Question about GeneralAire 81-11 Humidifier Float Arm
Drum not turning on Generalaire Humidifier model 81
Leaking at base due to too high of pressure or defective evaporative filter?
Humidifer FAQ's - General Filters, Inc.
www.generalfilters.com/support/faqs/humidification.html
I already have a GeneralAire® 1042 Humidifier installed, but have a 4,000 square foot home. Should I ... Can't I simply clean my Vapor Pad instead of replacing it? Where do I find ... I am seeing a very slight water leak coming from the bottom of my steamhumidifier. What do I do ... Legacy 1137 = 21 GPD / Up to 3,000 Sq. Ft.
GeneralAire® Legacy 1042 and 1137 Humidifiers - YouTube
? 3:22
https://www.youtube.com/watch?v=IM6IXVcjEdU
Jun 27, 2013 - Uploaded by GeneralAire Inc
GeneralAire® Legacy 1042 and 1137 Humidifiers - How to change the vapor pad .... Evaporator Pad (aka filter) change on aGeneral Aire 1042 ...
[PDF]General Aire Humidifier Owners Manual - On Time Mall
Jan 16, 2016 | GeneralAire Legacy 1040 Humidifier...
How do I wire up a Honeywell HE120 so it gets power only when the blower is on?
You didn't say what kind of furnace you have, but here is a link to what is known as an "air flow" switch that will allow the humidifier to operate only when it senses air flow through the furnace:
http://www.alpinehomeair.com/viewproduct.cfm?productID=453057513
Jan 26, 2015 | Honeywell HE120 Humidifier
My generalaire humidifier leak from the bottom , I have check the hose and inside all ok
Did you check the orifice inside the supply water tube? Sometimes the orifice can come loose and allow to much water inside the humidifier.
Feb 06, 2014 | General Filters 1099-LH Humidifier
What's your problem?Wire connection for GeneralAire power hfumidifier #1137
You will need a current sensing relay to cradle the blower motors common wire to accomplish this.
Jan 08, 2013 | Humidifiers
There is no water going into the humidifier, make: Generalaire 1042
Hello, first thing is check is the strainer going into the solenoid valve for sediment, if there is clean the strainer and reinstall. If the strainer in clean the check if you are getting 24 volts to the solenoid valve, if you have voltage and the solenoid does not let the water thru replace the solenod valve.
Apr 09, 2011 | General Filters 1042-LH Humidifier
Wiring a generalaire 1042 humidifier to a goodman furnace,when there are no terminals marked hum
24 VAC HUM
The yellow wire connected to the I.D. Blower pressure switch
is powered anytime the pressure switch is closed and provides
24 VAC humidifier control. Remove the yellow wire and connect
the supplied brown jumper wire to the pressure switch
terminal. Reconnect the yellow wire to the "piggyback" terminal
on the brown jumper and then connect the 24 VAC line of the
humidifier to the stripped end of the brown wire. Using a wire
nut or a field-supplied quick connect terminal can make this
connection. The wiring must conform to all local and national
codes. Connect the COM side of the humidifier to the B/C
terminal on the furnace control board (or to the COM side of
the 24 VAC transformer). DO NOT CONNECT 115V HUMIDIFIER
TO THESE TERMINALS.
Feb 21, 2011 | Humidifiers
My furnace is about 5 years old and the humidifier(skuttle190) has not been used in several years. I just ordered a new filter as the present one that I have does not fit properly on the wheel, its too...
Hello, if this is a drum type humidifier the small motor that turns the drum might be bad, take the drum off and see if the small shaft of the motor turn without the drum on it. if it does not turn than most likey the shaft or the internal parts of the motor are craked and must be replaced. If it does turn without the drum on it than either the filter is causing the problem or the drum is not seated properly. I hope this helps
Feb 13, 2011 | Skuttle 190 Humidifier
My honeywell humidifier attachment on my furnace will not start after the summer with water running to it.I have the humidity cranked up, but the filter is still bone dry.
Humidifiers usually are wired up to ONLY come on when the Heat is on and the fan running....anyother time you check it it will not be powered or wet...turn your heat on , wait till the fan comes on...then turn up your humidistat you should hear a click if its a flow through type and water should start flowing from the top...or if its tyhe drum style with the sponge...you should see it then turning...if it doesnt turn the pad/spindle may not be installed properly...if only fits one way
Oct 24, 2009 | Honeywell Power Humidifier: Furnace...
HE120 By-pass humidifer - Sponge Drum not rotating!!
Model HE908A drum is turning but we get no condensation
Dec 25, 2007 | Honeywell HE120 Humidifier
GeneralAire 81-11 Humidifier Float Arm Logo
60 people viewed this question
Top GeneralAire Humidifiers Experts
Mack Baxter
Dennis
Are you a GeneralAire Humidifier Expert? Answer questions, earn points and help others
