Watches Logo
A
Anonymous Posted on Jan 15, 2013
Zr55086 battery good but still not working - Relic Watches
Casio CPW-500H-1AV analog watch not working
That certainly wouldn't hurt - be sure you use good new batteries.
I replaced the battery as I have many times imy 2005 suunto s6 watch, but this time the display remains blacked out...none of the buttons work or make any noise. The battery is a 2032 and is brand new.
Tough one but here goes. 1 New battery does not necessarily mean good battery 2 Determine the battery is inserted with the correct side up. 3 Is there a reset. Possibly a small hole that you poke a paper clip into. 4 Try holding all the buttons in at the same time for a couple seconds 5 Go see a watchmaker,
good luck
Swatch Irony Battery replacement will not work
mcdevito75 here, I am thinking your watch ran fine before the battery change. It sounds like the new battery is not makeing good enough contact, you can try, removeing the battery and cleaning the contacts in the watch carefully with a Q tip, dip the Q tip in anything containing alcohol cologne, rubbing alcohol, perfume wet the Q tip good, then sqeeze most out of the Q tip as not too saturate the battery contacts, also clean the battery itself, the oil on your fingers could give it a poor contact on the watch. The stop watch section doesn"t take as much battery power as the second hand. You may also be able to jump start your watch also, You"ll need a needle and a magnifier glass, With the back off your watch, right in the middle of the movement, just below where the stem (winder) goes, you"ll just see part of a little gear, this is the hour hand gear, see if you can gently move that gear just a fraction, place the needle between the teeth of the gear and try to move it as gentle as possible then se if the gear will move on it"s own., be very carefull with the movement. Swatch watches are collectables. If you don"t feel comfortable doing the above, look for a small watch repair shop in your area for help.
1helpful
2answers
Battery is good, but watch stopped.
You need to hold in reset and mode to make it go back on.
1helpful
Dont work
This is pretty general but here is what you can do...
Check the battery. If the battery is bad then replace it.
If the battery is good have a watch technician check to see that the current is good. If the current is bad then check contacts for corrosion. If still bad have the movement replaced. If there is a signal then a cyclonic can be used to force the movement and free up the gear train. If this still doesnt make the watch work then replace the movement.
This is a very general answer for a general problem.
10helpful
Watch new battery installed still wont work
First you have to check if the battery is on full power, as sometimes even brand new batteries are underpowered. Good battery should have 1.54 - 1.57 Volts of charge.
If battery is ok and watch still not working - get the battery out and clean (scrape) all battery related contacts with steel needle untill they are shiny. Use the dust blower to get rid of cmall dirt particles.
Replace the battery. Now the watch should work.
If the watch doesn't work after cleaning contacts, then this is mechanical fault and you will need watchmakers help.
Do not forget to rate, please.
MY WATCH JUST STOP WORKING
first u have to check the batteries whether it is in good condition or not,if the batteries in good condition then go for the movements check
LED no longer work, hand no longer work
good morning ! the problem is the battery ! replace the battery carefuly! good luck !....
Top Relic Watches Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Relic Watch Expert? Answer questions, earn points and help others
