Question about KitchenAid Ovens
There is a yellow adhesive-like substance coming from both sides of the bottom rack
The oven has a microwave attached on top. The yellowish substance appears to be a glue or something which is coming from the wheels on the bottom rack but only on the front wheels.
  • 1462 Answers
SOURCE: neff u1721 fan door problem
yes it is a heat resistant adhesive and ive never had any success in regluing them
Posted on Jul 06, 2008
vitg55
  • 78 Answers
SOURCE: My GE Microwave/Oven Combo Unit JKP85B0A3BB has a melting chamber
It is one unit. You can not replace just a microwave.
Posted on Dec 01, 2008
rablack66
  • 48 Answers
SOURCE: GE jkp85 Microwave oven appears to be working
Most likely related to magnetron and diode this is for qualified tech to do only.
Posted on Nov 13, 2009
TheMobilian
  • 8220 Answers
SOURCE: Double wall oven Model Number
The probe might be out of spec and therefore the control is not getting a correct reading and thinks everything is fine. That probe is also known as a sensorthemobilian_437.jpgthemobilian_438.jpgthemobilian_439.jpgMight just be corrosion in the sensor's connector. Sometimes bypassing it entirely fixes the problem. Now about the steaming issue:
Convection motor not circulating the air properly?
I would check that.
American oven fault codes and manuals HERE
Posted on Dec 14, 2010
SOURCE: RE: GE cooking center microwave JKP85 - there is
I have exactly the same problem. I take it no one has offered a solution to this. Don't know if this is a lining coming loose and potentially dangerous. Anyone know?
Posted on Jan 31, 2011
How to change lower element in DeLonghi Airstream Convectio Oven
  • How to change lower element in DeLonghi Airstream Convectio Oven??
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Oct 28, 2017 | DeLonghi Ovens
    How do i fix an oven that bakes unevenly
    the cooking I can't help with, but the oven I can.
    sounds to me like the bottom element or what controls it is not working. the reason the ones on top are cooking is that the top element is coming on and browning them on top after the heat has made the dow rise and cook.
    so essentially everything is cooking from the top down. so when the temp drops its using the top element to heat with and thus browns the top rack.
    check ur elements to make sure both work, if so, move on to the thermostat which I have to be the culprit many times.
    Feb 26, 2015 | Ovens
    Whirlpool oven wont start, is there away to light the pilot?
    You don't say what model you have. That being said, I highly doubt it uses a pilot light. It most likely uses a glow bar igniter to ignite the gas. Take the bottom of the oven cavity off (remove the racks and you'll see a couple screws in the back on the bottom. Remove those and the bottom of the oven cavity should lift up).
    Once you have the bottom cover off, turn on your oven and watch the glow bar. If it glows bright white, it's good and your gas valve is most likely bad. If it doesn't glow at all, or it's not very bright, or it has one bright white spot on it and the rest of it looks a little yellowish orange, then you need to replace the glow bar igniter.
    Anyway, that's where I'd start.
    Nov 04, 2014 | Whirlpool Ovens
    I removed all the racks from my upper oven (including the side racks) to self-clean and am getting the "remove racks" light. I've cleaned the oven before and never had this happen. The...
    There is a button on the top receiver bracket on the left side... when you take the rack support bracket out you will see it. Take a damp sponge and go over that area, pressing the plunger/button in several times. That should do it. Sometimes grease build up can prevent the button from popping out all the way, so the oven thinks that the racks are still in there.
    Aug 21, 2011 | Electrolux ICON Designer E30SO75ESS Oven
    Baking on two racks - whenever I try to bake cookies on top and bottom racks, the lower tray does not bake anywhere NEAR as quickly....should I be able to bake evenly on up and down racks?
    Two racks never bake as evenly as one unless you use the fan inside the oven if you have one...The fan will also shorten the baking times...
    The other thing that I would check is to make sure that the lower element in your oven is not blown and you are heating with the top element only...
    Oven Problems Electric Oven is Heating Slowly or Poorly
    heatman101
    Oct 02, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
    How do i replace the cooktop light bulb in my microwave oven?
    I realized the light bulb was fixed using an adhesive (maybe a glue stick) that is why, I had a hard time removing the old bulb. After forcing it (and breaking the adhesive seal) I was able to replace it with a new one.
    Oct 06, 2009 | GE Ovens
    KitchenAid Oven Temp.- Bottomside of Pizza or Cake stays uncooked
    I have a 2yo Kitchenaid oven, and my advice is first, don't use convection for cakes or pizza. Use the thermal oven. For pizza preheat to 500 degrees, then put the pizza on the lowest rack, and bake for 7-8 minutes.This way the bottom browns, and the top doesn't get broiled from the top element coming on during the bake cycle.
    As for cakes, again place them on the low rack so that they get bottom heat. I keep my eye on the oven and when the broil element comes on I stick a piece of foil over the cake until it goes off. Otherwise it will set the top and the cake won't rise as much. Even doing that cakes don't rise as much as they did in my old oven, and they brown too much on top.
    The convection oven does a good job of cookies, and the broil mode is okay.
    I wish I hadn't bought this oven, but I didn't know about the upper (broil) element coming on during the bake cycle until I'd had it for awhile, and it was too late to return it.
    If anyone's shopping for an oven, ask questions, and don't get one that maintains the oven temperature by activating the broil element when baking.
    Jun 24, 2009 | KitchenAid Architect ® II KEBS208S...
    Model # mgr6775ads top oven does not come on.
    I am not quite sure I understand what is not firing, but looking at the wiring diagram, I would suspect that there is a bottom burner in your top oven that is not firing.
    From what I can see in the wiring diagram, the problem is going to be one of two things:
    1) The top oven sensor (although it doesn't make sense that the broiler work's with this bad.), or
    2) The board is bad.
    I assume your measuring voltage to ground or neutral, and measurement points on the valve for S7 are the same as they are for S6. You can trace the Red and Yellow wires back to the control board. Do that, and confirm whether there is voltage to the yellow wire.
    I would guess that the door switch is good on the top oven as well, because the broiler burner works.
    Jan 14, 2009 | Maytag Ovens
    Electrolux Icon Oven won't self clean - "Remove Racks" displayed
    I was getting the remove rack error until I finally figured out what it wanted me to remove. When you say you removed the rack supports, do you mean just the sliding parts or the whole side metal rack support? At first I thought they were bolted in, but I read somewhere that they come out, too. Upon further investigation, I found the rack supports just slide into the side walls at 4 points. I had to use a little force to pull them out, but they came out and my oven is self-cleaning as I write this. I just thought I would share in case you or others haven't figured it out yet. Now I will just have to see how hard it is to get them back in...
    Nov 01, 2008 | Electrolux ICON Designer E30SO75ESS Oven
    Neff u1721 fan door problem
    Nov 06, 2007 | Neff U1721 Double circotherm Electric Oven
    Ovens Logo
    37 people viewed this question
    Top KitchenAid Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
