Question about Sony PlayStation 2 (PS2) Console
Slot memory #1
Why my slot memory #1 doest not work it say there not memory card in the slot ,, and there one so I dont know what going on cant u help me with that thanks Pat
  • Patrick Bouffard Jul 16, 2007
    where is the fusible resistor (near the console's solder point)????
    thanks alot for your help I hope this will help with my prob
    Pat
    Problem Solver:
  • 30 Answers
If you're qualified to do so,check the fusible resistor near the console's solder point, if not visit the nearest sony service center.
Posted on Jul 15, 2007
SOURCE:
SD card wont load on my t-mobile G1
try to go to a free check up cellphone repair...
check if your sd card slot is working fine...
if not you know now what is the problem...
but before it...try to fix it by yourself...just make some little adjustments...
Feb 11, 2010 | Kingston 4GB Secure Digital High Capacity...
I cant seem to find my SD card slot on my Aspire 5515 basic vista laptop either i dont have one or i need to buy somthing.so really there is two probs 1) Were is da SD card slot and 2) if there isnt one...
The full specification of your laptop is located HERE. It shows that you do not have any card (mini or SD Cards) slots.The only option left in order for you to use and access any memory card is to buy an "external" USB-type Card Reader. There are 3-in-1 and 5-in1 Card Readers that can be connected via your USB port. In these card readers, you can plug in your memory sticks or memory cards and your computer can then access it.
Feb 09, 2010 | Computers & Internet
Memory card ?
Hi there.
At the front of the computer you should see 1-4 different sized small slots, the card should slide into one of these slots.
Good luck
Jun 02, 2009 | Dell Dimension 3100 PC Desktop
When I put a memory card in slot A it wont work
take the gc apart and look at the memory card slot number 1 it may have ben bent sumhow idk if u have younger bros or sis's they may have tried to put 1 in upside down or summin
Mar 24, 2009 | Nintendo GameCube Console
I bought a new mico sd card for my nokia 6233 bu it keeps sayin memory card not formatted hw cani format it
Dear
There Are two ways to format sd card
1) by Phone : Go to Memory card option
Gallery - memory card - option - format
& ur card will be formatted
2) By pc : connect ur phone to pc or sd card reader & right click on removable disk which is your sd card's slot & select format option.
Then it will ask for custom & quick format, select one from them & ur card will be formatted
Thanks & regards
Feb 23, 2009 | Nokia 6233 Cellular Phone
Memory card locked
pull the SD card from the the slot and it right side up with the label facing you, there is a short slot on the side with a sliding switch. move it to the other side of the slot and that will unlock the card. (it probably go moved as your were putting the card back into your camera) good luck!
Jan 11, 2009 | Toshiba PDR-3300 Digital Camera
I HAVE MY PROBLEM REGARDING MY MOTHERBOARD, AMD ATHLON EP-8KTA3L
Specification DFI AK74-SC Model DFI AK74-SC Socket Socket A Motherboard CPU AMD Athlon /Duron processor 600MHz-1.2GHz and faster Chipset VIA KT133/686A Memory 3 DIMM sockets
max. 1.5GB (unbuffered or registered)
Supports PC 133/ VCM SDRAM BIOS Award / 2Mbit Power Management ACPI and OS direct power management
Wake-on event: RTC/Modem/LAN Hardware Monitor System and processor temperature Expansion Slots 1 AGP slot (Supports 4x/2x AGP)
4 PCI slots
1 AMR slot
1 ISA/PCI slot Audio AC`97 Audio codec with Yamaha AP Super I/O 2 x NS16C550A compatible UARTs
1 x SPP/ECP/EPP parallel port IDE Dual PIO mode 3/4 EIDE channels up to 4 IDE devices
Ultra DMA/66 transfer rate up to 66MB/sec Rear Panel I/O Ports 2 x USB, 2 x DB-9, 1x DB-25, 1x PS/2 Mouse,
1 x PS/2 Keyboard, 1 x game/MIDI, 3 audio jacks I/O Connectors 1 x IrDA, 2 x external USB, 2 x IDE, 1x Floppy,
1 x ATX power, 3 x fan, 1 x WOR, 1 x WOL, 3 x internal audio Form Factor 4 layers ATX Motherboard Form Factor
30.5 cm x 22 cm 12.0 inch. x 8.66 inch. Warranty DFI AK74-SC Motherboard Pro DOA Warranty ONLY
DOA DFI Warranty
DFI Warranty
motherboard
If you want more Information then go to this link :-
http://www.motherboardpro.com/Motherboard-With-ISA-Slot-DFI-AK74-SC-1-ISA-4-PCI-AGP-Socket-A-ATX-Used-Motherboard-p-39.html
Dec 03, 2008 | DFI AK74-SC Motherboard
My memory card slot 1 doesn't work can I change the unit so that games will save to slot 2 instead or how do I swap the slots in the unit
When you choose to save when you are in any game, on the save screen you can choose to save to slot 2 provided there is a memory card inserted in slot 2.
Dec 27, 2007 | Sony PlayStation 2 (PS2) Console
PLEASE HELP WITH AGP SLOT DISABLE ON VECTRA XE320 ....
you can't enable/disable the AGP slot in your bios unless you have integrated Graphic card inside your motherboard ..
does your previous graphic card work with the motherboard ?
Dec 25, 2007 | HP Vectra Xe320 PC Desktop
Port 1 not working
Hello. Please check the port (by replacement) and the fuses on the main board. If you need more info please advice.
Mar 26, 2007 | Sony PlayStation 2 Slimline Console
Sony PlayStation 2 (PS2) Console Logo
35 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
