Question about Technics SL-1210 Turntable
Random my 1210 has stopped working, when i turn it on and press start it either turns half a rotation or if its left a min or 2 it starts to spin at abouts 150rpm and dosn't stop when the stop button is prest any ideas?
  • 3 more comments
  • lee_locker Feb 12, 2009
    no, no spills
    i used them 1 friday night they was both working fine then i went to have a mix on the sunday and 1 of them had stopped working
    so i removed the platter & dust cover, changed the fuses but still nothing.
    i tried them 24hours later and at first the deck had a little movement, so i turned it on and off a few times, then left it for a min or 2.
    then it started spinning really REALLY fast and it wouldn't stop so i had to turn the power off at the mains? any ideas???
  • lee_locker Feb 13, 2009
    i did turn the pitch up half turn but i've since reset it.
    the 2 fuses are the same as the 1s i took out, maybe its a problem with the transformer? or the stop/start unit?
  • jon_castle May 11, 2010
    ok well, if the fuses are the same i suggest that you try marking their original position, and the moving them, i would suggest that you play with the pitch resistor also the brake one too... but be sure to mark them so you can reset them acurately.
    let meknow what happens..
    jon
    sounds like you have put the wrong rating fuses i the both should be 250ma. Also did you fiddle with the pitch or brake resistors?
    sounds odd, can you explain in more detail? did you have a spillage on it at any point?
  • 515 Answers
No, this has nothing to do with the fuses. The problem lies with one or a combination of faulty IC's (integrated circuits). More than likely IC201 (Turntable Control IC), but IC101 (Turntable Drive) and IC301 (Pitch Control IC) will also cause this sort of issue.
Also take a look at R213, it generally gets very hot, and you can tell by looking at it and seeing discoloration, and might be the starting point to this mess. It's good to replace this as well, while your at it - however, it is no longer available from the manufacturer, so you'll have to match up the rating for it. In addition, take a look at Q2 and Q3 (Regulators), those also tend to burn out at the same time.
Good luck.
- OPTiC
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Posted on Mar 05, 2009
Why does my top load whirpool washer restart on its own after it finishes the last rinse and spin cycle. It does this on all settings, delicate, normal or heavy.
  1. Turn the washer off.
  2. Set the mode selector dial to NORMAL.
  3. Turn the dial counter clockwise ONE click (LEFT), clockwise THREE clicks (RIGHT), counter clockwise ONE click (LEFT) then clockwise ONE click (RIGHT).
  4. Now press the start button.
  5. All the cycle indicating lights should be illuminated.
  6. Press the Start Stop button once.
  7. Rotate the dial until Rinse, Wash, and Stop light illuminate.
  8. Turn the washer off and unplug it for 10 seconds.
  9. Finally, turn on the washer and it should now be reset.
  10. Run a test load empty to be sure the reset worked. If not perform the reset procedure one more time.
Oct 07, 2016 | Whirlpool Whirpool 3.5cu ft Top Load...
Tip
Sony CX355 skipping Fix
I have a Sony 300 disc changer that started randomly skipping tracks after it was 8 or 9 years old.
I tried cleaning it, no change.
I opened it up and found an adjustment screw on the reading lens carriage.
Note: It is very hard to see
It rotates approx 1 turn from stop to stop. It was centered from the factory.
I rotated it counterclockwise 1/2 turn, and it got worse.
I rotated it clockwise 1/2 turn, and it is fixed. It hasn't skipped a beat since.
on Sep 17, 2008 | Sony CDP-CX300 CD Player
E27 and e95 code
I had this problem. I tried to interupt a cycle just after it started and then couldn't start the cycle again, with the E27 code coming up.
e27 refers to a problem with the door locking mechanism which could be due to a number of causes. The problem I had was with the solenoid in the door, not a genuine problem with the door latch mechanism.
Here is how I fixed it:
(1) Set knob to off
(2) Hold down spin selector and Allergy rinse buttons and turn the knob to the LEFT (right does not work)
(3) The display then shows a number of program codes P01 to P14. (Pressing spin selector rotates through the codes).
(4) Press spin selector until you reach P02 on the display, then press the start button, the door will click and the machine will begin a cycle.
(5) Turn the knob to OFF, and then you should be able to use the machine as normal.
Jul 18, 2011 | Bosch Nexxt 300 Series WFMC2201UC
I have a Maytag Neptune FAV6800AWQ Serial Number
Fireman,
Excellent info wish all post would start off like this. The first two digits of the s/n are your series number a Series 16 machine I’m an owner no expert and will try to help.
I assume you have the Service Manual but just in case.
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
“”I can grab the drive belt and effortlessly move it back and forth-pulley spins and motor spins--Should it move like this?””
There should be slight resistance.
With the front cover off and be careful of the rotating drive belt can you start a Spin Only cycle?
Do you see the Motor rotate the Clutch Pulley assembly CCW? If so the wash basket should spin CCW just raise the washer top and verify the CCW/Spin rotation.
If that works again with the front cover off start a Quick Wash cycle min Soil/Spin settings and observe as the washer. As it fills the wash basket will be rotating CCW don’t raise the washer top to high or you will spray water around.
After the water fill the washer will start to Wash/Agitate. The Motor will rotate the Clutch Pulley CW and the Tumblers will rotate. Do you see this action.
You can go into Service Mode with this procedure and dump the wash water if the cycle fails with this procedure.
I would go to page 16 of the SM lower right hand part of page, Board Output Test and turn on the drain pump in service mode to pump out the tub.
Enter Service Mode by simultaneously pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
Pressing the Delicates key will lock the lid. Now press the Presoak key the drain pump will turn on. Stop with off button or hit the Presoak key.
Thank you again for the Model number and Serial number…. other readers this is how you post an issue.
Waiting for your feedback………Rich
Apr 12, 2010 | Maytag Neptune FAV6800AW Top Load Washer
14 cycle front load washer fridgidaire
press cancel. (turns off washer)
press start/pause (wake up)
hold cancel and start/pause 10sec
last error code will come up.
E47 door lock error
check wires connections to the door lock..
replace door lock..
hope it helps
Aug 08, 2008 | Frigidaire ATF6000ES Front Load Washer
Mind of its own
THE ONLY RESET IS TO UNPLUG IT FOR 15 MIN. SOUNDS LIKE MAIN CONTROL BOARD BAD
Oct 16, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Sometimed error being displayed but also not completing cycles and not performing a fast spin
Hi there, I've also had this problem a few times. I've found cleaning out the filter can help solve the problem of the E20 message. Also when it doesn't spin fast it usually means the load is uneven. I found it happens with towels or bedcovers, heavier loads, if the load is uneven it will spin slowly for a good few minutes and then just stop with the clothes still dripping. I found rearranging the load more evenly usually sorts it out. I've had my machine for 18months now and usually love it. It washes and dries well, however, my dryer has stopped working again! I'd only had the machine 7 months when the dryer first stopped working another 11 months down the line and it's not working again! Hope this helps. Lelly2003
Oct 27, 2006 | Zanussi WJD1667W Front Load Washer / Dryer
Technics SL-1210 Turntable Logo
757 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
