Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
Keyless entry keypad doesn't work
I have replaced the battery. Still doesn't work. Has the wiring anything to do with the keypad. Is it possible that someone has disengaged the keypad?
    Champion:
  • 244 Answers
No idea what you are talking about. is it a wireless or hard-wired keypad? Did you recode it if wireless. give more info.
Posted on Jan 26, 2009
2003 crown vic keyfob only works with ignition in run position .keyless entry and door locks work fine.even tried new keyfob.no change
The keyless entry system consists of the following components:
  • driver door module (DDM)
  • keyless entry transmitter
  • keyless entry keypad
The driver door module (DDM) receives inputs from the digital transmission range (TR) sensor, ignition switch, brake switch, window/door lock switches, lighting control module (LCM), keyless entry keypad switch and remote transmitter. The DDM outputs consists of keyless entry keypad switch illumination, power door lock actuators, luggage compartment release solenoid, horn relay, and lighting control module (LCM).
  • Battery junction box (BJB) fuses:
    • circuit breaker 7 (20A)
  • Central junction box (CJB)
    • 4 (10A)
    • 6 (15A)
    • 8 (25A)
    • 13 (5A)
  • Keyless entry keypad switch
  • Power door lock actuator
  • Luggage compartment release switch
  • Luggage compartment release solenoid
  • Connectors or connections
  • Wiring harness
  • If fuse's good have checked for DTC'S - diagnostic trouble codes .
  • B1526 Keyless Entry Circuit Short to Ground DDM Go To Pinpoint Test E . B1553 Decklid Release Circuit Short to Battery DDM Go To Pinpoint Test B . B1751 Park/Neutral Switch Circuit Short to Battery DDM Go To Pinpoint Test K . B2425 Remote Keyless Entry Out of Synchronization DDM Go To Pinpoint Test L Need a professional grade scan tool to check fro these codes . Not a code reader for OBD2 codes .
  • The doors do not lock/unlock using the remote transmitter
  • Remote transmitter not programmed.
  • Remote transmitter.
  • DDM.
  • Go To Pinpoint Test F .
Did you program the new key fob ?
Remote Transmitter Programming NOTE: All remote transmitters are programmable and must be set at the same time.
  1. Turn the key from OFF to RUN four times within three seconds, ending in RUN. The locks will then lock and unlock, confirming program mode has been entered.
  1. Press any button on each remote transmitter to be programmed. The doors will lock and unlock to confirm that each remote transmitter has been programmed.
  1. If additonal remote transmitters are to be programmed, repeat Step 3 within 7.5 seconds or steps 2 and 3 if more than 7.5 seconds have elapsed.
  1. To exit program mode, turn the ignition to START or wait 7.5 seconds.
  1. NOTE: Failure to wait at least 20 seconds will cause programming failures. Wait at least 20 seconds after turning the key to OFF or after the last remote transmitter has been programmed to activate a remote transmitter for testing or verification
Feb 19, 2017 | Cars & Trucks
How do I reset keyless door entry that is in lock out mode
Viper Keyless Entry Systems
https://www.viper.com/car/keylessentry/
Viper is the industry leader in keyless entry systems. Add the convenience of keylessentry to virtually any vehicle - even vehicles without power door locks!
Alarms, Remote Car Starters, Keyless Entry & Locks - JC ...
www.jcwhitney.com > Audio, Video & Electronics
20 out of 32 products in Alarms, Remote Car Starters, Keyless Entry & Locks ..... ofKeyless Entry & Car Alarms allow you to lock and unlock power door locks.
How to program your keyless entry keypad - Ford Ownerhttps://owner.ford.com/.../locks.../how-to-program...Ford Motor CompanyDiscover how to lock and unlock your doors and how to program memory settings that will adjust seats & mirrors for each driver.SecuriCode™ Keyless Entry Keypad - Ford Ownerowner.ford.com/.../locks.../securicode-keyless-entr...Ford Motor CompanyLearn how to set a 5 digit SecuriCode on the Ford keyless entry keypad. ... Sign out. Register/Sign In · Your Vehicle. Service & Maintenance. Service & .... vehicle's SecuriCode keypad to lock and unlock your doors without having to use a key. ... Thekeypad will go into an anti-scan mode if you enter the wrong code seven ...How Programming Your Keyless Entry Can Make ... - Ford Life
Jan 08, 2016 | Cars & Trucks
My keypad stopped working. Is there a battery for this?
if your keypad is factory installed there is no battery . if after market yes has battery. if factory, be sure no keys are in car, when you press in a code number does the pad light up ,if yes its getting power then it is probably the keypad needs to be replaced ,if not lighting up its not getting power, check fuses and wiring connections
Dec 23, 2014 | 2005 Ford Escape Limited
Lift-master 1280 Keyless entry pad not working.
