Question about Midland 75-785 Handheld CB Radio
Midland 38 plus won't transmit - Midland 75-785 Handheld CB Radio
    Genius:
  • Midland Master
  • 1,795 Answers
Did you check for broken wires to the mic.?
Posted on Jun 22, 2015
3 Suggested Answers
SOURCE: Midland alan 48 plus transmit scale not moving
Sorted now, soldered a new output transistor into the board and all working.
Posted on Dec 12, 2008
SOURCE: hi i have a midland
there is but if u get it wrong then you are stuft. i would just try the earth first cause altho the swr is good if the grounding is poor this will effect sigal.depending on mounting will depend on earth solution
Posted on May 01, 2011
How many watts do midland walkie talkie xt20 have?
These are FRS/GMRS (Family Radio Service/ General Mobile Radio Service) radios. The legal power limit for FRS is 500 milliwatts - or 1/2 watt. GMRS on the other hand is limited to a much higher 50 watt level. The wattage you transmit determines if you need to have a GMRS license. Most GMRS radios are in the .5- 5 watt range however.
The likelihood of your XT20 being a 1/2 watt out on both FRS & GMRS is very good. For Midland (or anyone else for that matter) to produce a radio with a 1 watt output that can run on just 3 "AAA" batteries would be quite the feat! If Midland did do this, the radio's battery life would extremely short. To balance the needs of light weight and battery life, output power needs to be reduced.
Claims of 20 miles is crazy. If you had these radios on mountain tops 20 miles apart - with a clear line of sight between them - MAYBE - you could hear one on the other. This would need to be done under only the most ideal conditions. The actual distance you can expect to get out of a pair of any brand FRS radios in "real world" conditions (line of sight blocked by trees and buildings) is about a mile.
An FRS/GMRS radio limited to 1/2 watt output when used on a GMRS frequency that is close enough to access a GMRS repeater system could easily cover 20+ miles. The key here is having a license and access to the repeater. Repeater owners take a dim view of unlicensed users access their repeater.
Channels 1 thru 7 are FRS and GMRS. That is, if transmitting .5 watts, you can use it as FRS. If transmitting more than .5 watts, you will need a valid GMRS license.
Channels 8 - 14 are expressly for FRS. Only .5 watts transmit power is permitted.
Channels 15 - 22 are expressly for GMRS at any transmit power up to 50 watts. Even if transmitting .5 watts, you MUST have a valid GMRS license on these frequencies.
I know - more infor than you wanted and no vclear cut number for wattage - but there's no info on these radios on Midland's site or anywhere else that I could find. Good luck!
Jun 16, 2012 | Midland XT20 Two Way Radio
I have an almost new Midland 75-822 that the WX works fine on, but the CB doesn't seem to receive, or transmit. It operates normally, but no reception, and no evidence of transmissions.
you'll need a schematic and some knowledge. there a two diodes that control the rx and two that control the dx.Check them to make sure they are producing the correct power out put if they are not you should replace all 4
May 10, 2012 | Midland 75-822 40-Channels Handheld CB...
Will transmit for a while and then quit
Check RF transistor may have leakage, "probably won't show up on a regular meter, carefully inspect board for bad solder connections, buy semiconductor cold spray may help tracking faulty part.
Mar 24, 2012 | Ranger Virage VX-38 Base CB Radio
I have a problem with radio gxt1050, it was functioning correctly, but now I turn on it and the keys not response, no PTT button, but I can hear calls from other radios... tanks
  • It takes a lot more power to transmit than it does to receive. So it is possible to listen but not be able to talk. Make sure that the batteries are charged and that the batteries are holding a charge. When batteries begin to fail they won't hold a charge for long at all.
Regard, Tony
May 06, 2011 | Midland Two Way Radio
Hi i have a midland 38 plus cb but the recieve is poor i have an excelent swr is there anything i can do to turn the receive up inside?
May 01, 2011 | Midland 40-Channel CB Radio CB Radio
Hi i have a midland alan 78 plus multi and it will not receive or transmit ,when you press the ppt button there's no signal strength showing on the display , the power supply is good and worked fine last...
hello there your problem is simple the final transistors have blown as you have no audio an audio transistor is also required best leave it to the pros to repair goodluck
Dec 17, 2010 | Midland 40-Channel CB Radio CB Radio
Dec 11, 2008 | Midland Radio Communications
Midland 75-785 Handheld CB Radio Logo
181 people viewed this question
Top Midland Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
