Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Simplicity sunstar electric clutch - Cub Cadet Street Sign- tractor lawn riding mower parts
Where is the clutch assembly on simplicity 7350 upright vacumn
The clutch is part of the brush roll. Remove the bottom plate to see the brush roll and clutch. The rod that attaches to the brush roll activates the clutch
Nov 18, 2012 | Riccar 8900 Simplicity 7822, 7300, 7350,...
How do I tread a sunstar sewing machine
here is a phone number,,call them and ask them about a manual
1-800-765-5977--sunstar dealer
1-800-431-6646--sunstar industrial
sunstar gobal---
mailto:Robin@CollierEquipment.com
Nov 07, 2012 | Sewing Machines
I need to replace the throttle wire on my Conquest 16hp Simplicity. Is this much of a job?
I believe what you're referring to is actually a cable not a wire. These are usually inexpensive and relatively easy to replace. I would go direct to manufacturer to ensure getting a matching part that doesn't require modification to work on your unit. Then simply route it just like the original was and you should be good to go.
NOTE: if you only have one lever, and not a separate clutch control, you will want to make sure that the clutch bar is only pushing forward at the very end of the high throttle setting and that it returns freely when you pull it back.
Oct 09, 2012 | Simplicity 2003 Conquest 16hp Briggs/44"...
Garden tools riding mowers simplicity
They do not make that pto clutch anymore but you can buy a electric pto clutch for around $200.00 -$300.00 You will need to check the shaft size it should be 1" or 1 1/8" I could give you more info but you need to find it your self.
Paulo
good luck
Oct 27, 2009 | Garden
Simplicity sunstar 20hp rear pto won't engage deck when you flip the switch, it used to work for a while and I could play with it and it would work but now nothing, any suggestions.
your electric clutch may need adjustment. Take the hood off. Look behind the double pulley that's on the crank shaft. Behind the pulley is an electric clutch. You will need a .010-.015 feeler gage and check between the clutch plates. You will tighten the three screws that mount the clutch to the motor. Try and get as close to .010" as you can. After adjustment start the motor and try and engage the pto. I bet it will work.
Good luck
Jul 18, 2009 | Garden
1990 20hp Sunstar Rear PTO cuts out during rototilling operations, if I turn off switch and turn back on it will work for a little bit but then cuts out again. I recently replaced my engine with a 24hp...
Did you install the original electric clutch from the old engine?
If so, you may not have the adjustment right. On most electric clutches, there is a specific distance between the drive plate and the driven plate. Check your shop manual (if you have one) for this, as it does vary between manufacturers, and depending on the size of clutch.
Apr 17, 2009 | Garden
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
63 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
