I am getting error code 996 when I switch on my Ricoh GX2500 colour printer. How can I solve the problem?
5 Suggested Answers
jaylex
  • 417 Answers
SOURCE: cause for error code sc560 on ricoh ap3850c
H there below is what is stated in the service manual and I suggest to change the power cord before the main PSU (Power Supply Unit)
SC 560 Zero Cross Error
When the power switch is turned on. The machine checks how many Zero-cross signals are generated during 500 ms. If the number of Zero-cross signals is more than 66 or less than 45 and the condition is detected more than 10 times this code is shown.
Cause is electrical noise in the supply from the power cord.
Solution
  • Change to another power wall socket
  • Change power cord
  • Replace main PSU (Power Supply Unit)
I hope this help you
Thanks J
Posted on Jan 13, 2008
STP162
  • 132 Answers
SOURCE: Ricoh AP3800 COLOUR Laser Printer
SC 556 Pressure roller fusing lamp temperature fluctuation
The pressure roller
temperature changes by
±20°C or more in one second.
This occurs three times in one
minute or two consecutive
times.
• Loose connection of
the pressure roller
thermistor 1. Check if the fusing unit is properly set
and connected to the main frame.
• Loose connection 2. Check if the pressure roller thermistor
connector is firmly connected.
between the fusing
unit and main frame
3. Replace the fusing unit.
Posted on Dec 01, 2008
SOURCE: Ricoh 3050 printer, Error 990
We got the same error on our machine, so I called Ricoh Direct Tech Support and they said it is a known manufacturer's error. All you have to do is 1. make sure your product is registered, 2. call them up and tell them the error and 3. they will send you a new machine. You will have to send back the old machine in the same box, but they provide the RMA for you to ship it back in.
Good Luck!
Posted on Jan 09, 2009
  • 393 Answers
SOURCE: Ricoh Service Code error - Service Code SC-300
I am a Ricoh tech and my service manual doesent have a 300 code,
Posted on Jun 18, 2009
Ricoh mp 1600 error 194 ricoh mp 1600 error code 194 how do I solve the problem
Having problems finding your error code. Here is a complete list of all codes for your printer: http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio%20MP1600
I do find the error code for a different Ricoh model (Aficio 1018).
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio%201018
Please verify your model number and error code.
Apr 21, 2015 | Ricoh Aficio Mp-1600 Copier
How to refill ricoh gelsprinter gx2500 ink cartridges
I using gelprinter recoh gx 3050, how i can refill this cartage
any branch in India give me gel ink & refillable cartage
pl. give advice abou
sujitgajre@gmail.com
Nov 08, 2011 | Ricoh Aficio GX3050 GelSprinter
I have a Ricoh aficio 2018D problem is SC390 Code i reples PCU Unit Lower unit/Drum & Developer but sc390 code problem not solw. Please help Me.
The TD sensor is reading an abnormal value, this could happen if no toner is getting into the developer unit or it could be a bad TD connection or TD failure. Would suggest checking to see if the toner supply path is working first.
Check that the toner bottle is empty and most of the toner in the development unit is depleted.Add a new bottle of toner, run a forced toner until it looks good, then run td initialization.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 03, 2011 | Ricoh Office Equipment & Supplies
How to solve error SC452 for colour copier
sc 542 is the fuser error code. please check with a ricoh tech to fix it.
Jan 03, 2011 | Ricoh Office Equipment & Supplies
Error 990 gx2500
This is a known manufacturer error. Call Ricoh Direct and talk to someone in Tech Support. If your product is registered with them, they will send you a new printer. You will have to ship the old one back in the same box the new one was shipped to you in, but they provide an RMA # so there isn't any charge.
plz rate the solution if helped
Nov 16, 2010 | Office Equipment & Supplies
WHAT DOES THE SC 38 MEAN ?? WHAT FAULT DOES THIS SERVICE CODE REFER TO?? I HAVE A LANIER 2138 COLOUR LASER PRINTER, (SAME AS RICOF AP3800 SERIES)
SC is for "Service Call". The error may be caused by a defect or an irritation of internal sensors.
Ricoh recommends to physically switch off the printer, wait for a few minutes and power on again. (Irritation by change in surrounding temperature)
If you recently replaced any movable parts inside, remove it again and reseat, many parts inside are checked by sensors for proper seating.
If this does not help, you need to call Ricoh customer service.
Feb 09, 2010 | Ricoh Aficio 3800CMF Laser Printer
Jun 09, 2009 | Ricoh Aficio AP3800C Laser Printer
Ricoh 3006
go to service program 5-810 ( sc reset) press on, turn off the machine an the turn on again. The service code should be gone, if it come back again check for a paper jammeed or wrapping the upper
fusing roller if this is not the case replace the thermistor;
Good luck
Vittorio
Dec 21, 2007 | Ricoh Aficio Colour 3006 Color Copier
jasbo
jasbo
