Question about Singer 7442 Mechanical Sewing Machine
My bobbin winder starts and then freezes and an alarm sounds-
I have to restart the machine
it continues to happen each time
the sewing part works fine
Try to sew slower. In my sewing class the bobbin always freezes, and if I go slower it works better sometimes.
Posted on Jan 24, 2009
I have acquired jones cb sewing machine.works fine except occasionally when stopped in middle of a seam wont restart but hums.will restart after turning handwheel.
Sounds like it is seizing due to old dried oil. May need a thorough cleaning and oiling. If this is the case, it would be good to avoid further use until it is repaired as continued use could damage the motor.
Wheel on right side that controls the needle up and down is very tight...
My jones sewing machine wont stitch straight just zig zag tried moving...
Feb 01, 2017 | Sewing Machines
I have just purchased a second hand Singer 6038. When sewing, the machine hesitates about every 15cm of sewing causing the stitch to go off centre. The tension is fine whilst trying various stitches.
I'm wondering if there is a possibility that a puff ball is getting in the tension, needle or bobbin. You might want to look at your thread in the light to see if it is fuzzy. Replace it with good, embroidery thread from someplace other than Walmart. Anyway, do a good cleanup in those areas to ensure there isn't buildup of thread.
Nov 28, 2016 | Singer 6038 Mechanical Sewing Machine
Broke a needle, replaced it. Now stitching is all wonky. Rethreaded many times, changed both needles. Adjusted upper and lower loopers. Nothing is working. Worked fine until the broken needle
Um, possibly the machine is out of time--happens frequently when needles break. You can search the internet for sewing machine timing or take it for service.
Nov 20, 2016 | Sewing Machines
Why won't bobbin winder spindle turn?
Bobbin winder spindle will not spin - YouTube
? 1:24
https://www.youtube.com/watch?v=Fh52_ndkSKs
Jun 12, 2013 - Uploaded by djc472
Thread caught between spindle shaft shoulder and bearing. ... Sewing machine won't pick up bobbin thread ...
Why won't the bobbin winder work on my Kenmore sewing ...
www.shopyourway.com > Manage My Life > Questions
The bobbin winder doesn't spin and I can't wind the bobbin. ... What will release thebobbin winder that is stuck to the right on my Kenmore sewing machine model 385.17826690? Why won't my bobbin holder thread to the top on my Sears Kenmore sewing machine model 385.17928?
Sewing machine bobbin winder won't turn ' ShopYourWay
Dec 29, 2015 | Sewing Machines
Keeps going out of line "main motor block". Had it repaired 3 times in last 6 mos.
Guess you should change repair service and ask them some warranty for repair?
Nov 06, 2015 | Sewing Machines
I keep getting error E6 on Brothers CS 6000i- I cleaned the thread several times and when I try to restart sewing it happens again. I've removed the bobbin and re-threaded and it keep jammin and beeping....
The motor locked up because the thread is tangled.
Solution:
Remove the tangled thread before continuing the operation.
Clean the bobbin case to remove the tangled thread.
After cleaning the bobbin case, insert the bobbin case properly.
If the needle is bent or broken, replace the needle.
Then, thread the upper thread properly, and continue the operation.
Dec 21, 2013 | Brother CS-6000i CS6000i 60-Stitch...
Brother VX1435, needle won't move
some machines when the bobbin winder is engaged will not sew, do you
have to disengage the center wheel in the handwheel to wind a bobbin?
or do you have to just move the bobbin winder spindle to the right to
wind the bobbin?
do you have a manual for the machine?
Sep 06, 2012 | Brother VX1435 Mechanical Sewing Machine
Bobbin winder belt melted
Mine stopped working too. Gave up and wound bobbins by hand for a while until I broke down and took the machine apart -- an ordeal to figure out. I found that a pliable ring on the winder was completely disintegrated (gummy plastic-like stuff). An online search found this -- a bobbin "tire" which I THINK is the part I need: http://www.sewingpartsonline.com/bobbin-winder-tire-brother-x55238051.aspx. Hope this helps. --Also cleaned all the lint out when I had the machine opened up. They don't make it EASY!
Jan 18, 2012 | Brother CS6000i Computerized Sewing...
Singer 7442 Mechanical Sewing Machine Logo
51 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