Is it possible the wiring to it backed out of the connections on the opener? Might check there first to see if it became disconnected. If the wiring looks good then I would take the wiring off of the back of the keypad and touch them together to simulate a switch. If the door reacts then the keypad is bad.
Nov 24, 2012 | Cars & Trucks
Can't reprogram/operate keyless entry pad for Craftsman Model 139.53661SRT3 garage door opener.
If the following instructions don't work and you have a good battery the keypad has failed.
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to your keypad and key in your 4 digit code and press enter.
Apr 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
2000 Lincoln Towncar. Keypad on door will not unlock doors. Interior lights do come on. The last two keys pushed simultaneously will occasionally lock the doors. I am using the code printed on a sticker in...
The driver door module (DDM) is connected on the standard corporate protocol (SCP) communication network. The DDM controls many functions including power windows, power door locks and remote keyless entry. The DDM also communicates with the driver seat module (DSM) to control the power mirror and seat memory functions.
Do you know anything about automotive electronic control modules ?
The driver door module (DDM) receives inputs from the digital transmission range (DTR) sensor, ignition switch, seat switch, window/door lock switches, lighting control module (LCM), keyless entry keypad switch and remote transmitter. The DDM outputs consists of keyless entry keypad switch illumination, power door lock actuators, luggage compartment release solenoid, horn relay, and lighting control module (LCM).
Best thing to do would be to have a factory scan tool hooked up to check for DTC'S diagnostic trouble codes . That should be the first step if it's not programming the code.
  • The doors do not lock/unlock using the keyless entry keypad
  • Keypad.
  • Circuitry.
  • Driver door module (DDM).
  • GO to Pinpoint Test L .
PINPOINT TEST L: THE DOORS DO NOT LOCK/UNLOCK USING THE KEYLESS ENTRY KEYPAD CONDITIONS DETAILS/RESULTS/ACTIONS L1 RETRIEVE THE RECORDED RESULTS FROM BOTH CONTINUOUS AND ON DEMAND SELF TESTS Use the recorded DDM DTCs from the Continuous and On Demand self tests.
  • Are any DTCs recorded?
Yes For DTC B1525, GO to L3 .
For all other DDM DTCs, REFER to the DDM Diagnostic Trouble Code (DTC) Index.
No If the door locks are inoperative, GO to L2 .
If the keypad illumination does not operate, GO to L10 .
If the keypad illumination is on continuously, GO to L14 .
L2 CHECK THE DOOR LOCK OPERATION Check the door lock operation by depressing a door lock switch.
  • Do the door locks operate?
Yes GO to L3 .
No GO to Pinpoint Test E . L3 MONITOR THE DDM PID KEY_PAD
Scan tool
Monitor the DDM PID KEY_PAD.
  • Are any of the keyless entry keypad switch numbers present?
Yes GO to L4 .
No GO to L5 . L4 CHECK THE KEYLESS ENTRY KEYPAD SWITCH
Keyless Entry Keypad Switch C525
Yes If 1/2, REPAIR Circuit 78 (LB/YE). TEST the system for normal operation.
If 3/4, REPAIR Circuit 79 (LG/RD). TEST the system for normal operation.
If 5/6, REPAIR Circuit 121 (YE/BK). TEST the system for normal operation.
If 7/8, REPAIR Circuit 122 (YE). TEST the system for normal operation.
If 9/0, REPAIR Circuit 123 (RD). TEST the system for normal operation.
No INSTALL a new keyless entry keypad switch; for additional information, REFER to Keypad-Keyless Entry . L5 CHECK THE KEYLESS ENTRY KEYPAD INPUT WITH THE KEYLESS ENTRY KEYPAD SWITCH Monitor the DDM PID KEY_PAD, while depressing all the keyless entry keypad switches one at a time.
  • Are all the keyless entry keypad switches operating correctly?
Yes GO to L9 .
No GO to L6 . L6 CHECK CIRCUIT 797 (LG/VT) FOR VOLTAGE
Keyless Entry Keypad C525
Measure the voltage between keyless entry keypad C525-7, Circuit 797 (LG/VT), and ground; and between keyless entry keypad C525-8, Circuit 797 (LG/VT), and ground.
  • Are the voltages greater than 10 volts?
Yes GO to L7 .
No REPAIR Circuit 797 (LG/VT). TEST the system for normal operation. L7 CHECK THE KEYLESS ENTRY KEYPAD SWITCH INPUT While monitoring the DDM PID KEY_PAD, momentarily connect a fused (7.5A) jumper wire between positive battery post and keyless entry keypad switch C525 as follows:
    Keypad Button Keyless Keypad Switch C525 Circuit 1/2 Pin 3 78 (LB/YE) 3/4 Pin 4 79 (LG/RD) 5/6 Pin 5 121 (YE/BK) 7/8 Pin 6 122 (YE) 9/0 Pin 1 123 (RD)
  • Are all the keyless entry keypad switch inputs operating correctly?
