Question about Electrolux Band Aerus Lux Legacy Canister Cleaner
Reset buttton location
No power
    Problem Solver:
  • 15 Answers
The reset button for the power nozzle in on the top of the housing just to the right of the wand to tool connection. As for the tank; this is more a guess than an answer: There is a small hole at the bottom of the bag compartment. I wondered if that was a reset button, but the manufacturer recommends disconnecting the machine until it cools down and resets itself.
I know it is not much help. Electrolux Aerus does not want customers to repair their own equipment, and they will refuse to give out information.
Posted on Jul 22, 2014
  • Barbie KingScott Jul 25, 2014
    Many thanks to all those Aerus-Electrolux (any model) canister vacuum cleaner access. To open the clamshell to access the guts, all you have to do is use a small wood block and a hammer. (1) Disconnect the vacuum from the power source. (2) Remove the hose, take the bag out of the tank. (3) Leave the bag access open. (4) Lay vacuum on either side. (5) Place the wooden block against the tank just behind the rubber bumper at the back end of the vacuum. (6) Firmly strike the wooden block maybe a couple of times until the bumper assembly slides toward the open tank at the hose end of the vacuum. (7) Turn the vacuum to the other side and repeat the process.
    Here is one of the sources I found and used: http://howtomendit.com/answers.php?id=64... Note: Aerus-Electrolux all have the same access. It worked!
Reset engine indicator light
1. With the Car Off, Press and hold down the Odometer Trip Reset Button. 2. While still pressing the Trip Reset Button, Turn the Ignition Key half way on where all your oil, check engine lights etc.. turn on. Don't turn it as far as you would to normally start the car. Wait a few seconds and the Check engine light will turn off. 3. Turn the key back to the Off position and you're done.
(source: Yahoo Answers)
Feb 08, 2014 | aFe 2004 Honda Accord - 3.0L V6 - Air...
Reset oreck XML professional
The reset button is power button,look at what it says under cell check button, hold(symbol) button t reset.
Jan 27, 2013 | Oreck XL® Air Purifier
Need to reset my homedics hepa air cleaner
Press the lit reset button indicator and hold it for some time (I think it's like 5-6 seconds at least)
Oct 24, 2011 | Homedics AR10 Air Purifier
After cleaning unit, cannot get "perform cleaning"
As long as something works, it isn't the fuse. If the machine is totally dead, then it's the fuse.
The plate and other components must be clean and dry. The plate must be totally free of debris, oil, and defects. (Did you clean it with ammonia/water 50/50 ONLY? Did you thoroughly air dry it? Is it perfectly whole, with no burned spots, loose portions, broken wire strands, cracks, lint?) If the plate passes inspection, and if you know they're reinserted correctly into the little "tracks" at the top and bottom you can reset the "perform cleaning" message. Try pushing the little black "reset" button that is located on the right side of the machine between the other manual controls. Then turn the machine off, using your remote or the o/- switch at the back of the machine. After a minute or two, turn the machine back on and see if that solved the problem.
If not, then the problem is probably with the computerized controls, which can only be serviced by Vollara (the new name for EcoQuest). Call them at 1-800-989-2299, ask for repairs, and give #16618 as your dealer referral number (unless you purchased the machine from an authorized dealer with whom you are still in contact.)
Hope this helps.
Jan 27, 2011 | Ecoquest Fresh Air Air Purifier
Unit stopped working; no power
Fuse is located on the bottom back side by on/off switch.
Grip both top and bottom to pull out. It's a squeeze lever on both ends. I was able to pull out using fingernails once, the second time I needed to use a paper clip on one end.
Jul 05, 2008 | Ecoquest Breeze AT Living Air Purifier
Hybrid gp problem
You have to locate the "blade" that is causing a short (usually can see it sparking; if not, reset it (turn it off then on) in a dark room and locate the problem area (this is how I figured it out).  If you can locate the offending "blade", simply tear it out of the base where the spark is occurring, fold it back against itself so the metal does not contact anything other than itself (and is no longer contacting the base where the sparks occurred).
This fixed my unit (I was just about to throw it out when I tried this solution).
Jan 11, 2008 | Sharper Image Hybrid GP (SI724) Air...
Red Light indicator on
I have a Bionaire tower air filter model BAP1700 that I bought from Costco. The filter check LED came on recently after 5 months of use. After cleaning the Permatech filters, I tried every remedy on this website including following the instructions that say push power button for 2 secs. Nothing worked. Then I noticed a tiny hole on the control panel in front of clean filter LED; I pushed a paper clip pin into that hole, felt a click, held it down and 2 secs later, LED went out. Success!
Apr 06, 2007 | Bionaire BAP1500-U Air Purifier
Replace Filter Indicator Will Not Turn Off
I owned the previous model of the same unit with the hole for the paperclip. But it wore out and I replaced it with the HAP422 and found the same issue; no hole to "reset" the light. I was just fooling with it and determined that "some" switch would reset it and finally held the power on button on for a few seconds, after which, the red light flashed and then went out. Problem solved. BUT THERE IS NOT ONE WORD IN THE MANUAL TO TELL YOU THIS! WHY NOT?
Dec 18, 2006 | Holmes Products HAP422G-U Air Purifier
Electrolux Band Aerus Lux Legacy Canister Cleaner Logo
97 people viewed this question
Top Electrolux Air Purifiers Experts
Richard Lane
Are you an Electrolux Air Purifier Expert? Answer questions, earn points and help others
