Question about KitchenAid 24 in. KUDI01TJ - Multiple Color Built-in Dishwasher
Water inlet opening dishwasher kitchenaid
Clean water inlet opening. how do you remove
  • 2 more comments
  • joe merigold Jul 13, 2007
    it seems now like I'm not getting enough water to wash the dishes. Dishes stay dirty, and the dtergent is hardly used. The last attempt had a little water on the bottom of the top and a code 72 on the readout.
  • joe merigold Jul 19, 2007
    I'll start again. Dishes weren't getting clean. Thought it was a water problem. I replaced the fill value. I also removed the lower spray arm to inusre nothing was blocking the impellars. Also cleaned the side inlet. Now when I start the machine, water fills, then heats, then nothing. Sprays arms don't work. They did beofe I started this process. What could I have damaged when removing the lower spray arm and screen to cause this?
    Tried it again. After the fill cycle, you hear a click. then there is a humming sound like a motor wants to run, but does not. Probably the spray cycle. I put it back the way it was. The sprays were working before I started all this, so it would seem it was something I did.
  • joe merigold Jul 21, 2007
    I've included the detailed description. Can you help?
    Novelist:
  • 159 Answers
I would like to help you but I really dont know what type of problem you are having. If you couold give a more detailed description of your problem I may be of help to you.
Posted on Jul 13, 2007
Not cleaning properly, and Water will not drain out. However when we pull the house out the water does drain. Assuming pump? KUDV24SE Kitchen Aid Built In
During normal operation the outlet hose should be higher than the outlet nozzle, if the water drains when youremove the hose it means that the pump is not working, open the bottom of the machine and remove the inlet side pump hose and check for any obstruction, clean and replace the hose. If this does not work you need to replace the pump.
Jun 02, 2011 | KitchenAid 34 in. KUDV24SE Built-in...
About 7 or 8 minutes after setting my dishwasher to run a "Normal" cycle, I noticed that it didn't sound right. The Sensing light and the Add a Dish light were both on. I hit cancel and opened the door to...
Check inlet water flow to your machine. Try pouring water manually
in the wash chamber. If machine works OK, it is inlet water problem.
Remove the hose and watch for free flow.Clean the strainer attached
to the machine. Beyond this point you can contact repairman!
Sep 21, 2010 | KitchenAid 24 in. KUDP01IL - Multiple...
KitchenAid Dishwasher Leaking
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Jul 16, 2010 | KitchenAid KUDC25CH Dishwasher
KUDS01FLSS0 Dishwasher - tub slwoly filling with
Slow fill of water is due to the strainer clogging. Strainer is located on the body of the machine where the inlet water hose is connected.
Clean all the water flow tubes in the machine.Clean the solenoid valve opening also.
May 26, 2010 | KitchenAid 24 in. KUDS01FLSS Built-In...
Lack of water
First close the main water tap. Then the following.
Check the water inlet hose at the washing machine entering point. You can turn the knob and remove the hose. You will find a strainer attached to the inlet pipe. pull it out and clean the strainer. Replace it the same way. Do not miss the rubber parts. Do not forget to open the tap.
Apr 15, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
My dishwasher is not washing the dishes it acts like there is no or not enough water coming out, the supply line is new and good water pressure going in just not coming out
Water inlet valve not opening all the way. Water should go up to about the heating element. Let dishwasher fill when it goes to the wash cycle open the door to stop it and see how high the water level is. The water inlet valve may have a screen on it that you can clean out. If the water is not high enough and the water inlet is not clogged up replace the valve. If the water is high enough several other things to check.
Feb 26, 2010 | KitchenAid Dishwashers
Dishwasher makes grinding noise during wash cycle (after pre-wash). noise persists for 15-20 minutes. It seems as though the inlet valve doesn't open during this phase of the cycle. adding water to the...
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it. When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it. Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Nov 19, 2009 | KitchenAid Dishwashers
Dishes not coming out clean
Nov 12, 2008 | KitchenAid 24 in. KUDP01IL - Multiple...
Dishes not clean
If your dishwasher is cleaning poorly, check these:
Water-inlet valve
Internal filters
Drain valve
Spray arms
Water temperature
Detergent cup
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Apr 04, 2008 | KitchenAid 24 in. KUDP01IL - Multiple...
KitchenAid 24 in. KUDI01TJ - Multiple Color Built-in Dishwasher Logo
169 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