Yes INSTALL a new keyless entry keypad switch; for additional information, REFER to Keypad-Keyless Entry .
No GO to L8 . L8 CHECK THE KEYLESS ENTRY KEYPAD SWITCH CIRCUITRY FOR AN OPEN
DDM
Measure the resistance between keyless entry keypad switch C525 and DDM as follows:
    Keyless Keypad Switch C525 DDM Circuit Pin 3 C521 Pin 8 78 (LB/YE) Pin 4 C521 Pin 13 79 (LG/RD) Pin 5 C521 Pin 16 121 (YE/BK) Pin 6 C520 Pin 24 122 (YE) Pin 1 C520 Pin 25 123 (RD)
  • Is the resistance less than 5 ohms?
Yes INSTALL a new DDM; for additional information, REFER to Section 419-10 . TEST the system for normal operation.
No REPAIR the circuit in question. TEST the system for normal operation. L9 CHECK THE KEYLESS ENTRY KEYPAD BACKLIGHT Depress a key on the keyless entry keypad.
  • Does the keypad illumination operate correctly?
Yes INSTALL a new DDM. For additional information, REFER to Section 419-10 . TEST the system for normal operation.
No If the keypad illumination does not operate, GO to L10 .
If the keypad illumination is on continuously, GO to L14 . L10 CHECK THE KEYPAD - DDM ACTIVE COMMAND KEYPAD BACKLIGHTING LIGHT ON AND OFF Trigger the DDM active command KEYPAD BACKLIGHTING LIGHT ON and OFF.
  • Does the keypad illumination turn off and on?
No GO to L11 . L11 CHECK DDM GROUND - JUMPER CIRCUIT 66 (LB) TO GROUND
DDM 522
Connect a fused (7.5A) jumper wire between DDM C522-4, circuit 66 (LB), and ground.
  • Does the keypad illuminate?
No GO to L12 . L12 CHECK CIRCUIT 51 (BK/W) FOR OPEN
Measure the voltage between keyless entry keypad C525-7, circuit 797 (LG/VT), and ground; and between keyless entry keypad C525-8, circuit 797 (LG/VT), and ground.
Yes GO to L13 .
No REPAIR circuit 797 (LG/VT). TEST the system for normal operation. L13 CHECK CIRCUIT 66 (LB) FOR OPEN Measure the resistance between keyless entry keypad C525-2, Circuit 66 (LB), and DDM C522-4, Circuit 66, (LB).
No REPAIR Circuit 66 (LB). TEST the system for normal operation. L14 CHECK THE KEYPAD ILLUMINATION - DDM DISCONNECTED
DDM C522
  • Does the keypad illumination turn off?
No GO to L15 . L15 CHECK KEYLESS ENTRY KEYPAD FOR SHORT TO GROUND
Yes GO to L16 .
No INSTALL a new keyless entry keypad switch. For additional information, REFER to Keypad-Keyless Entry . TEST the system for normal operation. L16 CHECK CIRCUIT 66 (LB) FOR SHORT TO GROUND Measure resistance between DDM C522-4, circuit 66 (LB), and ground.
  • Is resistance greater than 10,000 ohms?
Yes System OK. CLARIFY the concern with the customer.
No REPAIR circuit 66 (LB). TEST the system for normal operation.
Nov 03, 2017 | Lincoln Town Car Cars & Trucks
The Chamberlain wireless keyless entry model 940CD doesn't work. I changed the 9 volt battery, but it doesn't light up or do anything when I enter the password. It's like it's totally dead. I've had it for...
make sure it is the right keyless entry. For starters, Make sure your antenna hanging off the operator is "purple" color. If it is grey, you have the wrong keyless entry. The keyless you have is for the 315 frequency. If your antenna from the operator is grey, you need to get another keyless entry based on the frequency.
Oct 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keyless Entry Problem
First try changing the battery in thh keypad 9V. if that dos not work just moving the wire coming from your opener towards your keypad. DONT CUT THE WIRE OR ADD TO IT. That should take care of it
Feb 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
1993 ford explorer
the keyless entry pad may be an add on from the dealer which was just stuck on therefore comtains a battery need to remove the door panel and check for wires from pad
Sep 14, 2008 | 1993 Ford Explorer Limited
Sears Wireless keypad will close door but will not open
If you are sure the battery is good than it sound like the keypad is bad and needs to be replaced. With a 6+ year old operator I would suggest a wired keyless entry (Donino GD-1) so if the operator has to be replaced you can use the same keyless entry.
Jul 04, 2008 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
270 people viewed this question
Top Chamberlain Car Audio & Video Experts
Glenn Mayer
Glenn Mayer
Vince Heuser
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
