Question about Canon Image Runner 1630 Copier Copier
Codigo e805 ir 1310 - Canon Image Runner 1630 Copier Copier
Ihave canon ir 400 machine but thats no worked. machine displayed error cod E805 .sir please give me sugestation
E805The stoppage of the exhaust fan is detected, or a failure in rotation of the fan is detected. (iR/GP400 or later machines)The detail code, which can be checked with DISPLAY,
You can try to clean up the fan
Apr 14, 2018 | Canon Office Equipment & Supplies
Ir 2020 e805
E805- Fan Failure- open rear cover find PSU and check for rotation of cooling fan at power up ( spins as soon as display lights up)
If it isnt spinning - replace with correct part from Canon, the circuit is expecting a feed back specific value which will only be seen with the correct fan.
Jan 16, 2014 | Office Equipment & Supplies
Error e805 ir 400
my cannon ir400 xerox machine is on but no working power supply is full but not run machine
Dec 21, 2013 | Canon imageRUNNER 400S Copier
Canon ir 3100 cn E805 003
E805 fan error
Description
With the ITB fan in operation, the machine does not detect a lock state for 5 sec continuously.
Remedy
Turn off the main power, and check the DC controller PCB; then, turn the power back on.
Remarks
Disconnected fan connector; absence of lock signal because of fault in fan.
Nov 09, 2010 | Canon Office Equipment & Supplies
System Error E805 in Canon iR2018
E805 is Fan failure
The fan is faulty. - Check the fan connector.
- Replace the fan.
Jan 08, 2010 | Office Equipment & Supplies
Canon ir 400 photocopier
i have ir400 in my machine. first e805 code has been displayed and after that it shows that to load paper. then after e803 code is displayed. please help
Jun 03, 2009 | Canon imageRUNNER 400S Copier
Close the front door and second problem is E805
805 is a bad fan usually one of the three on the exit door
Dec 10, 2008 | Canon imageRUNNER 400S Copier
Canon IR 1310 Copier
I have downloaded service manuals, parts manuals, maintenance manuals, service mode, error codes from www.printcopy.info
Sep 13, 2008 | Canon Office Equipment & Supplies
Error code
805 codes are usually associated with fixing exhaust fans not powering up. Usually due to a blown SMD (Surface Mount Device) fuse on the DC controller PCB.
Aug 29, 2008 | Canon imageRUNNER 400S Copier
Canon Image Runner 1630 Copier Copier Logo
56 people viewed this question
old marine
old marine
