Question about Toshiba Satellite L645d-s4056
How to start for wireless - Toshiba Satellite L645d-s4056
  • Toshiba Master
  • 27,725 Answers
Power on the laptop computer and wait for the operating system to boot. Right-click the wireless Internet icon in the lower right corner of the desktop. This brings up a new pull-down menu. Select "View Available Wireless Networks." This brings up a selection of different possible Internet connections that are in range of the computer. Select the wireless Internet connection you want to use. If a password is required, you need to type it in now. Wait for the laptop to connect to the Internet. In a moment the computer is going to state it has successfully connected to the Internet. click Start, Run type in cmd and click Ok to bring up a command prompt. Type ipconfig /all and press enter and see if it gives you an IP address similar to 192.168.1.100. Check your wireless connection properties under My Network Places. Right click the wireless connection icon and choose properties. From there make sure Internet Protocol {TCP/IP} is listed, highlight it and click properties. Make sure Obtain an IP address automatically is checked and Obtain DNS server address automatically is checked. Make sure you Ethernet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabled if still no joy Let's first try to start the wireless service i.e. WLAN AutoConfig service manually. To do this, login to the computer as an administrator.
1. Click Start, type services.msc and hit enter.
2. Locate WLAN AutoConfig service, double click on it to open its properties window.
3. Under General tab, change the Startup type to Automatic and click Start button.
4. Click Apply and then ok. For more information about the wireless settings, check this link: http://technet.microsoft.com/en-us/library/bb878035.aspx Hope this helps.
Posted on Jan 16, 2013
D link adapter losing signal
Wireless Zero Configuration is a Windows service on Windows XP and Windows Server 2003 that is used to configure and manage wireless network connections on a wireless adapter. The service name for Wireless Zero Configuration is WZCSVC. On Windows XP, the display name for the WZCSVC service is Wireless Zero Configuration. On Windows Server 2003, the display name for the WZCSVC service is Wireless Configuration.
The Wireless Zero Configuration service is normally started at boot time. The programming interface for the Wireless Zero Configuration service can be used only if the Wireless Zero Configuration service has been started. If the Wireless Zero Configuration service is not started, then the Wireless Zero Configuration functions will return an error.
To enable the Wireless Zero Configuration service so it starts up automatically, go to the Start button. Select the Settings option and then select Control Panel. If you are using the Windows XP view, select the Performance and Maintenance category and then select Administrative Tools. If you are using the Classic View, then select Administrative Tools. Click the Services icon in the left pane. Click the Wireless Zero Configuration icon in the right pane and change the Startup Type dropbox to Automatic. This setting will set the service to start automatically at boot time. Then click the Start button to start the Wireless Zero Wireless Zero Configuration service and click the OK button.
The Wireless Zero Configuration can also be started and stopped from a command prompt. To start the Wireless Zero Configuration, run the following command:
net start wzcsvc
To stop the Wireless Zero Configuration, run the following command:
net stop wzcsvc
Apr 10, 2013 | D-Link Computers & Internet
Wmp55ag cannot associate with access point
Enable the Wireless Zero Configuration service so it starts up automatically, go to the Start button. Select the Settings option and then select Control Panel. If you are using the Windows XP view, select the Performance and Maintenance category and then select Administrative Tools. If you are using the Classic View, then select Administrative Tools. Click the Services icon in the left pane. Click the Wireless Zero Configuration icon in the right pane and change the Startup Type dropbox to Automatic. This setting will set the service to start automatically at boot time. Then click the Start button to start the Wireless Zero Wireless Zero Configuration service and click the OK button.
Jan 30, 2013 | Linksys Dual-Band Wireless A+G PCI Adapter...
Advanced configuration settings for the Belkin wireless G Plus mimo network adapter
Jan 22, 2013 | Belkin F5D9050 Wireless G Plus MIMO USB...
Why does my laptop not even show any view wireless networks
Hello Sarah,
I suspect that your Wireless Zero Configuration is turned off.
What I would suggest you do is that:
Click on start, click on All programs, click on accessories, then select Run, On the prompt that comes up, type the following:
1.) sc.exe config WZCSVC start=auto
2.) Next, type: net start WZCSVC
This should reset your Wireless Zero configuration and also start the wireless connections.
Kindly let me know how it goes after you have tried this.
Goodluck and thanks for using Fixya.
Jun 05, 2012 | E-Machines Computers & Internet
Have been working with att tech to enable for wireless and cannot get this to do anything
Are you able to see any available wireless networks?
Make sure the wireless radio is on, the wireless switch should be located above the keyboard, it has the picture of a satellite.
May 05, 2011 | Acer Aspire 4720 Notebook
I have a acer 6930 that keeps losing wireless connection when everything else in the house is still working
Configure Windows to manage your wireless network by right-clicking the wireless network icon and select view avalable networks... then click change advance settings... then click the wireless tab... If you don't see a wireless tab, then close it and click start then run and type service.msc and press ok. doublde-click the wireless zero configuration and set it to automatic then click start to start the service. then do the first few instructions until you see the wireless tab. Bullet-mark the "Let windows manage wireless network" then click apply or ok.
