Question about Kenmore Microwave Ovens
Kenmore mircrowave model 721.66222500 Pretty accurate description from grandson it has lightening in it. Was running when you shut the door and timer at 0. Did not shut off when pushing stop, had to open door. Have had it unplugged for a couple of days. Plugged it back in and heated up a cup of water fine. Is this safe to continue to use? What would cause this problem? Thank you.
MicrowaveSvc
  • 9098 Answers
SOURCE: microwave runs when the door is open.. stops when you shut it.
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
This can be caused by slamming the door or by habitually opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 11, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE JVM240 microwave - shut door, fan runs,can't set timer or cook
The "main" relay on the control circuit board is stuck (shorted) and needs to be replaced.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Dec 02, 2008
SOURCE: Panasonic microwave oven nns952wf runs when door is open
yep going through the same thing myself. I found that the OMRON switch V-16G-3C25-M is bad and now I'm trying to find one. I contacter OMRON but they said the switch can only be orded from panasonic so I'm going that route myself. If I have any luck I will write back.
Posted on Jul 22, 2010
heatman101
  • 43501 Answers
SOURCE: Jvm1870sk04 GE profile microwave will not shut off
Hi, Main control board bad...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Sep 20, 2010
heatman101
  • 43501 Answers
SOURCE: Microwave Model JVM 1870 stopped heating, all else works (timer)
heatman101
ggk
Posted on Sep 30, 2010
Kenmore microwave model 401.85053010 just stopped working because door will not shut and lock. Does the main board have a safety interlock tie-in for the door?
Most Microwaves have anywhere between 3 and 5 switches to monitor if the door is open or closed. They have to act in proper sequence too. It is a safery feature so you can not run it with the door open.
Aug 18, 2017 | Kenmore Microwave Ovens
Why does fuse keeps blowing within mircrowave
Hello friend, thanks for your post!
Based off the information you have provided I understand that your fuse blows every time your Electrolux microwave starts up. It sounds like it could be an issue within the control panel, capacitor, or circuit breaker. Because it could be a number of any one of several underlying causes, I would personally contact a professional to accurately diagnose your microwave to determine the root cause to reduce the risk of unnecessary parts-Matt
Aug 13, 2014 | Electrolux Microwave Ovens
Why does the fan on my Sharp Carosel II microwave continue to run? Model R-8560
From the description one of the door switches is defective, if you have a digital meter then I will walk you through the testing phase.
Jul 06, 2012 | Sharp Microwave Ovens
Kenmore elite microwave 721.80833 stops cooking intermittently
Check the door switches if one is bad it may think the door is being opened and stop the unit from running. If it is from a bad connection it will get worse as it gets hotter while running.
Oct 04, 2017 | Kenmore 80809 Microwave Oven
The light is out in the mircrowave and it does not work. When you enter the time and press start it says "door"
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Our file on door switches is here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Also at our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
You can find helpful exploded view diagrams and order parts by entering your full model number (KBMC140HSS0, KBMC140HSS02, KBMC140HSS03, KBMC140HSS04, or KBMC140HSS05) here.
Sep 30, 2010 | KitchenAid KBMC140HSS Convection/Microwave...
Microwave won't function.
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
Also see http://www.microwavedisplay.com/doorsw.txt
You can usually find exploded views and order parts by entering your model number at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Dec 04, 2008 | Kenmore 63263 Microwave Oven
Microwave Ovens Logo
43 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
