Question about Maytag Legacy Series Top Load Washer
My Maytag Legacy SAV515DEWW does not drain and spills over..
About 3 weeks ago my maytag washer stopped working. I checked it and the belt burned up. So I went ahead replaced the belt and the pulley. Belt started to spin sort of slowly and then it burned again during the first wash. Not only did the belt burn but water was on the ground since it was not draining.
I decided to remove the brakes and replaced the belt again. Now the machine is spinning extremely fast but obviously will not brake which is fine for now but the machine will still not drain.
Yes I checked the drain hose since when I first took the motor and belt out I had to remove the hose and water came gushing from there. There are no kinks in the back of the machine.
So I called the repair man and asked him for his suggestion and he said the machine needs its brakes in order to drain. So I went ahead and ordered the brakes and they should be here by tuesday. Now I hope that is it but I do not know I am hoping that any of you experts could help me with other suggestions.
  • 1 more comment
  • dynasty69 Feb 17, 2009
    Thanks for your reply. So the issue was 2 things. The inside of the water pump was stripped so that was the reason why the water was not flowing through. once I installed the New Pump and the New brakes. The washer is running perfectly.
  • curry11 Apr 20, 2009
    Washer just up and quit pumping water. Washer is not even two years old. I guess Ill be replacing a pump. This sucks!
  • GenWinn May 05, 2009
    My washer is spinning but not draining. I replaced the belt but is is still not draining. What next?
    President:
  • 1,214 Answers
Well, turn the water off, install the old brakes (or wait for the new), and run the unit through a cycle (without clothes) to pump all the water out.
With the new brakes installed, and the drum empty of water, turn the water back on, run the unit through a cycle to confirm all works properly. If not, make the additional needed repairs before proceeding. If it works fine, then your good to go and start washing clothes again.
Posted on Jan 24, 2009
  • Mark Egan Feb 17, 2009
    Great! Glad you got it running!
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
During wash cycle of my Maytag Legacy SAV515DEWW, tub moves freely and after spin cycle, tub keeps spinning for a while.
Maytag has a drum brake located on the bottom of yor machine. You need to remove the brake and clean it up or perhaps replace the device.
Google Maytag washer drum brake for several "how to"sites
Nov 30, 2014 | Maytag Washing Machines
MAYTAG PERFORMA MODEL# PAV2300AWW, REVISION#12, SERIAL#12296390ZM Washer filled but made loud grinding sound while agitating. I couldn't drain water on spin cycle. Now it has stopped working, I smelled...
hello you need to change drum rollers but if u remarked water dawn the washer and burn smell it could be the motor OR THE BELT because when the drum stop turning or turn slowly the motor turn fast on the belt when spin time it make this smell .
Sep 11, 2010 | Maytag Performa PAV3200
The grinding (bearing) noise on "spin", now leaking rusty water under machine... 3 1/2 years old "Legacy" ??? NOT !
maytag has rear rollers and front drum glides when goes out sound like sand paper scratching, also inspect belt idler same noise
Aug 14, 2008 | Maytag Legacy Series Top Load Washer
Maytag washer
replace the micro switch and your problem is solved.Its a very small switch right next to your door switch and fuse.It has 3 wires and must be replaced to fix this problem.
May 22, 2008 | Maytag Legacy Series Top Load Washer
Maytag Legacy top load washer is SMOKING!
this is a bogus website that is trying to push smelly washer product....no real fixes and there are other products out there for less just use bleach first
May 05, 2008 | Maytag Legacy Series Top Load Washer
Maytag washer repair
I had the repair guys out 3 months ago maytag paid for labor I paid $150 for seal and bearings, tub froze and belt broke. the tub now is making the loud screams that others complain about I contacted maytag and reapir servce and talked with the tech. this machine is a piece of S$%^ the seal fails on a regular basis and bearings get water in them. I just missed my 3 month waranty and will not pay for that repair again. people at home depot agree that this machine is trouble. the machine must be taken completely down from the top to replace the bearings and or the belt. the tub must be removed. If you call maytag they will pay for the labor but not the parts.
Jan 06, 2008 | Maytag Legacy Series Top Load Washer
My washer will not spin off the water
Check the drain hose and make sure it is not plugged or kinked. Check as well that pumps spins. Good luck
Aug 19, 2007 | Maytag Legacy Top Load Washer
Washing Machines Logo
367 people viewed this question
Top Maytag Washing Machines Experts
Richard Roth
Richard Roth
Bill Long
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
