it helps
Apr 14, 2012 | A-Data Technology 1GB kit (512MBX2)...
I installed 5G memory cards to my Gateway GT5238 PC, 1024 MB DDR2, Intel core 2 Duo E6300, 9-in-1 memory card reader, Non EEC, 4 slots, max memory 8192MB (8GB), PC2-6400, 8500, 5300, RAM DDR2. It had 1G to...
  • You Gateway only supports up to 8 GB. memory. Hence it will not see your 5 GB. dimms
  • tops: 8129 MB (8 GB.). 4- 2GB. Adding the maximum amount of memory will improve performance and help extend the useful life of your system as you run increasingly demanding software applications in the future.
  • Specs:
  • Installed: 1024 MB DDR2 (PC4200), 533 MHz memory (two 512 MB modules)
  • Expandable to: 8 GB (4 memory slots)
  • How much memory your Windows OS will recognize depends on which version of Windows you are running. 32-bit versions of Windows will see (and utilize) only 3GB or 3.5GB. To utilize more memory, install a 64-bit version of your OS. More information about OS memory maximums can be found at http://www.crucial.com/kb/answer.aspx?qid=4251.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
    Thanks, Joe
    Dec 02, 2010 | Gateway Computers & Internet
    Gateway mfatxstl elp 500c. MEMORY PROBLEM
    Check all of the other connections all around where you was at. Sometimes it dont take much to knock one of them loose. Also take the chip backn out and take a pencil eraser and clean the contacts on the chip with it.
    May 24, 2010 | Gateway GT5220 PC Desktop
    Need Manual for Slot1 PIII Gateway Jabil Tabor III Motherboard.
    The memory specifications for that motherboard are as follows:
  • 100-megahertz (MHz) Memory Bus Speed (FSB)
  • Three 64-bit or 72-bit Error Checking and Correction (ECC) 4-clock, 3.3V, unbuffered synchronous DRAM (SDRAM) Single or double-sided DIMMs in the following sizes: 8 MB, 16 MB, 32 MB, 64 MB, 128 MB
  • Expandable to 384 megabytes (MB) of SDRAM, CAS latency of 2, using 64-Mbit chips
  • DIMMs must adhere to the Intel 4-clock 100-MHz 64-bit unbuffered SDRAM DIMM specification, latest revision
  • Uses gold-plated DIMM socket
  • ECC signal and multiple bit detection, single bit correction, supported, using ECC DIMMs, can be enabled and disable in the BIOS Setup Utility
  • Jun 21, 2009 | Gateway Computers & Internet
    RAM Memory Speed compatibility
    all memory will operate at the slowest speed chip unfortunately. the only way to get the higher speed is to have all chips capeable of that particular speed.
    Feb 14, 2009 | ASUS Computers & Internet
    Want to add memory to Gateway 700x
    Upgrading RAM on your Gateway 700X (DDR) Computer is easy, Gateway 700X (DDR) Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. RAM Type, and comes installed with 512 MB (removable) of RAM.
    You can upgrade your Gateway 700X (DDR) Computer to up to a maximum of 2.0 GB RAM, the Computer has 4 sockets to install RAM, already with 512 MB (removable) standard RAM installed. For best Computer performance use the maximum amount of allowed RAM per slot for your system.
    Dec 08, 2008 | Computers & Internet
    Computers & Internet Logo
    121 people viewed this question
    Top Gateway Computers & Internet Experts
    Prashant M
    Prashant M
    Matthew Spark
    Matthew Spark
    Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
