Question about Samsung Dryers
Samsung #DV363 gas dryer installation instructions
Gas dryer. Samsung DV42H5200GP 7.5 Cu. Ft. Gas line connected, but not in on position. Is there a pilot to be lit? If so, where located?
No pilot...
Yours is a "hot surface" electric igniter ...
The link (below) should take you directly there...
(picture is just for viewing ... Retailer sales site)
Please be advised... gas appliances must be externally vented & installed in a manner as NOT TO THREATEN human life.
EVEN if you are having a HIGHLY QUALIFIED technician install, inspect & operate your equipment... The instructions should be completely read & understood by EVERY USER.
ADDITIONALLY it would be VERY WISE to consider getting a carbon-monoxide detector ...
Like your life depends on it.. because it could...!!
Be safe.
http://www.appliancepartspros.com/samsung-heate-dc47-00022a-ap4211272.html
Dec 12, 2016 | Samsung 7.5 Cu Ft Capacity Platinum Gas...
Gas converion
Since no model number was given, gas dryer conversion kits usually come with instructions. The usually require you to replace the burner orifice, and make an adjustment to the regulator already included with the dryer. In some cases speacial tools are required to perform the conversion. Pleazer Appliance...
Apr 08, 2014 | Samsung 7.3 Cu. Ft. 7-Cycle Gas Dryer -...
How to hook up kenmore gas dryer model# 76512
You may download a copy of the owner's manual and installation instructions at http://c.searspartsdirect.com/mmh/lis_pdf/OWNM/L0705194.pdf
Dec 08, 2011 | Kenmore Dryers
Samsung Dryer keeps tripping the circuit breakers
The "professional installer" likely set the pedestal on top of the power cord and damaged it, or the dryer duct has been pinched off causing the dryer to overheat.
Jun 13, 2010 | Samsung DV448AGE Gas Dryer
How to remove the front cover of my samsung front load gas dryer
take the top off first by removing the two screws in the back, then the five screws which hold down the door section. the door will lift off and then follow the instructions
Jun 08, 2009 | Samsung DV448AGE Gas Dryer
Samsung gas dryer convert to propane
I purchased a Samsung steam gas dryer and found that no one in our area knew anything about them, Fortunately I am a gas tech. but have never worked on this brand. The first thing is you should always use a gas technician before doing this. Secondly turn off the gas and electricity. You must remove the two screws from the back that hold on the top of the appliance and set this aside. Then lift up the front electronics and disconnect the wiring harness, once you've done this there are 5 screws along the top of the silver strip or door area. This will alow you to lift up the front and disconnect the wiring harness and set aside. now you can follow the instructions on converting your dryer. PLEASE check for LEAKS and proper gas flow. Follow the same steps in reverse to put the dryer back together and happy drying.
Mar 18, 2009 | Samsung DV448AGE Gas Dryer
1317150009709 frigidaire dryer0how do i get at the pilot light or
There are 2 house fuses in the dryer circuit. If
1 of the 2 fuses is blown, the drum may turn
but the heater will not operate.
Gas supply valve is not open (gas models).
Dryer does not have anough air supply to
support the burner flame (gas models).
LP gas supply tank is empty or there has been
a utility interruption of natural gas (gas
models).Replace fuse.
Check to make sure supply valve is open. See INSTALLATION
INSTRUCTIONS for procedure.
See INSTALLATION INSTRUCTIONS.
Refill or replace tank.
Dryer should heat when utility service is restored
Feb 16, 2009 | Frigidaire FGQ332ES Gas Dryer
How do you install an LP conversion kit on a Samsung dryer
kit comes with minimal instructions. you need to remove the burner which requires removal of the top panel, control panel and front panel. (see how do I remove front panel on samsung dryer for more details). It is fairly easy, maybe an hour the first time you have done it. Pay attention to all of the instructions re the burner, do not losen any of the gas tight fittings!
Jun 24, 2008 | Samsung Dryers
LP CONVERSION KIT
I think it would be useful to call in an plumber to do the job and i think you are on the right track.
Sep 14, 2007 | Dryers
Dryers Logo
49 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
