Question about John Deere 8870 4wd Tractor 1993 Ertl 116 5462
Jd 8870 will not start or run
Jd 8870 quit and will not run
I have JD 935 that runs fine for 10 mins then idles down. Never fully quits running. Changed fuel filters, lines, pump...
check for the cooling fins around the head and block are not blocked with grass clippings/ dirt/dust as it may be tending to overheat and boiling off the fuel in the mixture
Sep 16, 2014 | Cars & Trucks
Xerox problems
Hi Anonymous,
I suspect your question has answer by now.
If not, just visit the www.xerox.com website.
Regards.
Jul 29, 2014 | Xerox STANDARD CAPACITY MAINTENANCE KIT...
New holland 8870 tractor fault code f312 what does it mean
http://tractor-manual.org/store/products/new-holland-8870-tractor-service-manual-download/
May 21, 2014 | iPhone Apps
STX38 mower wont' start
Have you checked the output of the alternator.
got a ohm/volt meter? or a battery tester?
should be putting out 14 volts. may be the voltage regulator.
start there esp if you charge the battery and it runs for a hour.... hour and 1/2 then quits.
Jan 13, 2018 | John Deere 420,1020,2010,2020,2510,2520...
Need the instructions for using the Vosonic VP 8870
I can help you with your Vosonic VP-8870.
The manual, firmware and instructions are available from the manufacturer's website.
I hope that helps.
Mar 13, 2011 | Cameras
My JD X475 will run start and run fine for about an hour and then quit. The fuel filter is empty then. If I let it sit for about another hour it will start and then do the same. Could it be the electric...
Fuel pump could be getting weak, however I recommend to check the vent on the fuel cap. I have seen this many times with the JD machines. The tiny hole in the middle of the fuel cap gets clogged with debris and won't vent, causing the engine to vapor lock. Next time you have this condition, with the engine off, remove the cap for a few seconds and try to restart.
Sep 09, 2010 | Garden
My JD riding mower just stopped during a recent mowing
There was a time when my JD just quit and did nothing. After doubting the battery that is what it was-the battery. Jump start your JD and if it starts up then your battery needs replaced.
Oct 20, 2009 | Garden
Engine quites
Next time the mower quits, immediately unscrew the gas cap and try to restart it. If it runs straight away without a cap, you've found the problem - a clogged gas cap vent.
Clean the vent and you'll be able to run with the gas cap in place.
Good luck !
Marco
Jun 17, 2009 | Garden
John Deere 8870 4wd Tractor 1993 Ertl 116 5462 Logo
44 people viewed this question
Top John Toys Experts
Vernon Taylor
Adam Fjeld
Adam Fjeld
Are you a John Toy Expert? Answer questions, earn points and help others
