Question about Garmin Nuvi 660 GPS Receiver
Charging doesn't display map when charging
When I charge my Garmin nuvi 750 it will not display the maps. Using car charger.
  • 2 more comments
  • Anonymous Jan 28, 2009
    I have the same problem. When the car charger is plugged in I only get the pc and nuvi icon on the screen. The unit will only turn on when I unplug it. Any help?
  • Anonymous Feb 01, 2009
    I have exactly the same problem with my Nuvi 660. When started with a charger the maps start loading and then just when the WARNING screens appears the pc and nuvi icons screen comes on and the unit will not operate unless you unplug the charger.
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    Is the charger a Garmin OEM charger? If not, please note that many knock-off brands are not wired the same and will not allow you to use your Nuvi with the car adapter. The difference in wiring makes your Nuvi think your Nuvi is in data mode and connected to a PC.
    Please contact me if you need to obtain a Garmin OEM charger.
    - Jim
  • SHARCNET-USA
    Do you get the PC and Nuvi icon on the screen instead?
I learned that with the unit off - hold the on button down - don't release it. A PRE-BOOT MODE message will appear at the bottom and may flash. Continue holding down the start button. The first time I did it a series of dots came on the screen and I was instructed to touch each one. After that it started as normal. I plugged into a wall charger and but git the pc and nuvi icons again. I repeated the process - holding the on button on and let the PRE-BOOT MODE appear and kept holding but this time a different message came on and then the PRE-BOOT MODE appeared again. I let it go and took the unit to my car and plugged it into the Garmin car charger and it worked as it used to - normal. However, when I plugged it back in the house to the wall charged I got the pc and nuvi icon again. It appears that I am using the wrong wall charger as a previous writes stated. But the nuvi still worked in the car plugged into the nuvi charger. I hope this helps.
Posted on Feb 01, 2009
Don't have a manual. Charging in electrical outlet at home and don;t know how long to charge for. Plug in shows a red and green lite, both on and I have been charging for over 4 hours. Comments
Most garmin nuvi satnavs take 4 hours to charge with a mains charger or a car charger. It takes 8 hours with a computer. There's a batter indicator on the screen that shows WHERE TO and VIEW MAP. It will probably only appear when the charger is disconnected if it's the same as other garmin nuvis.
You can get the manual in Adobe Reader format from http://static.garmincdn.com/pumac/nuvi680_OwnersManual.pdf
Jun 14, 2011 | Garmin Nuvi 680 GPS Receiver
When charging my Garmin 265WT, is the screen supposed to show when the battery is fully charged? e.g. charging complete
While it's charging it doesn't show the battery indicator. When the charger is plugged out it shows the battery state on the screen that shows WHERE TO and VIEW MAP
Feb 25, 2011 | Garmin Nuvi 265W GPS Receiver
Garmin Nuvi 255w won't start up. tries loading maps and then goes in a continuous circle. acts if not charging. tried reseting and charging with wall charger and car charger
You should try to manually delete the maps (after a backup ) on the device , power cycle and retry sending the maps from MapSource or the Software CD from the manufacturer. The map is a single folder onto the device (eg. gmapsupp.img)
May 25, 2010 | Garmin nuvi 255W GPS Receiver
I cannot use the GPS unit while in charge mode(NUVI 350)
Are you using a USB cable & charger to operate the GPS?
If so, you should stop and use the supplied cradle / power cord to power the GPS instead. The USB cable is used to transfer data to and from the GPS and on other models (maybe your 350, too) to slow charge the GPS battery when completely discharged. Powering with the USB cable will power up the GPS, but does not allow navigation, mapping, etc.
Oct 12, 2009 | Garmin Nuvi 350 Car GPS Receiver
When I plug in the Garmin to charge it, the screen goes completely black and I get no directions. When I unplug it, the map returns with directions. Please help , Thank you James
If you are plugging it into your computer, or charging it through the USB port, the Garmin NUVI will go into "DATA MODE". You must use the car cradle to charge it and stay in navagation mode.
Mar 23, 2009 | Garmin nuvi 750 GPS Receiver
Don't Want to Buy the Updated Maps (nuvi 200W)
If the PC icon comes up while using the car charger, then there is a problem with your charger or mini-USB port on your Nuvi. Many after market chargers are not wired the same, causing the PC icon to show up on the screen. In this mode, your Nuvi will not charge nor can you use your Nuvi for navigation.
You can use your Nuvi with old maps. No one says you have to update. You'll just get an occasional reminder that your maps are outdated.
- Jim
Jan 24, 2009 | Garmin nuvi 200W GPS Receiver
Battery on Nuvi 750
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
Jan 19, 2009 | Garmin nuvi 250W GPS Receiver
Garmin nuvi 260w not operating while plugged in
Based on your description, you are doing it right. You said....
"when i connect it to the car charger it shows the computer sysmbol and starts charging. there is no other usb port on the device"
That is correct. It takes about 2-3 hours to fully charge a low battery.
There is only a mini USB port on a 260.
It's used for charging and downloading updates of software or maps.
Sep 02, 2008 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
401 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
