Question about Maytag Atlantis MDE7400AY Electric Dryer
Maytag commercial dryer display stuck on "0 minutes - delicates"
When money is put into the dryer nothing happens.. digital read out remains the same? Any ideas??
  • 489 Answers
SOURCE: cannot select all cycles
You have a problem with the display board and may need to be replaced.
Posted on Apr 28, 2008
AlmostBob
  • 550 Answers
SOURCE: Timmer Maytag Commercial Dryer
the maytag timer for MDE10 should be a multi vertical slide in type. If so under the keyed panel on the top of the dryer, is an electric control with a grey knurled knob facing the front of the machine.
This grey knurled knob is the time set.
The knob rotates clockwise (from front) under motor control while the dryer is running, and jumps back to starting position under spring control when the slide is pushed in.
There is a single grey stud moulded into the front of the knob, that is the sixty minute mark, and a number of slots before the stud, that take a nylon peg. they are 6 minutes apart 54 48 42 36 30 minutes. Inserting a nylon peg in the slot at 30 minute will do what you want.
Most service guys drop the peg in the bottom of the control when they remove it, makes it easier to find, next time, so if there is not a peg in any slot, examine the floor if the enclosure, A short nut n bolt will accomplish the same result if the peg is not there.
If the original multicoin push in has been replaced with a newer single slot device I dont know how the change is made, none of my dryers are that new.
Posted on Jul 28, 2008
  • 77 Answers
SOURCE: maytag commercial dryer rejects all quarter
Take out the coin slide and inspect for any worn parts. You can replace it for about $40
Posted on May 14, 2009
SOURCE: HiMy name is Ray and i would like to increase the drying time on a maytag commercial dyer model lde19cs
i just got off the phone with Maytag Commercial Laundry customer service, because i needed to know how to adjust the run times on this dryer model. here is what i learned:
there are slots in the timing cam into which fit a white pin for adjusting the run time. the letter settings on the cam are set at 12 minutes apart:
E = 12 minutes
D = 24 minutes
C = 36 minutes
B = 48 minutes
A = 60 minutes
if your dryer is running 48 minutes, that pin is likely in the 'B' slot. remove the pin. the built-in stop at the 'A' position is for 60 minutes.
Posted on Jul 02, 2009
  • 401 Answers
SOURCE: dryer heats on delicate cycle only
Sounds like one of the cycle thermostats has gone bad.
Posted on Jan 17, 2010
Machine won't work.
Robert. You have a bad water valve OR completely clogged up filter screens on the valve. My past experience with this machine with this type of problem is to replace the valve assembly. part Number W10364988
Apr 09, 2014 | Maytag Bravos Series MVWB300WQ Washer
I have a stackable Frigidaire Gallery Dryer. It won't turn on...
turn the start and it's like the drum gets stuck. then starts smelling like burning.
Mar 05, 2010 | Frigidaire Dryers
The lights on the dryer work it wont start it didnt have any problems drying before this happened no odors or smells i have a maytag MDE5500AYW. please help. thank u
If the display on the dryer reads '88' then place a heating pad over the display. After a few minutes, the '88' code will clear, and it will work fine. Sounds crazy, but works every time for me.
Sep 28, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Commercial dryer coin op programming
Below is Maytag's commercial laundry website where you should be able to acquire the information requested.
http://www.maytagcommerciallaundry.com/content.jsp?pageName=CustServ
Jun 16, 2009 | Maytag MDE16PD Electric Dryer
E = 12 minutes
D = 24 minutes
C = 36 minutes
B = 48 minutes
A = 60 minutes
May 28, 2009 | Maytag Dryers
Maytag commercial dryer rejects all quarter
May 14, 2009 | Maytag MDG16PD Gas Commercial Dryer
I have maytag neptune 5500- shows error code 88
When the 88 displays, put a heating pad over the display - it will be ready in just a few minutes. Sounds crazy, but it works every time.
Jan 10, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag MLG23PD Gas Commercial Dryer
605 5 quarters to start 712 12 minutes per quarter if yu want 1 quarter to start dryer change to 601. if yu want dry time to be 8 minutes change to 708 press whites and colors to select value and then press permanent press to go to next code.
Apr 19, 2008 | Maytag MLG23PD Gas Commercial Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
299 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
