Question about Western Digital 160GB MyBook Essential Edition 160 GB USB 2.0 Hard Drive
How to open files on WD external hard drive?
Drive is 160 gigabytes. Did not receive info re how to open a file.
  • Anonymous Mar 11, 2009
    When i plug my WD i dont find it in my computer ?? before it was working but now i dont know what is the problem ???????!!!
You have to find it first by directing windows to the file . Right click MY Computer select explore select the drive letter C is your internal hard drive D is usually your CD/DVD.One you find the file double click on it . It will open with what ever program is associated with it
Posted on Jan 25, 2009
WD External Hard Drive Passport Ultra Beginner's Questions
Usually with an external hard drive it's not necessary for it to copy over an existing backup or at least you can program your PC not to do this. What will happen is you will have several different copies of backup's and you will have to decide if you want to erase the others and keep the most resent one. Yes your file will be saved withing the backup but if you change the file name it will file this as a new file
Sep 28, 2015 | Ultra Computers & Internet
Why can't I access any of the files on my WD Elements external hard drive?
If you have not reinstalled a new OS the drive should be seen after starting your unit.
Disconnect the USB drive and reboot your unit.
After the unit comes up, plug in the drive.
If the drive is new to the system, it will locate and load drivers.
Afterwards it should give the opium to view files.
It should also be seen in your device manager, under disk drive.
You should be able to go to prosperity's and see sharing opium's ect. ( Security ) Try to make your changes here
May 20, 2014 | Western Digital 2TB WD ELEMENTS USB...
Does not allow transfer of files or pictures
Plug the external hard drive into your laptop or desktop computer.
Most external hard drives do this through a cable connecting the hard drive to the USB outlet on a computer.
Plug your external hard drive into a wall outlet if it receives power from an AC adapter rather than your computer.
Click on the "My Computer" icon on your desktop, and open the external hard drive.
It will be located under the USB connecting drive, which is labeled with a letter ranging from "E:" to "K:".
Open the folder on your external hard drive where you would like to save the photographs.
usually in my documents my pictures or if you want to save them to a specific spot so as not get them mixed up.
Create a folder if one is not present right click in my documents select new folder and name it lets say my pics 1
Move this window to the bottom right corner of your screen to be used in future steps.
Open the folder on your home computer where the files are being stored that you wish to transfer to the external hard drive.
These may be on the desktop, in "My Documents" or elsewhere in your computer.
If you are unsure where they are located, you can always search for them by file name by going to "Start" then "Search."
Right-click on the photo file, and select "Cut."
Click on the window showing your hard drive files to bring it into use on the screen.
Right-click on the white space in the window where you would like to transfer the files, and select "Paste."
Your files have now been deleted from their original location and transferred to your external hard drive in the folder you selected
hope this helps
Sep 27, 2012 | SimpleTech Signature Mini 160GB External...
WD essential 1tb I cannot open the software on my laptop. A window pops up saying WD has encountered a problem & must close program, send or don't send option is all. How can I access my Passport? It...
Hi: That portable hard drive is USB 2.0 is the port on the laptop USB 2.0 can you use a memory stick to transfer files from the one lap top to the other lap top then on to the external drive.
Mar 16, 2011 | Western Digital WD My Passport Essential...
Hi! I stored files, docs, and pics, on my Verbatim Ext. Hard Drive USB 2.0 awhile back. I now want to update it. When I go to "shortcut to Verbatim" I get a Nero BackItUP Archive File page. When I...
Connect the external drive.
Open 'My Computer'.
One of the icons should be associated with the external drive.
Double-click the icon to "open" the external drive, to show the files/folders on the drive.
Oct 05, 2010 | Verbatim External, USB 2.0, 750GB...
Unable to access files
To access the files off the hard drive another way - remove the hard drive from the case and connect it to an USB hard drive adapter and then plug it into a working computer's USB port. If the computer see the hard drive as an external hard drive/storage device and you can open the folders and files then backup your data. This also indicated the hard drive is OK and the Western Digital case/electronics is faulty.
To use this as an external USB hard drive, put the hard drive in an USB adapter case.
Sep 09, 2010 | Western Digital 320GB MyBook External USB...
Accidentally deleted files from My Book - possible to recover?
These two articles recover WD Mac and restore Trash Mac may worth for a glance. But the first thing you need to take care is do not put more items to your WD drive where those stuff originally located. Best regards.
Sep 24, 2009 | Western Digital My Book Essential Edition...
External imation hard drive showing an empty folder !
You can run a data recovery app on the drive and attempt to pull offany data still accessible. I recommend the GetDataBack Data Recoveryapps from http://www.runtime.org . Get the one for the file system on your thumb drive and give it a try. These apps have recovered data from "dead" drives for me more times than I can count.
Aug 24, 2009 | Western Digital My Book Essential Edition...
External Hard Drive will not show up. Tells me to format it.
I have a Western External Hard Drive 320 and when I plug it in the computer will recognize it and allow me to access my files but after a short while if I go to click on a file t open it the WD 320 will click off for a minute and then reappear in the auto run mode.
Jun 20, 2009 | Western Digital Passport 320GB External...
Cannot open file due to I/O device error!!!
dont worry, you can recover files from WD external hard drive, you need to follow the correct steps, here's a perfect data recovery tutorial for you
Recover files from External Hard drive
The tutorial is very easy to follow as I followed it to get back my files.
Apr 06, 2009 | Western Digital Passport 160GB External...
Western Digital 160GB MyBook Essential Edition 160 GB USB 2.0 Hard Drive Logo
1,848 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
