Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
After RTH6400 installation heat strip is no longer actuated
I ahave an American Standard airconditioner-heat pump unit that has a heatstrip within the inside exchanger unit Prior to installing the programable thermostat the heat strip would engage to bring temp up quickly. Now, the heat strip does not come on at all. The manual does not seem to address a unit with both a heat strip and a heat pump. How can I get our heating/cooling system to work as it used to?
  • 700 Answers
Http:// look at the very last part of thius page and you will see that the particular thermostat does not work for heat pumps tha have auxillary heat. Sorry for being the bearer of bad news but you need to upgrade the selection to make it work right.
Posted on Jan 25, 2009
Heat works until thermostat calls for aux heat, then blower shuts off with outside unit still running.
Some blowers shut off depending on the system. Do you have electric hest strips inside? If not the blower will shut off. The outdoor fan should not be running if in defrost mode. If you have heat strips then you likely have low voltage wiring crossed
Dec 16, 2016 | American Standard Heating & Cooling
American standard error code 158
thermostat error codes for an american standard ... - AllExperts > ... > Heating, Air Conditioning, Fridge, HVAC
Aug 22, 2010 - programmable thermostat, error codes, american standard: James, I am not familiar with that stat set up,short of goggle/yahoo the codes may ...
Jul 24, 2015 | American Standard 5000 Heat Pump Unit
Take a look at this YouTube page that explains with good videos what are some of the common problems with heat pump noise. The one that seems dominant is the defrost cycle a heat pump goes thru when it melts ice off the evaporative coils. In defrost cycle, The compressor runs but the cooling fan does not, so you will hear a loud buzzing sound and the unit sounds like it is stalled...because only the compressor is running to generate heat to melt coil ice.
Defrost cycle noise video:
Mar 06, 2015 | American Standard 5000 Heat Pump Unit
Why does my American Standard heat pump compressor and condenser fan run when I have the thermostat set to emergency heat?
It's possible the "brain" thinks it can still supply some heat. Other wise there is a wiring problem or thermostat switch problem. Installed recently? Never used emergency heat before? What is your emergency heat type, gas or electric? Are you sure they are working. If not the "brain" senses and uses the only source available: heat pump. Thermostat? probably Honeywell? If so call Mfg customer service. Warranty on thermostat or heat pump? If so call customer service. Call your installer.
Feb 28, 2015 | American Standard Heating & Cooling
American standard heat pump will only work on emergency heat with fan turned on not auto but only works a little while then quits i can turn it off for about 20 min. and back on emergency heat with fan on...
How old is the unit? Heat pumps don't work when it's real cold, you know it's limits. If it's not real cold outside, then it may be low on gas or such and need a service call.
Nov 26, 2013 | American Standard Heating & Cooling
Wiring schatic to wire a 10 kw heat strip inside of a trane gas furnace
If you are using strip heat as seperate mode you must install a fan isolation relay which would be energized by emergency ht mode of stat.
Nov 25, 2012 | Carrier 38CKC042 Air Conditioner
The heat pump stays on to 20 deg (outdoors) and the burners will not work till the temp is under that leaving the house at a max 65 deg, I beleave the heat pump should true off around 30 -35 deg ? then the...
Remove the cover of the circuit board and controls on the outside unit. Some units have a thermostat that allows you to set the temperature at which it switches to the second stage of heat. Set that for about 34 degrees.
Jan 02, 2011 | Heating & Cooling
Installing rv roof airconditioner heat strip
I see what you see also in the manual. The difference is the Heat Strip package that part is optional and the 600212-001 with the optional heat strips becomes the new 600315-001 I talked to Dometic Duo-Therm and the models are the same but they both are not heat pumps but the new heat strip package comes on when told to go into heat mode when you change the thermostat to heat. The part you purchased will fit both model numbers you listed for your roof top air conditioner. Thanks, Sea Breeze
May 09, 2010 | Heating & Cooling
Carrier heat pump: aux heat does not seem to work
The unit is probably to small for theare you are trying to heat.
When the Aux HT light came on that meant the heat pump could not keep up with the demand for heat. (Probably due to extreme cold, or undersized unit.)
If yu have heat, then at least one heat strip is operating. If you have multiple heatstrips, one or more could be malfuncioning.
Or it could simpy be to cold/to small fr your area and not able to keep up.
How many square foot are you trying to heat?
What is the outside temp?
What is the inside temp?
What size unit (BTU output) do you have?
Dec 22, 2008 | Haier Energy Star ESA3183 Air Conditioner
Heating & Cooling Logo
548 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
