Question about Brother DCP-7020 All-In-One Laser Printer
Scanner arm hitches as it moves
My printer was pluged in a 220 volts surge and the power supply was blown off. I repaired it by changing only the fuse which was blown off and all was OK. But the problem I'm facing now is that, when I put the printer on , I saw a message on the LCD screem reading "Please Wait" which will last for as long as the printer is left on. the scannig arm does not move normally as it should making a cracking or grinding sound and I also noticed that the fan is not spinning as it should be thou the power is on .
  • 62 Answers
There is more to he fuse blowing that caused the problem. U may have also caused the control board to fail. Take it into a service rep to have it looked at .
Posted on Jul 11, 2007
SOURCE:
110 volts, rated TV was plugged into 220 volts power supply. Now when it was plugged into an 110 volts supply its not getting on? What could be the causes? and please suggest solutions.
It probably fried the power supply in the TV unfortunately. If the electrical surge stopped there then it should just be a matter of swapping out the power supply. Provide a make and model of television and I will see if I can help find one with instructions on how to change it.
Nov 24, 2012 | Office Equipment & Supplies
Sir, I got Epson stylus 480 printer and unfortunately in Pakistan voltage is 220v but i imported it from america where voltage is 120v so i directly turned it on and it started once on 220v and now not...
What you should have done before using your Epson stylus printer was to purchase a Voltage Converter able to convert 220 volt into 120 volt.
You probably "burned" out the printers electrical circuit because you let 220 volt directly into a device built for 120 volt.
If it is the other way around f.ex. connecting a 220 volt device into a 120 volt outlet it will not destroy the product. Only the product may not work as it is supposed to or it will be slower.
Here is a site with a voltage comparision chart, that can help you to choose a Voltage Converter for your purposes.
http://www.110220volts.com/Power/Voltage+Converters.html
Regards
Sep 15, 2011 | Office Equipment & Supplies
My hp printer 6110 officejet all in one keep giving message scanner failure when i want to print something
Please make sure that the printer is connected to a wall outlet and not to a surge protector because surge protector distributes the total electric supply equally to each and every device connected to that surge protector. Printer might work and might not with a surge protector but it will always work fine with a wall outlet till the hardware of the printer and power chord, adapter are working fine.
some times scanner failure error comes if it is not getting enough power supply.So if it is connected to a surge protector then I will suggest you to disconnect it and connect it directly to a wall outlet.
Now scan or copy any document and see if something happens.
If not the do check while you press scan or copy button the scanner light is moving or not?
If scanner light is not moving then do a hard re-set.
Hard Re-Set :
- disconnect power chord from the back of the printer and then from wall outlet or surge protector.
- wait for 40 secondsand then connect the power adapter to wall outlet and then to the back of the printer. The try to scan or copy....still not working then check if the scanner bulb is glowing or not?
If scanner bulb is not glowing and if you dont hear any noise while you press scan or copy...then printer hardware has gone bad and you need to replace the printer
Feb 25, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Cannon 5600 printer is not receiving power from 220 volts
Sir,
You are suggested to check the power cable if it fine and properly pluged in the printer and check if you printer power adapter is working fine. you can check the Power adapter by the Tester usually avalible at electronics shop.
Oct 20, 2009 | Computers & Internet
El mimo error 220
Scanner Lamp Or Compositive Power Supplys Problem.
Change The Lamp if the problem Continive change or repair The Compositive power supply
Sep 02, 2009 | Canon imageRUNNER 400S Copier
I have a brother printer and I pluged in to 220
Connecting it on a wrong power outlet like what happen will cause a major problem on your device , since your device is made for 110 and you connect it to a 220 this can still be fix and it needs a part replacement so better take it to a service center to have it check and have the burned part replace....
Aug 10, 2009 | Office Equipment & Supplies
Ricoh FT 3013 error code E 21? how can it be fix
· Scanner home position sensor failure
· Defective scanner motor
· Defective main board
· Defective dc power supply board
· Incorrect scanner drive wire position
· FU202 on the dc power supply board open (blown fuse).
- Action -
Turn the main switch off and on.
Check the position of the 1st scanner sensor actuator.
Actuated De-actuated
Does the scanner motor rotate when the main switch is turned on?
No Yes
Correct the scanner drive wire position.
Check the voltage at CN106-2 on the main board.
24 volts 0 volts
Check FU202 on the dc power supply board.
Good No Good
Replace FU202
Replace the dc power supply board.
Check the voltage at CN105-1 and 6 on the main board.
24 volts 0 volts
Replace the main board.
Jun 26, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
Accindentally pluged it to 220 volts instead of 110 volts
hello , i suggets you replace the power supply with a 110 v input boerd .
or do this if the damage is big replace the all sytem with a new one then get a voltage step down ie 220 to 110.
thank you
May 06, 2009 | Yamaha DVR-S120 DVD Player
Epson perfect 4990 color scanner
You can try to purchase a new power supply from the USA or similar that has 110v power. Problem is that maybe the power supply let some of the high current through to the main board in the machine and that may have fried too. If you can afford it, try the power supply option first - the scanner may just power up fine.
Jan 20, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Brother DCP-7020 All-In-One Laser Printer Logo
82 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