Try to reconnect to your wireless network and you should be able to maintain your connections wirelessly.
Jun 09, 2010 | Acer Aspire 6930-6771 Laptop
Cannot get on the internet because of article 871122
This behavior occurs for several reasons. Some computer and hardware manufacturers provide their own configuration software that replaces the Wireless Zero Configuration service that is provided in Windows. In that case, you must use the software that is provided by the manufacturer to configure your wireless network. If you want to use the Wireless Network Setup Wizard or the View Available Wireless Networks feature to configure your wireless device, see the documentation that came with your computer or with your wireless network card. Use this documentation to determine whether you can use the Wireless Zero Configuration service to configure your wireless network. Sometimes, you cannot use the Windows functionality.
If your computer or your wireless network adapter did not come with its own wireless network software, follow these steps:
  1. Click Start, click Run, type ncpa.cpl, and then click OK.
  2. Click Network Connections.
  3. In Network Connections, click to select your wireless connection, and then click Change settings of this connection.
  4. On the Wireless Networks tab, click to select the Use Windows to configure my wireless network settings check box.
To start the Wireless Zero Configuration service, follow these steps:
  1. Click Start, click Run, type %SystemRoot%\system32\services.msc /s, and then clickOK.
  2. Double-click Wireless Zero Configuration.
  3. In the Startup type list, click Automatic, and then click Apply.
  4. In the Service status area, click Start, and then click OK.
Jun 01, 2010 | Toshiba Satellite A105-S4344 Notebook
No wireless access
On Windows XP :
Click on start >> go to control panel >> double click on network connections >> right click on wireless network connection and click on properties >> click on wireless networks >> check the box that says ”use windows to configure my wireless network settings” and click OK >> right click on wireless network connection again and click on view available wireless networks. If you see your network name then click on it and click connect >> enter password if configured and click OK.
Note : If you don’t see wireless network tab under wireless network connection properties then follow below steps.
Click on start >> click on run >> type services.msc and click OK >> scroll the right side window down to wireless zero configuration >> double click on it >> start up type should be set to automatic and service status should be started (In case if it is different then change the settings) Then follow the above mentioned steps to look for wireless network tab and follow further.
On Windows Vista :
click on start >> go to control panel >> double click on network and sharing center >> onto left, click on connect to a network. If you see your network name then click on it and get connected.
[Note : If you don’t see any network name and wireless switch is turned on then follow the below mentioned steps]
Click on start >> click on run >> type services.msc and click OK >> scroll the right side window down to WLAN Auto configuration >> double click on it >> start up type should be set to automatic and service status should be started (In case if it is different then change the settings). Then try to connect to your network again.
May 19, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
Wireless connection
Hi Kazmerr
Re: Dell Latitude d600
Assuming you already turned your wireless, your distance should be in range fom your router. Turn off and on the switch  or you can press Fn+F2 to start your wireless connection.If thats a no go check your wireless client  and make sure no other wireless client is installed ie. your ISP wireless connection manager.
Other work around for this is : make sure you have enabled or started your wireless client for windows by ff the steps below :
Win XP Sp2: start > control panel  classic view> administrative tools > services > then look for Wireless Zero Configuration and right click it and choose start or restart . After doing this you may check or view your available wireless network again.IF no go >
For winXP or VIsta ONLY
Go to start > control panel   { classic view } > system > device manager > Look for network adapter {+} sign > look for 802.11g wireless / or anything that says 'wireless' and make sure that theres no yellow question or excamation mark on it and IF none right click it and choose remove/uninstall> then restart PC > and try to view avaialable wireless again by ff the steps above.
{ tthis will refresh your wireless network hardware and software}
Note: for yellow exclamation marks or questions marks on your wireless adapter you MUST reinstall your DEll Wireless adapter. using you DELL System Recovery Disk.
In most instance it has somthing to do with your wireless switch on your laptop. With all possible steps porvided above doesnt woprk pls notify me. Thanks and good luck.
Jun 11, 2008 | Dell Latitude D600 Notebook
Dell wireless software is preventing me from using windows wireless software
do not worry about it, to start windows,
click start > run > type services.msc and click ok
you would be in the services page, scroll the page to the bottom, and from the bottom 3rd option, you would find wireless zero configuration, open it and start the service, and click ok, and now richt cick yoyr wireless zero config icon, click view available wireless networks , click change the order of the preferred networks, and under the wireless networks tab, select use windows to config your wireless network option, and click ok, tat would start windows,
check it out, for any more qurreies, revert back
Dec 08, 2007 | Computers & Internet
Toshiba Satellite L645d-s4056 Logo
60 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
