Question about Bosch 1191VSRK 120V 1/2" Single Speed Hammer Drill
Bosch drill overheated and stopped working
Direction switch is also stuck in forward
4 Suggested Answers
stug_57u
  • 99 Answers
SOURCE: bosch psb 600 drill will not reverse
The red button sits on a lever that changes the polarity of the switch output. If this lever feels loose and you can't feel it engaging anything then you need to split the housing and make sure it is seated properly. If it is, and the lever on the switch is moving fine aswell then you should check all the wires coming out of the switch, and if they are all connected properly you will prob need a new switch.
Posted on Oct 26, 2008
  • 5603 Answers
SOURCE: drill just stopped? not working
These tear the brushes out. You can not use them for hammering. It is a design problem.
Replace the brushes and use only for straight drilling.
Posted on Jul 29, 2009
  • 211 Answers
SOURCE: Bosch GBH 2-20 SE hammer drill stopped working
hi
check the cord and the switch to have continuity,the wires,the brushes,the rotor and stator.
regards savumihai71
Posted on Dec 16, 2009
How do the wires go on a bosch CSB650 drill
If you mean the R/l switch attached to the top of the switch. The wires from the brushes go to diagonally opposite connections and the field leads in the others. If it go slow in forward motion swap the brush wires over with each other.
Jun 07, 2012 | Bosch Drills
hi
regards savumihai71
Oct 11, 2009 | Bosch Drills
Bosch 1199vsr stopped working while drilling through concrete. The reverse works. Help
your tool should have a rotating reversing switch and the contacts for the forward rotation might be dirty or burnt. I would unplug the tool and remove the screw holding the back handle half on and look to see if anything is burnt or just dirty or bent. If you have an air compressor try blowing thru all areas of the tool. Let me know if this doesn't work you can also go to Boschtools.com and type in your model number on the left hand side after clicking on manuals.
Jun 28, 2009 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
Drill just stopped? not working
Jun 28, 2009 | Bosch 1199vsr 1/2'' Dual Torque Hammer...
Bosch 11224 vsr no noise
Make sure your brushes are contacting the armature, sometimes they hang-up. But it sounds like the crossover has failed. Its the part that changes the tool from forward to reverse. You need P/N 1617200262.
Any Bosch service center should be able to supply you with this part.
Apr 17, 2009 | Bosch Drills
BOSH PSB 600 RES drill will not restart
Hi, Sounds like you have a pinched wire somewhere. When you say you somehow make it work are you bending the powercord, shaking the drill or what? Any of those things would suggest a pinched wire or broken switch. Make sure the switches for reverse and hammer work in both directions. You say it is relatively new and there is no smell so I would not suspect the brushes and it doesn,t sound like it is running long enough to overheat anyway. The best advice I can give you is that the drill needs to be opened and examined, and if you have an ohm meter check all of the connections from the power cord to the trigger. If you don't feel comfortable with that then you may want to return it under your warranty or you may want to do that anyway. Good Luck!
Feb 04, 2009 | Bosch Drills
Bosch 3.6v driver
bad switch
Dec 02, 2008 | Drills
Bosch 1191VSRK 120V 1/2" Single Speed Hammer Drill Logo
63 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
